You deserve #15,000 Van, you are the top support dude thank you very much from all of us, you help make Dragon community what it is |
Sao Paulo - Brazil
Joined Dec 2009
dgpilot, IŽll share what find out. My radio is normal and the dosd is doing the mix.
rsands2801, thanks for the input. I will have to check it very closely. I know that to have rth working, I must have servo test going to the expected side. Thanks guys. |
Australia, VIC, Melbourne
Joined Mar 2010
So generally you leave the aprotgain and aprocgain settings as default and mainly adjust the rocstepgain and rotstepgain settings?? |
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
You're plane should be more than stable enough. You shouldn't need much step gain for it. The fact you said it was bouncing back and forth and tried to flip over is exactly what to much step gain will do. |
Like Mike said...the PWM rail power should be coming from your 5v BEC/UBEC/flight pack. Most likely you've got the 5v line going to your Rx, then it's passed to the DOSD PWM pins via the PPM cable. As for the humming...probably just the servos hunting around center. If you get the UHF antenna to close to the Rx antenna you could 'swamp' the Rx and get some channel cross over which will cause servo jitters. Moving your Tx away from the Rx should fix that. There is normally some servo noise anyway.
| Thread Tools | |
| Discussion Dragon OSD | Level Flight | Video Piloting (FPV/RPV) | 20 | Apr 17, 2011 12:12 PM |
| For Sale New Intelligent Flight Dragon OSD | bfischer | Aircraft - Electric - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
| Discussion FS Ready to fly Intelligent Flight Dragon OSD | bfischer | Video Piloting (FPV/RPV) | 0 | Mar 03, 2010 05:57 AM |
| Discussion RV OSD or Dragon OSD | djdaveq | Video Piloting (FPV/RPV) | 1 | Feb 06, 2009 12:18 AM |
| Discussion RV OSD and Dragon OSD - so near to being Really good! | magnetman | Video Piloting (FPV/RPV) | 8 | Nov 11, 2008 05:13 AM |
