Old Jun 11, 2010, 11:37 AM
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Cralis,
Can you do that - connect it and measure it at the pin where it goes into the DOSD+, or at least on that side of the 100k resistor. Have the OSD powered up while measuring this.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old Jun 11, 2010, 07:01 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
I'd love to, Daniel... But.. not sure where to touch the positive probe. Can you tell me, and I'll give it a bash.
Cralis is offline Find More Posts by Cralis
Old Jun 11, 2010, 08:40 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Daniel... as an electronics novice... I am scared to put probs too close to things ont he board... scared of the 'magic smoke'. Is there anyway the diagnostics screen could show the voltage being read on the RSSI port?
Old Jun 11, 2010, 09:54 PM
Joined Aug 2005
Cralis,
As a matter of fact there is. Just set the OSD mode to 3 and see what "voltage3" says.
Daniel
Old Jun 11, 2010, 09:55 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
OK, checking now...
Old Jun 11, 2010, 10:43 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
30 minutes..
DragonOSD+ RSSI diagnostics (3 min 37 sec)
Old Jun 11, 2010, 11:29 PM
Joined Aug 2005
Cralis,
It looks like the RSSI voltage after the 100k is too low. You may need an RSSI buffer.
Daniel
Old Jun 11, 2010, 11:30 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Ah no! I thought the resistor I added (100K Ohm) WAS the buffer.
Old Jun 11, 2010, 11:32 PM
Joined Aug 2005
No - that's just a resistor. Thomas's early receivers did not include a buffer and did not do well on the RSSI output front as a result.
Daniel
Old Jun 11, 2010, 11:40 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Ok... are they easy to make, or would this be my only options? Not even sure it will work with the DOSD+ though...
Says:
Operating Voltage: 5VDC (powered by EagleTree eLogger).
So, I guess I need all pins off the DOSD+ to this device. Ahh.. this isn't good news.
Old Jun 11, 2010, 11:46 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Hi guys, looks like voltage 3 is for RSSI, is that right? It's going from 0.07v to 0.03v, I would ask on the tlrs thread what the RSSI voltage should be out of the reciever, even before you connected to the dosd+ it looked low to me.
Daniel, does the gain channel work with gps stabilization if I have auto-stabilization set to zero and gps-stabilization set at, say 4.00 if I launch with the gain switch "off" when I turn it on it should hold heading, is that right?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Jun 11, 2010, 11:52 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Mark, this is the info I have:
http://www.rcgroups.com/forums/showp...&postcount=377
But it sounds like a strange dialect of Greek to me...
When I measure with my volt meter, I get 0.89 when the Tx is on, and 0.44 when it goes off - which matches another guy who runs the Ramzibi.. Razibi... Bizira... what ever... another OSD.
It also kinda matches what THomas says:
"it is normal the off voltage is about 0.5V
and the on voltage is about 1.0V"
Old Jun 11, 2010, 11:57 PM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
I think yours is right then, looks like you will have to buy the one, or your could make your own for a dollar. Do a search for rssi buffer, very simple to make.
Mark
Old Jun 12, 2010, 12:18 AM
Joined Aug 2005
mark,
The gain channel works on both the IMU and GPS stabilizations. Where they are independent are the individual gain controls in the menu. So you can still use the gain control channel to test it.
Cralis,
"voltage3" is what you need to be looking at - this was mentioned in post #1654 above as well - you might have missed that.
Why don't you try a different resistor value - say 47k or something.
Daniel
Old Jun 12, 2010, 12:29 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks Daniel. I will try a 47K one. Will take a drive and find a shop that sells them. Do you think that would work, or should I just cut my losses and get that ET buffer? It;s both a space and a cost issue though, My wife is gonna kill me if I have to pay more for this damn plane! ehhe.. And space is an issue too..
If you think there's an average chance of a 47K working, I'll go get one now.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
