This loss-of-ppm failsafe is deigned for some digital systems (eg spektrum) that can have a throttle channel set at a value that would activate PPM stopping if using a PPM encoder, or an FM set that outputs rubbish when out of range DOSD will recognise the rubbish as a failsafe condition. If your Rx won't failsafe, then DOSD can't recognise a failsafe. |
France
Joined Mar 2008
Hello ,
Just few words about customer service of dragonlabs. Specially for john . You're just a great guy . My dosd had a problem . I send it to john . After check up , my new dosd was fried. John send me a new one with all the wiring ready to use . All that on two days. So thank you john for all you did for me . Dragonlabs rocks
Joined Sep 2011
I still dont get my gps to work. Tried having it connected for 1 hour with gps only. Tried 2 different gps. Same problem. No sats. What colors should the tx rx cable have? Can it be something wrong with my dragon osd? Please help me. Had this osd 'for 2 months and its frustrating that it doesent work.
I don't recall the colors of the Tx and Rx wires. If you have them hooked up wrong the DOSD won't boot. Try looking at the DOSD video output display and see if it's hanging up on the GPS section or boots all the way up. If it boots up then I'd rule out the Tx/Rx wires being wrong. You need to be outside for GPS, especially initial, lock. I would recommend connecting only the GPS to the DOSD and power the DOSD via a 2S or 3S battery connected to the power pins. Do not power up any other electronics. Leave it outside, in clear view of the sky for an hour or so. When the red led on the GPS is slowlty flashing then it's got satellite lock. Things such as VTx's, cameras, ESCs, etc, can create rf noise that affects the GPS. If you can get lock, from the above, then start adding one component at a time until you find out which, if any, are affecting the GPS from locking. I highly recommend wrapping the GPS wiring (all four wires) through a torroid as many times as possible, as close as possible to the GPS. You'll likely need to solder in some extention wires to reach your DOSD. Distance is also your friend. My GPS is on the rear half of my fuse and my camera, VTX, esc is up towards the front. |
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
remove the ESC-BEC power cable to osd/receiver if you are using a separate UBEC I would probably run the ESC control wire through the toroid a few times then take the pins out of the receptacle/plug that you don't want, fold them back, put some electrician's tape on so they don't connect/short |
Joined May 2011
Anyhow your package should be at the main processing branch and on it's way back to you. Expect to see it at your door by late next week.John |
What plane? Dosd powered by current sensor or video power? brand, frequency and mW of your vtx? And what kind of antenna? How far is your vtx from the antenna? Try this: Power up dosd with gps outside, but no camera or vtx. Just leave it in your back yard or something. The red light on gps will blink once at power up. It will start blinking regularly when it starts locking on to satellites. If it doesn't start blinking after an hour, something is most likely wrong with the gps. (or wherever you are has some WEIRD interference). Once the gps starts blinking, power up the camera. Wait 10 seconds. If the gps stops blinking it's interference from the camera. Move the camera further and try using a toroid on the camera cable. If its still blinking, power up the Vtx. After 10 seconds, if it stops blinking then your vtx may be swamping the gps. This occurs more often on 1.2-1.3ghz. In this case, you can try this filter, or a similar one for your vtx frequency. http://www.nghobbies.com/cart/index....roducts_id=565 If its still blinking, power up your plane. Again, wait 10 seconds. If it stops blinking now, then your GPS or it's cable may be too close to the ESC or power cables. Try repositioning your cables and putting a toroid on the gps cable, close to the gps. If its still blinking, put on your goggles and go fly your plane! |
i found that all servos and chanell glitch and sometimes not moving. if i do direct conection without dosd, servos and motor works smoothly. is it my dosd fried or need to upgrade firmware. hope dragonlabs can help me way to fix. i like dosd very much. pls help me. tq. |
Joined Aug 2005
ultrojo,
It's not uncommon for the servos to twitch a little. This could be due to a number of things - such as the DOSD+ making some stabilization adjustments (if you are in autopilot or RTH or stabilization mode). It might be due to GPS position drift resulting in the DOSD+ making corrections as well. When the RTH/autopilot/stabilization is not active, you should not see twitching in the servos. Daniel |
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
