Old Feb 10, 2012, 05:21 PM
MikeTheCrash is online now
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by gazzzz View Post
thank you mike thecrash you are the man
I just showed that to my wife and she laughed
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Feb 10, 2012, 05:41 PM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
lol
flylite is offline Find More Posts by flylite
Old Feb 10, 2012, 06:38 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
well I would love to test dragon tracks on 5.8ghz.
i love to build antenna and go far So far I have build cloverleaf, spw, helicals 4, 6, 8 turn. Gone out 8.1km on 5.8ghz 200mw. I even have a swr dyi meter to tune antennas.
I have two 5.8ghz receivers too ... well three
I've just built a new plane too. It has dragon OSD in it. And since my hd keychain broke I only record the sd version.
whakahere is offline Find More Posts by whakahere
Old Feb 10, 2012, 08:29 PM
gazzzz is offline
Find More Posts by gazzzz
Norway, Oslo
Joined Feb 2012
mike thecrash I'm glad you answer when I ask you something. you are a big help, so for me you are the man
gazzzz is offline Find More Posts by gazzzz
Old Feb 10, 2012, 09:16 PM
rsands2801 is offline
Find More Posts by rsands2801
Joined Dec 2007
second, service is something else when dealing with Mike(theCrash)
rsands2801 is offline Find More Posts by rsands2801
Old Feb 10, 2012, 10:47 PM
Moelich73 is offline
Find More Posts by Moelich73
Bazinga!
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
Originally Posted by Moelich73 View Post
Hi guys
I flew with my new DragonOSD for the first time this weekend and it went very well, there's just two
Problem 1:
I'm struggling with the AP setup, but will go through the thread again and search for setup tips. The problem with forum searches is that there's a little bit of info here and there, spread over many pages!
At this stage all the AP settings are at default, and when I activate AP the wing dives down and to the right. When I do a servo direction test, My pan servo (on rudder channel) goes nuts (jitters) and the one elevon seems to move, but nothing else.
Problem 2:
My other problem is I'm experiencing a buzzing noise on my audio channel. I'm not sure if it's related to my OSD wiring, or something else. I have it wired as follows:
Onboard microphone's signal wire goes to my Vtx, together with the audio out pin from the OSD. Is that correct?
When the onboard mic is connected, I can hear the motor running fine, but the buzzing noise is also there. With the audio variometer activated, I can hear it very faintly in the background if I turn the volume up, but the buzzing noise is also very loud then.
Another sound I can hear sometimes, is a different buzzing noise every 5 seconds. You can hear it towards the end of the video clip below.
Any advice would be much appreciated!
http://vimeo.com/36269100
Can someone perhaps help me with problem 2? Problem 1 is sorted now. Thanks!
Moelich73 is offline Find More Posts by Moelich73
Old Feb 10, 2012, 10:52 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Is the buzz there with no DOSD audio connected? That would at least point to a DOSD or non-DOSD issue. You can try putting a series resistor (~4.7k ohm) in the audio line to attenuate it. I had an issue with my GoPro where the audio line was really affecting the video signal....and the audio wasn't attached to the DOSD. After adding a resistor in the audio line my video problem was fixed...weird...I know, I was surprised too.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 11, 2012, 02:08 PM
Bazinga!
Moelich73's Avatar
Joined Feb 2007
Thanks for the advice. I unplugged the DOSD audio and the buzz is still there, so it seems to be something else than the OSD. Unfortunately the 4k7 resistor didn't make a difference. Seems like I'll have to dig deeper to find the problem.
Edit, 30 minutes later:
I made some progress! I replaced the video Tx with another (identical) one, and the buzzing is now only half as much. So it seems like the Vtx is a bit crappy on audio. I suspect the noise problem will be gone if I buy a better quality Vtx (these are both the 1.2GHz 800/500mW Vtx from RangeVideo).
Sorry, this is now off topic from the DragonOSD.
