Old Mar 16, 2010, 08:30 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
An idea for a traveling 3D foamie and a general concept
So I was thinking, I do appreciate profiles for their ease in construction and versatility as well as performance but I'm still often a full fuse guy as well as the airfoil. So what if you built a full fuse (hollow inside) with foam, and then cut cores for the wing and the tail feather (yes a fully symmetrical stab).... Maybe this idea is already out there but it's sounding great to me.
The idea with the traveling part would be that the wings are in 2 halves, each has a built in servo and wires extending outside... then you could use two spars/tubes inside the wings which will slide into each other and a hole drilled through the middle (once the wings are joined) then you put a nylon screw there... well maybe that's too complex but yeah...
Any thoughts?
GreenAce92 is offline Find More Posts by GreenAce92
Old Mar 17, 2010, 07:39 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Any thoughts?
Check out the Carbon Traveler at, www.acesim.com/rc/ctc/#Kit. It is pretty cool and might be what would work for you. Read the thread linked at the web sight. It is worth reading.Watch the vids. You can also download this for your real flight 3.5 sim if you have it, you can find it at Knife Edge forums.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Help! 3D Foamie wieght?!? RCpilot71 3D Foamies 29 Mar 18, 2010 11:51 AM
Build Log 10 sheets of foam and an idea. A-10_Flyer Foamies (Scratchbuilt) 2 Mar 03, 2010 10:13 PM
Help! choosing motor for 3D foamie slo-stik 3D Foamies 2 Mar 01, 2010 10:58 PM
Discussion An idea/design for a vector thrust and aileron only pusher prop jet GreenAce92 Foamies (Scratchbuilt) 0 Feb 26, 2010 11:29 PM
Discussion I need an indoor 3D foamie for my 2S batteries. Any suggestions? racin06 3D Flying 2 Nov 22, 2008 08:32 PM
