Old Nov 07, 2012, 11:40 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
FY30 IMU not showing up
OK,
I have checked everything several times.
And the FY30 lights up, but still does not show up when booting up.
And no AH.
Two Pic of the set up.
The monitor was blurry because I had to hurry after hooking up before it disappeared.
PS. tried to upload a video of the 2nd aileron causing the "Failsafe" to come on, but unable to do it.
Flybynight2 is offline Find More Posts by Flybynight2
Old Nov 07, 2012, 11:49 AM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
I was really thinking of getting an IMU for the DOSD, but from all this talk of problems do you guys think it would really make a noticeable diff? It would be going into my aerial photgraphy plane.
Techmeister is offline Find More Posts by Techmeister
Old Nov 07, 2012, 12:12 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by DenisM View Post
Van, what is the part number for that I2C pressure sensor DOSD v2 supports?
I would just build one myself using pitot tube from DIY drones.
Thanks!
It's a Honeywell HSCMRNN001PG2A3. Here's a source: http://sg.element14.com/honeywell-s-...SCMRNN001PG2A3
Discussed here: http://forum.tsebi.com/viewtopic.php...start=10#p1412
erkq is online now Find More Posts by erkq
Old Nov 07, 2012, 12:40 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Personally I don't think you'll notice any significant difference with/without the IMu attached.
Vantasstic is online now Find More Posts by Vantasstic
Old Nov 07, 2012, 12:43 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Is the IMU needed to provide any functionality to DragonOSD that you would not have without it? Is it only used for the AIH? Everything else like waypoint, RTH, loiter and autopilot/level flight all work w/out the IMU? I guess it would be just as easy to ask, what do you gain using an IMU with DraagonOSD?
-Thanks
CheckSum is offline Find More Posts by CheckSum
Old Nov 07, 2012, 12:48 PM
erkq is online now
Joined Dec 2010
-Thanks
I thought the DOSD could use IMU inputs to smooth out the flight if you route the servos through the DOSD. Am I mistaken? It would be nice to have the platform more stable for camera work. Otherwise you're stuck with routing the servos through the DOSD and then through the FY-30 for stabilization.
Old Nov 07, 2012, 12:51 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Flybynight2 View Post
OK,
And no AH.
Okay, your picture is really hard to decifer, but here's what I see.
#1. The FY-30 is being powered from the Xlator? If so, that'sa noa gooda. The FY needs something like 4.6v (minimum) to operate properly. The Xlator gets its power from the I2C circuit with is only 3.3v.
#2. Connect ONLY the GND and Rx to Tx line from the FY to the Xlater...ie remove the Red wire on your current connection.
#3. Run a power and gnd wire from your Rx to any +/- pins on the FY (I used one of the servo output pins). Now the FY has 5v to run and the Xlator has 3.3v to run.
Take a look at my wiring set up in this post: http://www.rcgroups.com/forums/showp...ostcount=19290. This works for me.
Old Nov 07, 2012, 12:57 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You are correct. The DOSD can react quicker to attitude changes provided by the IMU. An unstable plane or flying in gusty winds would likely benefit from an IMU. Will you notice a significant improvement w/wo the IMU? I haven't, but perhaps that's because I'm flying higher with a wide angle GoPro lens so bumps and stuff don't show up as much?...
Old Nov 07, 2012, 03:48 PM
DenisM is offline
Find More Posts by DenisM
Joined Jun 2007
I think I digged something
Ok thanks Van.
HSCMRRN001PD2A3
http://ca.mouser.com/ProductDetail/H...gKSPjD4RfSHq/S
That os 3.3v I2C.... do we need 1psi one?
I think so. DIY drones http://store.diydrones.com/Kit_MPXV7...v7002dp-01.htm show 0.3 psi sensor...
I don't recall. I'll have to do some research to see if I can find it again...
DenisM is offline Find More Posts by DenisM
Old Nov 07, 2012, 04:00 PM
erkq is online now
Joined Dec 2010
Ok thanks Van.
Honeywell ASDXACX030PA7A3, (30psi, absolute pressure, I2C interface)
Honeywell ASDXRRX001PD2A3, (1psi, differential, I2C interface)
These are 3.3v I2C.... do we need 1psi one?
Daniel himself said you must use this one: HSCMRNN001PG2A3. See my post above.
Old Nov 07, 2012, 04:22 PM
Will it ever Fly?
Joined Nov 2011
yes, I have it run like you have.
I just took the pics to show the Fy30 is powered up, but not being sensed by the DOSD.
Is this a BAD one? How would I know.
Support from Dragon Labs, will not answer any of my e-mails. As usual take the money and run.
Old Nov 07, 2012, 04:51 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Wha??? Who are you sending the e-mails to? I do support for Dragon Labs (volunteer basis) and I've answered every e-mail I get...even if I can't provide the direct answer personally.
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
you need to speak to chirs1seto. He's a good guy, sure he will fix this for you.
do you have a multimeter you can test all the voltages are correct? I have a feeling there are two lights on my FY, I will check
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Nov 07, 2012, 04:57 PM
undefined
Joined Jun 2008
just one light on the FY after initialisation
dumb question - have you got the Xlator the right way round?
Old Nov 07, 2012, 06:09 PM
Will it ever Fly?
Joined Nov 2011
Van, (sorry) was not to you.
I was talking about Dragon Labs support Web site.
Crash, I don't know Chris.
yes I everything is set correct, I have checked it all several times.
PS Posted schematic.
And I have been working on it today in 40 weather, My fingers are frozen.
JIm
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