Old Feb 11, 2012, 05:33 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 11, 2012, 06:22 PM
Mehari is offline
Find More Posts by Mehari
Joined Aug 2008
I have searched for a while but can't find an answer to this one.
Anyone know if the GPS Logger from SM-Modellbau can be used as the GPS sensor with DOSD?
Specs are as follows:
GPS logger:
10Hz GPS, or 10 readings per second
Micro SD memory card
Data are stored in plain text on the card
Altimeter barometric sensor supported by additional
Full telemetry support for Jeti Duplex, Multiplex M-Link and Graupner HoTT, including barometric Vario
Direct connection of UniLog half possible for data recording and telemetry support
Recording of all data on the sensor bus multiplex in operation with M-Link
Recording of the receiver battery voltage
Powered by receiver battery
Internal backup battery (battery) for a quick start of the GPS
Thanks.
Mehari is offline Find More Posts by Mehari
Old Feb 12, 2012, 04:09 AM
SPG is online now
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
If I understand it right, the transmitter gain adustment adjusts up to what you have set in the DOSD menu....so you can decrease the gain, but not increase it to a greater value that what you have set in the menu.
Thanks Van', After a bit of testing It does seem to work that way.
...some flyers use the tilt channel indicator on the stability control channel to give a visual indication of how much stabilisation is being used
Good Idea. Will have to try that.
SPG is online now Find More Posts by SPG
Old Feb 12, 2012, 04:16 AM
undefined
Joined Jun 2008
Originally Posted by AussieHoppy View Post
hi folks
i've been using dlink on and off for a while but finally getting around to setting up a complete dragon kitted purpose built Bixler
Before i started on the complete wiring setup i tested the LM 1.2/500 which works no prob
I havent glued the fuse together yet, just finished soldering the wiring together with component placement, and have run into an issue when i powered up the DLink Rx & DOSD+V2 for the first time...
I made the control channel on a slider to make sure the first time i powered up i had access to the menu... when i turn the slider to no display the camera image is crystal clear... as soon as i turn the slider for either osd or menu, in other words pulling up any text, the screen is so distorted you cant read any text or image, just garbled... slider back to no display and perfect image again
i havent made the usb adapter yet, i'll make it tonight (about to go fpv'n for the day) and see if i can find something while accessing from my PC, but if anyone knows what might be causing this i'd much appreciate it
cheers
First off I would double check that you have got the video in and out pins the right way around on the DOSD
after that, it may be that the VTx is out of design spec. The common fixes for this are a 100 Ohm resistor either in series with the video signal or linking the signal to ground, or even both.
GPS logger:
Thanks.
Having looked at the unit translated by Google into English, my guess would be no. DOSD will automatically recognise the chip type and baud rate from MediaTek (MTK), Antaris (u-blox) and SkyTrax (Venus) if you can get raw data. I think you should check with the shop that sells the GPS if it can output NMEA sentences which I believe is what DOSD wants
Old Feb 12, 2012, 04:26 AM
Joined May 2010
ahah... and i thought i was past the challenges for this install lol
thanks ever so Mike, i'll let you know how i go
cheers!
Old Feb 12, 2012, 07:46 AM
pyrojets is offline
Find More Posts by pyrojets
Joined Apr 2011
My GPS can't seem to get a fix. It is connected correctly placed in the open space for more than half an hour( only DOSD is turned on and it is stationary) but still no fix. Flown it in my plane for about 10 mins or so but still no set. I have managed to get a fix once but it took it about 2 hours to get a fix. Is there a way to solve this problem or I just have to be patient?
pyrojets is offline Find More Posts by pyrojets
Old Feb 12, 2012, 09:03 AM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
Wrap the gps cable through a ferrite ring a few times. Also make sure the GPS cables are not crossing other cables. I was having horrible gps problems because the cable crossed over the throttle line from the ESC.
Tracks is offline Find More Posts by Tracks
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 09:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 12:56 PM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 06:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 01:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 06:13 AM
