North Carolina
Joined Nov 2008
OUTSTANDING! That is the exact compass I was hoping to work with. I've sent an email to place my order. I'm assuming to wire the compass to the DragonOSD+ is a simple wire connection between the i2c connections, right? Is there info on how to configure the OSD for a compass (versus a GPS)?
This is awesome news. I've been looking for an OSD that supported a digital compass forever! Can't wait to get this and give it a try! Thanks! Quote:
North Carolina
Joined Nov 2008
Just thought of one more question:
When I connect the HMC6343 to the OSD, what will my display options for the compass heading be? Will I be able to use the same compass display options of the GPS? (Fingers crossed that you'll say yes! ).
I have to be sure:
here under "Serial Port" topic you can find 3 links to USB2TTL converters that can be used with OSD+. One of them is 5V FTDI board (I have this one). From another hand there is 3.3v pin in I2C connector in OSD. Will they (FTDI 5V and OSD+) work together? Regards Michal |
Joined Aug 2005
gobigkahuna,
You won't need to configure anything. If a compass is detected, it will use the compass heading instead of the GPS (if present). So all you need to do is to plug it into the I2C port. At a later stage I could get into writing the support for a humidity sensor and depth sensor. galaxiex, What kind of screen are you using to view the OSD display? If you are using a CRT, you will find some of the stuff off the edges of the screen. This can be easily addressed using the SAFEZONEX and SAFEZONEY parameter in the menu. Those parameters allow you to move the display elements further from the edges so you can customize it to make full use of your particular display unit. Usually LCD/goggles will see more of the screen and will require no or less adjustments. Daniel |
Joined Aug 2005
gobigkahuna,
I forgot to mention - the OSD will work fine without a transmitter. Just connect the Video out to your line amplifier if you have one. If you are going to send the video over a long wire, it might be a good idea to have a line amplifier to drive the line. Likewise for the audio - just take it from Audio out. Daniel |
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
