Old Feb 18, 2012, 02:08 PM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Originally Posted by Vantasstic View Post
I did a mod on my DOSD board that helped improve the text with borders on. In short, it produces a thinner black border. If you're not soldering profecient you could end up damaging your board so consider before doing. http://www.rcgroups.com/forums/showp...ostcount=14534
big thanks for the link. I remember reading about that mod. Not sure I want to risk it, but with our usual overcast skies, I need a solution for reading the upper section of the OSD. I tend to solder adjacent contacts together+re-do a lot when trying this stuff - but haven't bricked anything yet.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Feb 18, 2012, 05:07 PM
Joined Feb 2012
return home DOSD V2
How do i tighten up the turn redius?
when circling on return to home.
Bruce the goose is offline Find More Posts by Bruce the goose
Old Feb 18, 2012, 05:23 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Reduce the 'Hit Distance' in the menu. I think it's default to something like 200 (meters). Make it smaller and it should circle tighter. Or do you mean, how to make the initial turn to home tighter? I think that may be adjustable, but can't recall right off the top of my head...perhaps turning up the ROTstep gain...
Vantasstic is online now Find More Posts by Vantasstic
Old Feb 18, 2012, 05:43 PM
Just trying to get a nut.
scrtsqrl's Avatar
United States, CA, San Diego
Joined Oct 2006
Increase ROTStepGain. Do so in small increments.
scrtsqrl is online now Find More Posts by scrtsqrl
Latest blog entry: Travel Quad
Old Feb 18, 2012, 05:44 PM
Joined Dec 2007
Attitude Limit will determine the roll rate for you i think...could be wrong mind
rsands2801 is offline Find More Posts by rsands2801
Old Feb 18, 2012, 05:45 PM
Joined Dec 2007
Max heading change? if its higher it would change the roll rate according to manual
Old Feb 18, 2012, 08:01 PM
Delaware
Joined Oct 2007
Dosd+v1
Hey guys, I really can use some help. I have a DOSD+V1 with software version 4.0. I bought this when it first came out, but never used it until now. I plan to use it in a Stryker, but there is no elevonmix for this version of software.
I have tried for about a week to get the pc commander to work using the flytron usb/ttl loader and this one (http://www.foxtechfpv.com/index.php?..._image&pID=242) but no luck. I can use hyper terminal and the flytron loader to communicate with the DOSD. I also tried the ds 30 loader, but when I select the hex file the write config box on advanced tag and the write program on basic tab become unchecked and grayed out. When I click download, the download box opens and says "Nothing to do"
I hope you guys have some insight on what the problem is.
Hocke57.
Hocke57 is offline Find More Posts by Hocke57
Old Feb 18, 2012, 08:59 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
No, that only works if you have an IMU installed. The DOSD itself can't determine bank angles without an IMU's input.
Old Feb 18, 2012, 11:19 PM
hollywoodjoe67
United States, NH, Wakefield
Joined Mar 2011
standard 5pin plug
hey john,
how are ya? just wandering if i can get another standard 5 pin plug that goes from dragonlink tx to back of futaba radio, I filled the wire end connector with solder and could not melt it out...uggh....let me know, thank you...joe janis
hollywoodjoe67 is offline Find More Posts by hollywoodjoe67
Old Feb 19, 2012, 01:58 AM
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Hocke57.
I think the baud rate for connections changed around then sometime, don't know it that helps?
can you try loading older/newer versions incrementally ?
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Feb 19, 2012, 11:23 AM
Delaware
Joined Oct 2007
I have tried older and newer versions after the baud rate changed, and it hasn't helped.
Old Feb 19, 2012, 04:35 PM
Australia, VIC, Melbourne
Joined Mar 2010
I am currently in the middle of a new build (Zephyr II Wing) and am laying out the wiring schematic. I am running both servos on the DOSD as well as the throttle signal wire for AP to control the throttle. My question is; where does the power come from to power the servos while they are connected to the DOSD? Does it come from the CH9 PPM out/ power cable from the DL Rx, or does it come from the DOSD? Do I still need a BEC on the DL Rx if no servos are connected to it? I am wondering where (if at all) I need to use the external BEC.
Haych is offline Find More Posts by Haych
Old Feb 19, 2012, 05:39 PM
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Originally Posted by hollywoodjoe67 View Post
hey john,
I gave away my last one trying to help another Dragon Link user but you can give this guy a try.
http://www.hansenhobbies.com/products/connectors/
John
JMSTECH is offline Find More Posts by JMSTECH
Old Feb 19, 2012, 05:43 PM
undefined
Joined Jun 2008
are you getting live data or any kind of connection with PC commander?
Old Feb 19, 2012, 05:47 PM
undefined
Joined Jun 2008
you need to power the servos connected to DOSD, the receiver and any servos attached to it.
normally you power one and the other is connected electrically via the PPM line thus powering the other
with a BEC in your ESC this is normally powering your system via the ESC control cable. Safer to use a separate BEC connected to a free servo position and tie back the power leads (both + and -) in the ESC control cable
DOSD does not supply power to servos.
Discussion Dragon OSD Level Flight Video Piloting (FPV/RPV) 20 Apr 17, 2011 12:12 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - Electric - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer Video Piloting (FPV/RPV) 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq Video Piloting (FPV/RPV) 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman Video Piloting (FPV/RPV) 8 Nov 11, 2008 05:13 AM
