Old Feb 15, 2012, 05:32 PM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
You will need to power the OSD.
Tracks is offline Find More Posts by Tracks
Old Feb 15, 2012, 05:50 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Cheers Tracks !
AussieHoppy is offline Find More Posts by AussieHoppy
Old Feb 15, 2012, 05:56 PM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by AussieHoppy View Post
Thx Van for putting my mind at ease, you've confirmed my thoughts
I remember reading a long way back that text borders can have some effect... tonight I'll make the usb adaptor and try link to PCC so I can get things sorted
Btw, when I connect the osd to my pc, will I need to power the osd with the plane vid battery, or will it powerup from the usb? I'm working onsite atm, no access to a pc to read the manual...
re. usb connections - a few posts back - http://www.rcgroups.com/forums/showp...ostcount=15767
you may not need flight battery connected, but the osd does need power from somewhere!
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Feb 16, 2012, 03:16 AM
ultrojo is offline
Find More Posts by ultrojo
ultrojo's Avatar
Malaysia, Johor, Johor Bahru
Joined Feb 2012
Hi DOSD+ support,
after too many try & error, i am stuck
Sorry , i have to ask you, about my new DOSD+v2
using:
flysky 9ch (upgrade er9x firmware)
rmile PPM encoder
DOSD v2
cam, vtx,vrxm gps
my DOSD+ can display parameter Volt,gps etc but cannot access control mode in chanel5 via Radiolink, i already setup ch5 for control mode. and screen appear "AP DISABLED" blinking always.
my servo attached DOSD+ can works.
but seems ch5 not work on DOSD. because 3switch i push seems not works. i try 2 radiolink also same
can help me to solve it
thanks
ultrojo is offline Find More Posts by ultrojo
Old Feb 16, 2012, 04:37 AM
undefined
Joined Jun 2008
Originally Posted by ultrojo View Post
Hi DOSD+ support,
using:
rmile PPM encoder
DOSD v2
cam, vtx,vrxm gps
thanks
"ap disabled" means that you are in autopilot mode and there is no GPS lock
It sounds like your channel assignment is wrong in DOSD and/or in eepe
I have eepe as well. as Throttle defaults to ch3 on the radio perhaps your DOSD is expecting a different channel map. when you boot up the DOSD can you see on screen if it says radio type detected? Futaba is probably what you need unless you want to change the assignments. This is a simple fix if you have USB>TTL and PC commander
in eePe set mix P1>ch5 @ 100% then download it to your radio. this will make the knob on the top left of your radio the mode control
Old Feb 16, 2012, 05:09 AM
ultrojo is offline
ultrojo's Avatar
Joined Feb 2012
problem solved
thanks a lot MikeTheCrash!
my channel assignment is wrong in DOSD, i expect DOSD did chanel 5 for default chanel for control mode, i have to set it via PC commander "SET ctrchanel 5"
now can access.
only 1 small issue raise. only aileron stick can change menu (left right) , but ELEvator stick cannot move the menu..
any idea?
Old Feb 16, 2012, 05:48 AM
undefined
Joined Jun 2008
problem solved
now can access.
any idea?
I think you will have to change your elevator assignment in DOSD as well
Old Feb 16, 2012, 07:23 AM
ultrojo is offline
ultrojo's Avatar
Joined Feb 2012
thanks bro..
solved..
cause of ch2 radiolink reversed..
thanks mike
Old Feb 16, 2012, 09:32 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
DragonTrax Request
It would be nice if data from Dragon Trax could be fed to a laptop and subsequently displayed on the screen a la instrument panel...or perhaps to servos so that "steam guage" instruments could be constructed. This way, the video downlink could be kept clean of scene contaminating simbology.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Feb 16, 2012, 10:29 PM
Joined May 2010
so magic doesn't happen
Old Feb 16, 2012, 10:50 PM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
JBB,
I really think you should be here beside us and helping with us with interface layouts. IMO.
John
JMSTECH is offline Find More Posts by JMSTECH
Old Feb 16, 2012, 11:02 PM
scrtsqrl is offline
scrtsqrl's Avatar
Joined Oct 2006
Originally Posted by JMSTECH View Post
JBB,
John
Hey John!
I have no clue what interface layouts are...lols...
But I can try to help you from out here...
PM sent...
PS- I still have an original JMSTech Easystar FPV power bus. I'm sure it'll be worth gozzillions one of these days.
Old Feb 17, 2012, 01:57 AM
Joined May 2010
the first time you connect the osd to PCC, how long does it take to "download parameters"... it seems to be taking forever...
Old Feb 17, 2012, 05:54 AM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
It should only take a couple of seconds at most. Power it down and try it again. Make sure you don't have Tx andRx reversed.
Old Feb 17, 2012, 05:55 AM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I set channels for pan and tilt, but Im not seeing the bars on screen. I think I missed something. Anyone have this set up?
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
