Old Mar 27, 2012, 11:36 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Originally Posted by vantasstic View Post
the arduimu v2 works directly with the dosd...you may be able to find one in the for sale section. I had one, but already sold it. You are not out of luck though...read this:
http://www.forum.tsebi.com/viewtopic...75074101265f2a
mudlark is offline Find More Posts by mudlark
Old Mar 27, 2012, 11:38 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
Make sure you twis the GPS wires as much as possible and add a toroid ring as close to the GPS as you can with about 5+ turns. After that mount it away from your VTx and motor etc... And do not mount the GPS cables anywhere close to your ESC... If you do all that then you should honestly get a lock in 30sec! To a couple minutes... But it will save you $40 and will work great.
Also the one in the link needs to be modded to work with DOSD 3.3v... Read at the bottom of the page.
Crazy1
Originally Posted by barok View Post
sometimes it takes awhile for my gps to lock on to the satelites,,thinking of replacing my gps this one has battery back up..is this compatible with Dosdv2
simple osd gps unit
http://www.readymaderc.com/store/ind...roducts_id=219
crazy1pilot is offline Find More Posts by crazy1pilot
Old Mar 28, 2012, 05:15 AM
999vertigo is offline
Find More Posts by 999vertigo
Closed Account
Joined Aug 2011
deleted
999vertigo is offline Find More Posts by 999vertigo
Old Mar 28, 2012, 05:20 AM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Originally Posted by 999vertigo View Post
Does Dragon OSD supports "fly-by-wire" mode with IMU installed?
No, it will keep the wings level and hold altitude but will not correct to the track it was on like the RVOSD.
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Mar 28, 2012, 08:31 AM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
What do you mean 'fly by wire'??? All R/C systems are 'fly by wire'. Do you, perhaps, mean can program in and fly waypoints? If so, yes, the DOSD does that. You have to load your mission on the ground and can't change the mission while in flight. You can select/change which waypoint you want it to fly to, but you can't upload a different waypoint mission while airborne.
Vantasstic is offline Find More Posts by Vantasstic
Old Mar 28, 2012, 09:11 AM
Closed Account
Joined Aug 2011
deleted
Old Mar 28, 2012, 11:26 AM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Yes wireless fly by wire...Agree.
Does with DOSD+IMU model aircraft can remain stability provided by IMU in non A/P mode (no RTH or Waypoint seq) when user is flying the rc model?
At the time he is flying the model !
If I understand the question then the answer is yes
there is a stability setting on the DOSD. You can assign as much or as little GPS stability and or IMU stability as you wish.
Furthermore you can assign the stability to a channel switch or pot on your RC Tx to adjust stability remotely without going into the menu, from 0-100% of your menu setting
I have seen people turn up the GPS stability, take the goggles off and let the plane fly itself while they chat
this is not the same as the "fly by wire" that RVOSD offers which I believe is more like a headlock gyro
Note that if you have a lot of stability it will reduce the effectiveness of the autopilot.
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Mar 28, 2012, 01:08 PM
Closed Account
Joined Aug 2011
deleted
Old Mar 28, 2012, 03:13 PM
undefined
Joined Jun 2008
Thx Mike,
Correct me please if i`m wrong.
From DOSD Custom Settings Menu---GAIN Channel example C7.
Then from Autopilot Settings Menu---Auto-stabilize gain with IMU or GPS-stabilize gain with out IMU should change gain from C7.
If IMU is active how we can select which gain to adjust.Or both they will change gain.
yes both
Old Mar 28, 2012, 03:51 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thx Mike,
I see no reason to have both stabilization set...if no IMU then set the GPS stab gain to >0, if using and IMU then set the GPS gain to 0 and the IMU gain to >0.
Old Mar 28, 2012, 04:01 PM
Closed Account
Joined Aug 2011
deleted
Old Mar 28, 2012, 04:25 PM
undefined
Joined Jun 2008
You can assign only one channel for gain..
Is what i just asked and Mike say both.
it's correct, there is one gain channel for both types of stabilisation
Vantasstic is saying that you don't need two trpes of stabilisation at the same time.
Old Mar 28, 2012, 04:43 PM
Closed Account
Joined Aug 2011
deleted
Old Mar 28, 2012, 09:40 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Then how you can disengage the GPS gain if IMU is connected with only one gain controlling both GPS and IMU.
In the DOSD menu there is a GPS Stabilization gain setting and another that just says Stabilization Gain (I believe). The one that says GPS gain uses the GPS the other uses the IMU. If you have an IMU attached and talking with the DOSD then I'd set the GPS Stab gain to 0 to disable GPS stabilization and adjust the Stab Gain (for the IMU) to suit your taste. If you assign the Gain channel to a slider/knob you can adjust the amount of gain while in flight. Lets say you set the stab. gain to 3 and assign a turn knob for Gain. With the knob all the way down you should have no stab gain, all the way up you should have stab gain of 3. This would be helpful to find what amount of gain you like. To little gain and the stabilization will be slow to correct, to high and it'll bounce all over the place.
Old Mar 28, 2012, 11:20 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
Alright .. my first prototype of the DOSD Cable for the "DragonBox" is ready .. It connects the ImmersionRC TX to the DOSD to the CCD Killer Cam..
The DragonBox will be my first attempt to create a little tiny box to fit all the sensor and the DOSD into it, so it's a clean and exchangeable installation of the DOSD in similar planes.
I also created custom cables to easily access the FrSky RX and a special PPM cable to connect the FrSky RX to the PPM Input of the DOSD.
Attached some pictures.
Next will be the power distribution block that will provide power to the DOSD, the RX and the VideoTX.
If anyone is interested, let me know. I can make those fairly quickly and they work great.
flyandi is offline Find More Posts by flyandi
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
