Old Jan 05, 2012, 09:46 AM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Originally Posted by Vantasstic View Post
That would be no problem The more solder/connection points you have the more line loss you'll have...but that'd probably not be noticeable.
Very good point and tweaking the values in the OSD menu will provide better accuracy to compensate for those kinds of things.
John
JMSTECH is offline Find More Posts by JMSTECH
Old Jan 05, 2012, 06:30 PM
pyrojets is offline
Find More Posts by pyrojets
Joined Apr 2011
Is there way to limit the rudder mixing with aileron? Have anyone tried mixing the pan with elevator and tilt with rudder? Cos when I turn on the mixing and move the elevator stick, autopilot will be activated, regardless of which mixing is activated.
pyrojets is offline Find More Posts by pyrojets
Old Jan 05, 2012, 10:05 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
No, mixing in AP is either on or off.
I've not tried that, but AP shouldn't engage with that mixing unless you have some channel bleed over that's getting into the AP channel. Try turning down your end points on those mixes/controls to see if that stops it from going into AP mode.
Vantasstic is offline Find More Posts by Vantasstic
Old Jan 05, 2012, 10:57 PM
pyrojets is offline
Joined Apr 2011
I see, so that means DOSD will know how much rudder input to use? Or it is getting information from the tx?
Ok. Will try that out.
Old Jan 06, 2012, 08:36 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
The DOSD only control aileron/rudder mix IF it is enabled AND only in AP mode. It mixes in a given percentage (sorry, I don't know what percent) and the amount of mix is not adjustable (in the current fw at least). I use it on my Skywalker and never felt it had two much rudder mix. It doesn't kick in a lot of rudder, just about enough to help with more coordinated type turns. I also have my Tx programmed for Aileron/Rudder mix for my normal flying.
Old Jan 06, 2012, 08:51 PM
pyrojets is offline
Joined Apr 2011
If the autopilot is turning in the wrong direction, is it advisable to change it while the plane is in the air or do I have to land it and change it on the ground?
Old Jan 06, 2012, 08:54 PM
navihawk is offline
Find More Posts by navihawk
United States, FL, Orlando
Joined Nov 2006
So with the board you dont need to use the angled pins you can just solder the servos connections to the board? like vantasstic did?http://www.rcgroups.com/forums/showp...ostcount=15082
And i dont need to make any adjustments like software, it comes ready to use?
navihawk is offline Find More Posts by navihawk
Old Jan 06, 2012, 09:56 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You could do it in the air. I'd HIGHLY recommend doing it on the ground though. It'd be a shame to have a plane go in while you try changing things around and something goes bad. Of course, doing the servo movement test on the ground should verify the AP movements will be in the correct direction.
Old Jan 06, 2012, 09:59 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Correct. If you install pins you'll need connectors on both ends of the harness. If you direct solder you only need the connector on the end that connects to the Rx and DOSD.
No menu setups needed. You just connect and go.
Old Jan 07, 2012, 02:30 AM
pyrojets is offline
Joined Apr 2011
Read the manual. Is it the servo direction test? The manual says that the aileron will "roll right" and the elevator will go up, then what about the rudder?
Old Jan 07, 2012, 03:24 AM
MikeTheCrash is offline
Find More Posts by MikeTheCrash
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
By servo movement test, you mean moving the stick on the tx or running with the plane and checking whether the control surfaces are moving in the correct direction?
There is a servo direction test the in the menu. In the manual, p.50
MikeTheCrash is offline Find More Posts by MikeTheCrash
Old Jan 07, 2012, 10:45 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
In the servo direction test you should get up elevator an up right aileron. If you have the Rudder mode set to either 1 or 2 it also will move. It should move to the right. If the aileron or elevator movement is wrong you need to change it in the menu...I think it's Rev AP Ail and Rev AP Ele or something like that. DO NOT reverse it from you TX as then in non-AP mode you're flight control surfaces will be reversed. If the rudder moves the wrong way just change the rudder mode for opposite movement and test again.
Oh, for flying wings the servo direction test should just get you up right aileron/elevon. The left surface doesn't move I believe.
If you get surface jiggling in the servo direction test, don't fret. This is pretty common and is often made worse by sub-trim offset, trim offset, reduced endpoints, etc. It doesn't jiggle like that in AP flight, only in the direction test.
Old Jan 08, 2012, 03:47 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hi folks, I am now on the market for a higher quality OSD with RTH.
I am tossing up between this one and the eagle tree systems one.
I don't want stabilization ect, I just want essential info and a good RTH system in case I have a video malfunction when away from LOS.
I have a budget in mind and it's about what the Dosd is worth.
Do I need any extra bits for what I want that aren't in the Dosd v2 combo with gps, current sensor and OSD?
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 08, 2012, 11:07 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Stabilization, RTH, and Waypoints can all be done with just the DOSD V2, GPS, and Current Sensor (not needed for AP use, but for power system monitoring). You MAY need one extra item based on the Rx you're using.
The DOSD uses a PPM signal for the Rx input. If your Rx isn't capable/bashable to get a PPM signal then you'll need a PPM encoder. These run ~$25 from DIYDrones and a little less from Foxtech (I believe). On one side of the encoder you'll connect your Rx signal outputs (up to 8 channels). It then puts these into channel order and output it as a PPM signla on a single 3-wire servo harness into the DOSD.
The other thing I HIGHLY recommend is a TTL-USB/FTDI device. This provides communications from the DOSD to your PC to setup, adjust, upload new firmware and waypoint missions, and download GPS track data files. The setup and configuration can be done via the DOSD menu, but its easier via the PC.
Old Jan 08, 2012, 11:28 AM
JMSTECH is offline
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Also if you like to save weight and space in your RC platform, might want to consider this... DragonOSD+ has only one printed circuit board, half the size and weight to most in it's class. I see the others still require double the components (maybe also double the printed circuit board) to achieve the same high resolution. But if you study the other systems then you probably already know this.
John
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
