Old Sep 10, 2012, 02:57 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Firatp View Post
I could connect 3 sensors at one time with pictured gadget.
I connected barometric, airspeed and FY30 translator at the same time. All of them run perfect.
I bought it from fpvcenter.com
Cheers
Attachment 5145938
Oh... jeez... that's a great find! I just soldered up a cable to connect my FY30, altimeter and airspeed sensors!
erkq is online now Find More Posts by erkq
Old Sep 10, 2012, 03:00 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Originally Posted by erkq View Post
The wind had nothing to do with your inability to turn and your stall. The plane has no idea it's in wind when it's flying. The plane got far away from you and it was heavy. But you'd know this if you got some flying experience first. You're just fighting yourself trying to learn this way.
I wish you luck, really. But sometimes people who don't want to learn from other's experience quit the hobby in frustration. I hope you are able to persevere! It's a fun hobby!
You aren't wrong - I take total responsibility for taking the plunge. I have 4 multirotors, one with FPV gear, but this is my first plane. I should learn on a lighter, less-expensive plane. I should learn how to make a downwind turn into a gusting headwind. I lost a $75 used camera and maybe a $5 BEC. I had two witnesses who found it hilarious and I have video of the event. That's $80 for entertainment for 3 people, not much more than taking in a movie!
viper522 is offline Find More Posts by viper522
Old Sep 10, 2012, 03:10 PM
erkq is online now
Joined Dec 2010
Well, I'm glad to hear it. It sounds like you'll stay in the hobby, then. Yeah... witnesses... a lot of help they are! $80... not too bad.
Sorry to be hard on you. I had a buddy who bought an E-flight SR-120. I tried to talk him out of it, but he wouldn't listen. It put him off the hobby for almost a year! Fortunately he's back at it with a 130x! I just hate to see people put off a fun hobby when they could enjoy it. But it sounds like you're well into RC and can take care of yourself.
Old Sep 10, 2012, 04:35 PM
flipy is offline
Find More Posts by flipy
United States, FL, Tampa
Joined May 2010
I'm trying to replace the old burned current sensor with a new one.
I've bought an ACS756 based PCB (http://www.ebay.es/itm/230828719406?...ht_1613wt_1414).
It has 4 outputs:
- V+
- GND
- Vout
- Vsense
For what I can see, V+, GND and Vout are the same outputs from the IC Current Sensor (http://www.allegromicro.com/Products...Cs/ACS756.aspx).
However, V+ and GND are connect by a "BC 104" (transistor?, mind me, I'm learning electronics too!), and they seem to affect Vout somehow.
Vsense seems to be directly connected to the pads (current).
Questions is: how should I connect this to the DOSD?
I guess GND is GND on DOSD, V+ is V2 on DOSD, and Vout is Vsense on DOSD? (I don't think Vsense from the PCB should be connected to Vsense on DOSD).
flipy is offline Find More Posts by flipy
Old Sep 10, 2012, 06:17 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Why don't you contact John (jmstech1@gmail.com) and get a new current sensor right from the source - than you don't have to worry that your DOSD could burn :-)
flyandi is offline Find More Posts by flyandi
Old Sep 10, 2012, 08:36 PM
rotormonkey is offline
Find More Posts by rotormonkey
rotormonkey's Avatar
Canada, ON, Ottawa
Joined Aug 2009
flyandi: My phone is a Samsung andriod, but it's running firmware v2.1.x. Doesn't meet the requirements. I've no idea what the screen resolution is either, I'm guessing probably not 800x600 (or whatever the requirement was).
Here's another question. A little earlier in the thread I was having problems with interference on the RC side. I found that disconnecting the current sensor solved the problem even though I was already powering my video stuff from a different battery than the RC stuff.
Somebody had suggested adding an LC filter to the current sensor so I could get it working. My question is - why does the current sensor have 3 wires? One signal, one power, one ground. Are the power and ground wires only for powering the DOSD from the flight pack? Since I'm not doing that anyway, could I potentially just remove those two wires and use the signal only in an effort to remove the interference the video stuff is causing?
If not, if I'm going to use the LC filter, would I filter the power and ground? Or filter the signal line?
rotormonkey is offline Find More Posts by rotormonkey
Old Sep 10, 2012, 11:47 PM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Anyone use the dragon osd gps with a my fly dream tracker?
cody069 is offline Find More Posts by cody069
Old Sep 11, 2012, 04:44 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
yep, works fine
Haych is offline Find More Posts by Haych
Old Sep 11, 2012, 05:45 AM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
yep I'll second that. It works great.
metalbender4by is offline Find More Posts by metalbender4by
Old Sep 11, 2012, 05:51 AM
cody069 is offline
cody069's Avatar
Joined Dec 2008
Cool.....Thanks guys
Old Sep 11, 2012, 09:53 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
current sensor's three wires are ground, current (middle one on the plug) and voltage
there must be almost zero RF coming out of the current sensor so if you have interference when plugging it in, what else is connected to it? your ESC?
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Sep 11, 2012, 06:53 PM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
So is anyone using DragonOSD with an ezUHF receiver? I want to do some testing, but I'm finding posts that say an analog converter is required to get RSSI working properly? Anyone have any experience?
Tracks is offline Find More Posts by Tracks
Old Sep 11, 2012, 08:09 PM
fixandflydan is offline
Find More Posts by fixandflydan
fixandflydan's Avatar
Joined Jul 2012
Is "throttle step" and "throttle gain" the same thing?
Does throttle step have to be greater than 0 for dosd to control throttle?
fixandflydan is offline Find More Posts by fixandflydan
Old Sep 11, 2012, 08:16 PM
Canada, ON, Ottawa
Joined Aug 2009
I don't think you understood.. When I plug it in everything starts glitching on the RC side. I'm guessing because it's bridging the video circuit with the RC circuit so each is no longer isolated.
I already have torroid filters, and twisted wires on the vtx, gps and camera wires which are the only things connected to the OSD.
What I would like to do is find a way to get the current sensor to work without killing my RC range (I'm on 72mhz).
Old Sep 11, 2012, 08:28 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Throttle step of 0 disables any DOSD throttle control. To have AP 'cruise control' you need to set your cruise speed, throttle mode 2, and throttle step >0 (start with ~8 and adjust as needed). The DOSD will control throttle UP TO what the throttle stick is at. It can NEVER exceed actual stick position...i.e. if you flip on AP and reduce throttle all the way then your plane will only be a glider. If you turn on AP and give it 3/4 throttle the DOSD will try to maintain the set cruise speed only up to 3/4 throttle. For failsafe AP and cruise control you need to set your throttle failsafe to or above what's needed to maintain your chosen cruise speed.
I've tried cruise control...didn't like it. Don't get me wrong, the DOSD was working the throttle to maintain, but I felt disconnected from the control loop. I found I prefer just setting my throttle to my approximate setting from comfortable cruise speed and just leave it there. This also seems to help with other AP functions, like maintaining altitude, ascending/descending to different waypoint altitudes, etc. I actually think you'll find more people prefer a set throttle vs cruise control...at least I do.
Vantasstic is online now Find More Posts by Vantasstic
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
