Old Jan 11, 2012, 05:32 PM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Originally Posted by crazy1pilot View Post
when i plug everything in to the computer it recognizes it as com 5 and i click connect and it attempts to connect but then says connection failed. what am i doing wrong? i am powering it with a 3s in the power plug on the DOSD (not the CS).
Try reversing your TX and RX wires.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Jan 11, 2012, 05:41 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
spitfire_Doug
IT WORKED guzzes thank you guys!! i love RCG <3
crazy1pilot is offline Find More Posts by crazy1pilot
zkilzz is offline
Find More Posts by zkilzz
Joined Sep 2011
If i have the DL uhf rx and rssi hooked up. Will ap rth engage if the signal is 0%?
zkilzz is offline Find More Posts by zkilzz
Old Jan 11, 2012, 07:58 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yes IF you have the DL failsafe set right. You want to make sure you set the failsafe with the AP/RTH set and some throttle if you want to 'motor' back home vs trying to glide back home.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 11, 2012, 08:50 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Info on failsafe:
http://www.rcgroups.com/forums/showp...ostcount=14964
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Jan 12, 2012, 01:50 AM
flyboygaac is online now
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
Originally Posted by JMSTECH View Post
also like to add that these IMUs will soon be supported!
* CHR-UM6
* Sparkfun Razor 9DoF AHRS
* Mongoose IMU
John
Hi
I think you should include the CRIUS board in the support list because it has 10DOF, arduino, it has the same sensors has the others (and even more) and it's the cheapest.
In the code you just need to adapt the orientation of sensor and it's addresses. (and also I already have it form my MultiWii project )
It will also be nice if we could mix Multiwii code and DOSD code so that one only IMU could be used to control a leveled Quadcopter, heli plane or flying wing and also provide information for DOSD.
IF DOSD board could support all the processing we could just couple it with FreeIMU 0.4.1
http://www.varesano.net/topic/freeimu
flyboygaac is online now Find More Posts by flyboygaac
Old Jan 12, 2012, 08:30 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by flyboygaac View Post
Hi
I'm certainly not a programmer or an electronics design engineer. I would think, though, that making it so just about anything out there would be plug 'n play with the DOSD would consume huge amounts of (limited) memory. I'm not aware of other OSD systems that use a variety of sensors for the user to pick from. I'm willing to bet most are 'use just our sensors or use nothing'. Daniel keeps saying the DOSD was design just as an OSD system that has turned into a lot more. Perhpas a DOSD V3, 4, 5, etc will provide more and better options as things continue to develop.
Old Jan 12, 2012, 05:27 PM
Joined Sep 2009
I am trying to update my DOSD using the DragonOSD+ PC Commander version 2.11 but every time i click check for latest version it just says an error has occurred while performing a firmware check. please try again later.. i have tried over several days and it just keeps saying that. is there another way of updating the firmware? my dragon has firmware 11.2 and i would like to put the newest one on 17.2..
Crazy1
Old Jan 12, 2012, 08:17 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just go to the DragonLabs.net web site. You can find the lings to the firmware there.
http://www.dragonlabs.net/site/DragonOSDplus/downloads
Old Jan 12, 2012, 08:38 PM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
spitfire_Doug
Hey Im trying to do the same thing but about 2 steps behind you I think.
I have been looking at pages 76-81.
Tell me, that black FTDI cable on page 76 , is it just a USB cable or does it have a chip moulded into it?
I fly Mk multi's and have a MKUSB adaptor (serial adaptor and have tried that but connection fails).
weather is fining up so wanna get in the air for its maiden.
Troy
Imagecatcher is offline Find More Posts by Imagecatcher
Old Jan 12, 2012, 08:48 PM
Joined Sep 2009
Ive been there and downloaded the new Firmware but how to i go from "my computer" to the "DOSD"? like how to i get it to load onto the Dragon? thanks
EDIT:
I believe i figured it out. didn't realize there was a "Flash Device" instead of "Check for latest version"
Crazy1
Old Jan 12, 2012, 08:57 PM
Joined Sep 2009
Troy
this is the programmer i bought, it was only $3!! took a little while to arrive but cant complain to much. works perfect after i reversed the RX & TX wires.
also you wont need to modify anything with this USB connector, because it already comes with the individual wires to connect.
http://www.ebay.com/itm/ws/eBayISAPI...E:L:OU:US:1123
Crazy1
Old Jan 12, 2012, 09:14 PM
NSW Australia
Joined Mar 2010
Crazy1
DONE I have ordered one ...CHEAP!
BUT
Will my Mikrokopter USB serial adaptor do for now??? Any MK multirotor guys out there??
Thanks Crazy1
Old Jan 12, 2012, 09:27 PM
Joined Sep 2009
BUT
Thanks Crazy1
I do not think so but i am not 100% sure.. i just ordered a KK Board programmer because i am going to use a CHEAP HK KK board as a gyro stabilizer for my plane and try it out....
http://www.rcgroups.com/forums/showthread.php?t=1554249
maybe Vantasstic will know better as he seams to be the Customer Support for Dragon OSD
Old Jan 12, 2012, 09:34 PM
NSW Australia
Joined Mar 2010
I have the FY30A to stabilise...pretty good.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
