Thanks Daniel, That helps alot! ![]() I will see if I can find that HSCMRNN001PG2A3 sensor somewhere. (I had trouble trying to order from Farnell before). No problem about the cap, I understand decoupling capacitors and probably have something suitable in my stock. Hookup looks easy from the data sheet. I already have the BMP085 baro sensor and it seems to work great, and I have the pitot tube kit from DIYdrones as well. For the airspeed accuracy, just relative should be fine. Thanks again, I'll let you know how it goes. Dale Edit; I have the sensor HSCMRNN001PG2A3 coming from DigiKey for 53.17 shipped.
Joined Aug 2005
magnetman,
I'm looking at what you posted about your measurements, that you are seeing 8.7mV for 600mA idle current. That is incorrect. The sensitivity of this board is around 12.65mV per 22mA or 0.575mV per mA. By this calculation, 600mA should yield an output voltage of approximately 345mV, not 8.7mV. So something is definitely amiss here. Here is what I would check first - make sure that the following resistor has been removed as per the photo:- http://forum.tsebi.com/download/file.php?id=709 Let me know if that resistor is already removed on your board. Daniel |
magnetman... did you update the firmware of your OSD? And also I will have pcb's arriving in about a week from there on I begin assembling them. Send me your mailing address again to jmstech1@gmail.com, I let you try one out.... consider yourself as a beta tester for us.
![]() John |
hi daniel.. well upgraded firmware from 6.7 to latest 8.4..
i can toggle to the menu but cannot select to make the changes.. see vid..
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
