Old Sep 08, 2012, 05:30 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by viper522 View Post
I forgot to ask this before, but does DOSD have a heading hold mode, or some other hands-free mode that will level the plane while I use pan/tilt controls to look around?
You can enable stabilization hold (either GPS stab, or IMU stab if you have an IMU attached). You can have the stabilization either always on, on only when you turn it on, or on a slider/knob and can adjust how much/little stab gain you want while in flight.
Vantasstic is offline Find More Posts by Vantasstic
Old Sep 08, 2012, 05:35 PM
Joined May 2011
Originally Posted by Vantasstic View Post
Yes, for AHI you need to connect and IMU. The DOSD, GPS, and Current Sensor will provide all the autopilot/waypoint/RTH/stabilization capabilities you'd likely need. The IMU would provide more stabilization refinement plus the AHI. The recommended is the FY-30 with DragonOSD Xlator board...while you're at it, I'd recommend adding a barometric sensor for better altitude readings. All these can be found at ReadyMadeRC. FY-30 ~$99, Xlator ~$20, Baro ~$20. NONE of these items are REQUIRED for AP/RTH/Waypoint. Consider them additional options to enhance your DOSD experience.
Thanks for that info Vantasstic. While we're at it, I' like to get your advice on something. I'm considering buying a GPS tracker like this one:
http://www.ebay.com/itm/GPS-GSM-GPRS...item53ee988bfc
It basically sends you GPS coordinates if your plane goes down through txt message. I want to know if it would cause any sort of interference with my DL or GPS or any other component?
THOMASJONES is offline Find More Posts by THOMASJONES
Old Sep 08, 2012, 07:17 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I can't answer on the tracker question. If it's transmitting a signal then the possibility exists that it can cause issues. I just use a recorder on my ground station to record GPS info. Of course, if you loose video from the plane then the recording won't be of much use.
Old Sep 08, 2012, 07:51 PM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Check out the beacon from FMKit. It doesn't require a gps signal or a cell signal, or a sim card. It is super small and light, and can transmit for weeks. You just need a cheap walkie talkie to track it. It uses a timer or VOX so it doesn't transmit during flight. $50.
iskess is offline Find More Posts by iskess
Old Sep 08, 2012, 09:04 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Link???
Old Sep 08, 2012, 09:38 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
http://www.fmtv.us/rf_beacon.html
http://www.rcgroups.com/forums/showthread.php?t=1274173
Old Sep 09, 2012, 08:58 AM
Fus ro dah!
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I went back and did a step for step connection with my FY30 and FTDI. Wow....follow the instructions and it really does work!!! I had connected my FY30 to early on my previous attempts. I was able to connect and check the firmware version now. I've got V1.16...the latest available, so won't worry about trying to reload with different (older) firmware. Chris is helping me out with this so I should be up and running in the near future. Thanks for the help guys!!!
Glad it worked for you. I did the same thing recently - couldn't get it to connect then followed the instructions exactly and bam.
Thanks also for turning me onto the Xlator board. I'd been using the DOSD to control rudder and FY30a on the ailerons. Is there a post that explains the benefits of using the Xlator?
Bigster is online now Find More Posts by Bigster
Old Sep 09, 2012, 10:31 AM
United States, CA, Sebastopol
Joined Dec 2010
One benefit is you get an artificial horizon
erkq is offline Find More Posts by erkq
Old Sep 09, 2012, 09:38 PM
rotormonkey's Avatar
Canada, ON, Ottawa
Joined Aug 2009
I've noticed the GPS co-ordinates on the OSD seem to disappear and reappear throughout my flights. Altitude, distance, speed, etc appear to continue updating though so I don't think the GPS is losing sat lock.
Anyone have any idea what's going on?
rotormonkey is offline Find More Posts by rotormonkey
Old Sep 09, 2012, 10:13 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Adjust your...oh crude, I forget now....something ratio (alt ratio?). The lower the number the sooner the GPS display disappears. The higher the number the longer the coords show. It has to do with distance vs altitude ratio. This is normal, not a display problem.
Old Sep 09, 2012, 10:14 PM
Fus ro dah!
Bigster's Avatar
Joined Sep 2004
No kidding!? I guess I'll have to go back and read up! Thats pretty cool.
Old Sep 09, 2012, 10:27 PM
San Marcos, CA
Joined Aug 2009
Oh man - I had no time to fly this weekend :-( really sad!
flyandi is offline Find More Posts by flyandi
Old Sep 10, 2012, 12:59 AM
Australia, VIC, Melbourne
Joined Mar 2010
yep, I think thats the one Lee, I set mine to about 10 I think (default 0.7??) and I see co-ords pretty much all the time.
Haych is offline Find More Posts by Haych
Old Sep 10, 2012, 03:16 AM
fixandflydan's Avatar
Joined Jul 2012
What is throttle gain? Is that throttle step?
fixandflydan is offline Find More Posts by fixandflydan
Old Sep 10, 2012, 03:18 AM
Barcelona, Spain
Joined May 2010
If you're referring to "Peak values", it should go away once you start flying.
They're meant to provide information in case of failure/crash, so it is possible to record them.
flipy is offline Find More Posts by flipy
Discussion Dragon OSD Level Flight Video Piloting (FPV/RPV) 20 Apr 17, 2011 12:12 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - Electric - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer Video Piloting (FPV/RPV) 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq Video Piloting (FPV/RPV) 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman Video Piloting (FPV/RPV) 8 Nov 11, 2008 05:13 AM
