Old Jun 13, 2010, 11:18 PM
i3ond is offline
Find More Posts by i3ond
James Bond
i3ond's Avatar
USA BABY
Joined Jun 2010
how hard is the install and where do you get the gps module?
Thanks.
BTW. Congrats on the 2k posts
i3ond is offline Find More Posts by i3ond
Old Jun 13, 2010, 11:56 PM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Installation is not too difficult and gps module is found here: http://www.ohararp.com/products.html I recommend you tell Ryan about USPS shipping instead of UPS (much cheaper) and also buy his pcb board which makes installation easier. It is very fast start up time, very cheap and very good response. I do not make a cent on this and how could you when he is selling them at $25 for the gps module!
John
JMSTECH is offline Find More Posts by JMSTECH
Old Jun 14, 2010, 12:01 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
John, is this the one you recommend? Had 8 pins, byt 4 in the front are the ones we need?
"10 Hz - FMP04 GPS module
26x26mm (smart antenna type)
MediaTek chipset"
The $25 one?
Cralis is offline Find More Posts by Cralis
Old Jun 14, 2010, 12:08 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Yeah it is Cralis, I have a few other GPSs but this is the only one which would pick up a signal in my basement shop which is covered in wood and cement. plus it has a built in battery under the tin so it aquires fast.
One more note ... reverse the RX and TX going into Dragon OSD and this is according to the silkscreen or labeling on their optional PCB.
John
Old Jun 14, 2010, 12:12 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Ta. Sent the guy a mail asking about cheap post... Dropped your name with the email.
Old Jun 14, 2010, 04:21 PM
badlands is online now
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
I now use this FMP04 GPS module all the time.
Again - thanks goes out to John for suggesting this nice unit.
badlands is online now Find More Posts by badlands
Old Jun 14, 2010, 04:29 PM
kempo is offline
Find More Posts by kempo
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
Originally Posted by Daniel Wee View Post
kempo,
The timer automatically changes to elapsed time once you get sufficient GPS reception.
Try reducing ROTSTEPGAIN and ROCSTEPGAIN.
Daniel
Today , during 2 flights, I played with APROTGAIN and ROTstepgain only.
The best result is with APROTGAIN- 35 and ROTstepgain-3(0:37 first video), but still, after the first turn it dives,
start to do sudden movements.
All the rest of the Autopilot settings remained unchanged:
ROTlimit- 15,1
MAX heading chg- 44,9
APROCGAIN-39,9
ROC limit -10
ROC step gain - 0
Max. altitude chg.-9,6 m
Low speed limit - 1,96
Cruise altitude - 100
Current waypoint - 0
Hit distance- 200m
Auto-stabilisatize gain-0
Do I need to change something else or should I play only with APROTGAIN and ROTstepgain until it stops dive/oscillate/wagging?
Video still processing:
Dosd+ autopilot test 2 (4 min 25 sec)
Dosd+ autopilot test 1 (4 min 14 sec)
kempo is offline Find More Posts by kempo
Old Jun 14, 2010, 04:51 PM
Wadsworth is offline
Find More Posts by Wadsworth
HD Hero Rocks!!!!!!
Wadsworth's Avatar
Houston, TX
Joined Dec 2009
Kempo,
Have you tried the return to home with ROC step set to anything higher than zero?
I don't know what plane you are using but some of my planes tend to dive after certain rudder or aileron input. The DOSD+ then needs to use elevator to counter the dive.
The way I understand it, with ROC step at zero it won't do anything to the elevator, and this could be why you are diving. Try running it with ROC step at 2 or 3..
Wadsworth is offline Find More Posts by Wadsworth
Old Jun 14, 2010, 06:06 PM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
kempo,
I would also suggest a smaller value for ROTSTEPGAIN. Let the plane turn more slowly. I would probably use a ROTSTEPGAIN around 1.5 and APROCGAIN of around 50.0. Don't shoot for a fast or tight turning autopilot. Go for a very gentle turn since there is no IMU.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Jun 14, 2010, 09:27 PM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
hi all,
Just curious if i need to do anything to my dosd+ to use flytrons small current sensor? also which way does the current need to go through it?
Cheers
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Jun 14, 2010, 10:27 PM
Joined Aug 2005
spitfire_Doug,
You may need to fiddle with the Current Offset and Current Multiplier settings in the menu to calibrate it. Other than that, I reckon it should work just fine. Do make sure the wiring is correct though.
Daniel
Old Jun 15, 2010, 02:35 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Originally Posted by spitfire_Doug View Post
hi all,
Cheers
Doug
Hi Doug,
As Daniel stated, you should fiddle with the adjustment with in your OSD menu. As for wiring this current sensor: http://www.flytron.com/58-ultralight...nt-sensor.html the connection on the pcb is exactly the same way as this one: http://www.forum.tsebi.com/viewtopic.php?f=7&t=64
Don't forget to make sure your ground is facing the "outside" of the Dragon OSD+ pcb. That is what we call the ground rail... ground trace follows the outside edges of the board except for one set of plug.
John
Old Jun 15, 2010, 07:19 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Spitfire Doug
I use the Flytron sensor with DOSD+ and it works great. Manual is on line at their website - and the new revised version does say which is right way to connect it up : )
Seems very Linear and accurate. I have no offset in there (but it is only approx calibrated at moment - good enough for FPV)
I use a servo lead to connect up to the DOSD+, but note that the signal line and the Vbat from the Sensor must be swapped around to suit the DOSD+ conenctor so pay attention to that. I'm assuming that you want to use that voltage input on teh DOSD+ to supply / monitor the battery.
Shikra is offline Find More Posts by Shikra
Old Jun 15, 2010, 02:16 PM
kempo is offline
kempo's Avatar
Romania, IS, Iasi
Joined Nov 2008
kempo,
Daniel
Well with this settings ROTSTEPGAIN-1,5 and APROTGAIN - 50.0 RTH works . Not straight to home(it moves like a snake) but it's comming home .I tried several flights- aprox 30 minutes and same result: it works. Thank you Daniel.
Now I want to configure the altitude cruise. For that I must change the APROCGAIN and ROC step gain, do I need to change anything else(ROC limit,Max. altitude chg,Hit distance) ? With what values I must start ?
Dosd+ autopilot working without stabilisation (2 min 52 sec)
Originally Posted by Shikra View Post
Spitfire Doug
Shikra I've got a Flytron sensor too. Can you post some pictures with your connection ?
Old Jun 15, 2010, 05:06 PM
badlands's Avatar
Joined Mar 2010
Looks good Kempo - that would do me!
What does your DOSD+ control? rudder & ailerons?
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
