Old Jun 16, 2010, 03:39 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
kempo,
Those were just ballpark figures. You can reduce ROTSTEPGAIN to 1.0 and APROTGAIN to 48.0 to see if the weaving is reduced. The key is to start with smaller values. You can use the default values for APROCSTEPGAIN and experiment. Ideally keep ROCSTEPGAIN lowish - less than 2.0 if possible.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Jun 16, 2010, 03:43 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by badlands View Post
Looks good Kempo - that would do me!
What does your DOSD+ control? rudder & ailerons?
Nope, a flying wing
renatoa is offline Find More Posts by renatoa
Old Jun 16, 2010, 09:35 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
RENATOA - i like that!
Not sure how you get all your fpv gear on there thou...
badlands is offline Find More Posts by badlands
Old Jun 16, 2010, 09:47 AM
kempo is offline
Find More Posts by kempo
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Like that :
kempo is offline Find More Posts by kempo
Old Jun 16, 2010, 01:01 PM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Today I tested again the autopilot:
1. I think that I will stick with ROTSTEPGAIN-1,5 ,APROTGAIN - 50
because with ROTSTEPGAIN-1 ,APROTGAIN-48..45 I don't like how it behaves;
2.I tried several setups for ROCSTEPGAIN/APROCGAIN : 2/45 ; 1,5/45 ; 3/45 ; 2/50 ; 1,5/50 ; 1,5/100 ; 5/45
and the cruise altitude 100m but it isn't working.
3. I've set the Valid HDOP to 0,9 , it is ok ? With this value now I've got the elapsed time and not the UTC time. Should I lower it? What is the best value for it ?
4. When are the longitude/latitude coordinates displayed? Because sometimes I see them on display and somethimes not.
5. Now I've got the 7.5 beta7 version shoulld I upgrade to a newer firmware version--8.8, do I need to note
all my parameter settings to modify them after I upgrade ?
6.I've bought the 10 Hz - FMP04 GPS module and now I want to connect it.(http://www.ohararp.com/files/FMP04_DataSheet_R02.pdf)
The connection from the image is correct ?
7. Where can I see/download the flying log ?
I hope that I don't forgot something .
Old Jun 16, 2010, 01:42 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
Number 7 answer -
1. Enable logging either through the on screen menu or serial terminal. This is done by setting the logging period (in seconds). You can use the SET LOGPERIOD xx command to do this from the serial terminal. xx is a number in seconds indicating the number of seconds between each log (i use 1 sec).
2. Get a home position lock.
3. You can then list the various logs via the serial terminal, using the SHOWLOGS command.
4. You can download the specific log via the serial terminal using the DUMP xx command where xx is the log number as listed in SHOWLOGS. This will result in a text dump of a KML formatted file which you will need to either capture or cut/paste into a file and name it with a .KML extension. This file can then be opened with GoogleEarth.
Old Jun 16, 2010, 02:02 PM
Joined Aug 2005
kempo,
2. Are you using EVN1 and EVN2? Ie. is the wing mixing being done by the OSD or the radio?
3. Valid HDOP should be around 1.2 to 1.5. Too low and you may never get a home position fix. The clock shows elapsed time (as long as it gets a home fix. Until then it shows either random or UTC time, depending on the kind of reception it is getting.
4. The lon/lat data is shown if your altitude to range ratio falls below the value set in the menu. Above that, it is not shown but if you get too low and below it - it shows up.
5. Usually it is better to use newer firmwares. Be sure to read the changes for all the intervening versions. You probably need to write down your settings for such a big jump in version.
Daniel
Old Jun 16, 2010, 02:19 PM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Number 7 answer -
Well I tried and I've got this result :
Badlands cam you make a tutorial for newbie with printscreens ? Step by step ?
Thank you.
Old Jun 16, 2010, 02:25 PM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Originally Posted by Daniel Wee View Post
kempo,
Output 1 - EVN1
Output 2 - EVN2
Elevon mix - 3
The wing mixing is being done by the OSD.
Old Jun 16, 2010, 02:28 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
Kempo - can u use Hyper Terminal?
Old Jun 16, 2010, 02:38 PM
magnetman is offline
Find More Posts by magnetman
Fly the Discombooberator!
magnetman's Avatar
Joined Nov 2003
Commands
How do you list all the commands available via the terminal??
magnetman is offline Find More Posts by magnetman
Old Jun 16, 2010, 02:39 PM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
I never used commands until now.
Old Jun 16, 2010, 02:44 PM
Joined Aug 2005
kempo,
Maybe you should try a larger value for APROCGAIN and ROCSTEPGAIN.
Daniel
Old Jun 16, 2010, 10:07 PM
Joined Aug 2005
kempo,
BTW, are you using a 5Hz GPS or 10Hz one?
Daniel
Old Jun 17, 2010, 01:52 AM
renatoa is offline
Joined Sep 2007
Kempo is off to job, less internet accesibility during the East European work time, so I'll respond behalf of him.
I think is 5Hz, is more than one year old, V1.0
Only those from last 6 months or so are 10Hz.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
