Old Feb 19, 2012, 07:24 PM
Jim2011 is offline
Find More Posts by Jim2011
Joined Aug 2011
Spektrum receiver with Dragon OSD?
I have a Dragon OSD V2 and am trying to get all my connections right and get it operational. Can this be used with a spektrum receiver as the ones I currently have are spektrum. I have a Dragon Link long range transmitter and receiver on order but figured I would try and figure it out in the mean time. If it will be too difficult I may shelf it until the Dragonlink Transmitter and receiver get here. Most connections were fairly easy to identify with the Dragonlink web site, but finding a ppm from a spektrum receiver is difficult. I am anxious to get it all working, but I am trying to be careful and not damage it in the process by a wrong connection.
Jim2011 is offline Find More Posts by Jim2011
Old Feb 19, 2012, 10:28 PM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Originally Posted by MikeTheCrash View Post
you need to power the servos connected to DOSD, the receiver and any servos attached to it.
normally you power one and the other is connected electrically via the PPM line thus powering the other
with a BEC in your ESC this is normally powering your system via the ESC control cable. Safer to use a separate BEC connected to a free servo position and tie back the power leads (both + and -) in the ESC control cable
DOSD does not supply power to servos.
OK, thanks Mike
Haych is offline Find More Posts by Haych
Old Feb 19, 2012, 10:32 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You will need to use a PPM encoder to connect your Spektrum Rx to the DOSD. Sparkfun/DIYDrones has them: http://store.diydrones.com/SearchRes...x=0&Search.y=0
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 20, 2012, 12:03 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Hello all!
I am trying to get back to flying, the forums, PCC and all that, but I am battling with heavy work load of a job upgrade, and a large project that completes soon. But I will be back soon. Infact, in anger, I threw together a large HK glider, but don't have the time to setup a new DOSD+, so might fly it conventionally. *SHOCK HORROR*
Hope everyone is alive and well.
Cralis is offline Find More Posts by Cralis
Old Feb 20, 2012, 04:36 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
As of last week also available here: http://www.dragonlabseu.bigcartel.co...ct/ppm-encoder
(outrageous shameless plug!!)
Originally Posted by Cralis View Post
Hello all!
Hey Craig! Are you going to come back and integrate waypoint programming into PC commander?
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Feb 20, 2012, 05:06 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Mike - I want to! Easy as! But, just gotta tie up some work issues, then I'll be BACK!!
Old Feb 20, 2012, 05:49 AM
Bruce the goose is offline
Find More Posts by Bruce the goose
Joined Feb 2012
is there any way to make the on screen text look better
Bruce the goose is offline Find More Posts by Bruce the goose
Old Feb 20, 2012, 08:12 AM
Ho-Jazz is offline
Find More Posts by Ho-Jazz
Just a dude with LiPos
Ho-Jazz's Avatar
United States, GA, Buford
Joined Nov 2009
DOSD rocks! Here is a little video of RTH testing on my ritewing Z2.
Z2 Dragonlink AP Test 2 (4 min 0 sec)
Ho-Jazz is offline Find More Posts by Ho-Jazz
Old Feb 20, 2012, 11:19 AM
undefined
Joined Jun 2008
http://www.ebay.co.uk/itm/Space-Spec...#ht_1240wt_905
Old Feb 20, 2012, 11:35 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Real funny Mike.
Bruce, I did this mod to improve my text with borders on: http://www.rcgroups.com/forums/showp...ostcount=14534
Old Feb 20, 2012, 11:38 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Hello all!
Welcome back Craig. It's good to see you again. As for setting you your DOSD...I know this neat program a fairdinkum mate (from your neck of the woods I believe) that did up this program called....PC Commander. It works great and makes setup a breeze. I highely recommend it...but if you want to do it the hard way...have fun!!!!!
Old Feb 20, 2012, 12:53 PM
undefined
Joined Jun 2008
OK sorry for the flippancy, what do you mean by "better"?
for example reduce the shadow with Vantasstic's mod
or if you are having trouble viewing text at the screen edges on fatsharks, for example, adjust the safezones
Old Feb 20, 2012, 03:33 PM
mudlark is online now
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, High Wycombe
Joined Mar 2001
I'm a bit concerned that you knew these existed.
mudlark is online now Find More Posts by mudlark
Old Feb 20, 2012, 04:43 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
I am going to power my motor through the sensor so i can get a measurement on battery mah used and voltage on it. My plan is
Battery 1 (FPV Battery)
DL RX
Battery 2
Motor
ESC
Connections
Connect PPM from DL RX to DOSD
DOSD to feed servos
But I want to ensure the next part
DOSD would technically be powered by the sensor if i wanted to get the motor battery voltage and mah used?
Ideally i would like the sensor only to give the data to the DOSD and have the DOSD itself powered by the servos. Is this possible?
rsands2801 is offline Find More Posts by rsands2801
Old Feb 20, 2012, 05:04 PM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
DL RX
Battery 2
Motor
ESC
Connections
DOSD to feed servos
Best just to use Battery 1 to also power the DOSD directly, this will give you what you want as well as giving you the ability to monitor the voltage of battery 1. You will still be able to get the mah used and voltage from the current sensor.
Just make a spur and connect it as in the manual if not taking power for the
DOSD from the current sensor ( you have to use the jumper if you need to power the DOSD from the current sensor).
Hope that helps
flylite is offline Find More Posts by flylite
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
