Old Mar 16, 2010, 07:16 PM
bababooey1 is offline
Find More Posts by bababooey1
Joined Mar 2010
Any SR owners have blades that hit tail boom when landing?
THe second time its happened...coming down to land while i am giving a little rear stick and the blades catch the rear boom. I dont know whats going on but has anyone else experienced this?
bababooey1 is offline Find More Posts by bababooey1
Old Mar 16, 2010, 07:20 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You bet. This is common with this type of heli. Want to see my collection of Axe CP and Blade CPP aluminum tail booms? They all have the same diagonal dent in them.
Balr14 is offline Find More Posts by Balr14
Old Mar 16, 2010, 07:28 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
I am speaking from a new to heli mind but learning.
Do you think the damper's in the head could be soft for the newb and mabey a harder damper would help?
ridgewalker is offline Find More Posts by ridgewalker
Old Mar 16, 2010, 07:36 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Never land while moving backwards, sideways or forward. Get into a hover and lower heli slowly to the ground...
Is what I keep telling my self...
livonia bob is offline Find More Posts by livonia bob
Old Mar 17, 2010, 09:16 AM
JettaManDan is offline
Find More Posts by JettaManDan
Crazy Foamie Builder
JettaManDan's Avatar
United States, MD, Lexington Park
Joined Jan 2010
my friends SR just did this the other day....nice big dent and a cracked blade...
JettaManDan is offline Find More Posts by JettaManDan
Old Mar 17, 2010, 09:28 AM
Joined Mar 2010
So what other blades are compatible with the SR...any 245mm? Do the carbon fiber blades take light strikes better than the regular wood?
Old Mar 17, 2010, 10:21 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
CF blades are expensive and brittle. Wood absorbs impact much better. Odds are good CF blades will take out the boom and the blades. Plastic blades are the most durable, but they will wreck the tail boom.
Old Mar 17, 2010, 10:58 AM
sNstRflyEr4G3 is offline
Find More Posts by sNstRflyEr4G3
I NEED MORE FOAM...LOTS MORE
sNstRflyEr4G3's Avatar
United States, MA, Webster
Joined Mar 2009
Agreed, never try to land while moving backwards, even super slow.
sNstRflyEr4G3 is offline Find More Posts by sNstRflyEr4G3
Old Mar 17, 2010, 11:30 AM
Joined Mar 2010
Old Mar 17, 2010, 02:25 PM
Danoman812 is offline
Find More Posts by Danoman812
Huge field, little tree... WTH
Danoman812's Avatar
Anniston, Al.
Joined May 2009
I can say for certain... the CP Pro 2 and the King 3 blades won't work together. I'd thought of taking my extra set of King 3 blades and sanding them down the the CP Pro 2 size but, the blade holders on the King 3 are thicker. I could 'work' them down but, nah... I'll just buy new ones. Although, Givin' that the King 3 chord is about 5mm thinner...
Hmmmmmmm. That could be interesting. It looks that they appear to be the same depth as far as being semetrical. may be worth it after all... (I have two extra sets of those thanks to that head explosion and it's collecting dust waitin' on parts... hehehe)
Oops... went off topic. Sorry guys.
Danoman812 is offline Find More Posts by Danoman812
Last edited by Danoman812; Mar 17, 2010 at 02:26 PM. Reason: I got stupid and went WAY off topic... Game back on...!!!
Old Mar 21, 2010, 09:32 AM
jfmsam is offline
Find More Posts by jfmsam
South Florida
Joined Mar 2010
Happens to me when I was landing too hard in my initial flights.
Now with a little more experience I'm no longer striking the tail, nor am I landing it as hard as before.
I also tightened the blade holders a bit more. They are short of being stiff, so they still straighten out upon spin up. I don't know if this contributed so as not to strike the tail but it is definitely a coincidence that I haven't hit my tail in a while.
jfmsam is offline Find More Posts by jfmsam
Old Mar 21, 2010, 06:23 PM
SeaDog-Chief is offline
Find More Posts by SeaDog-Chief
Joined Oct 2008
Had to replace my feathering shaft after a boom strike and found that the dampers were soft like sponge foamies and not hard like O rings are supposed to be. My experienced heli friend flew it the first flight and told me they were worn out before it had ever been flown.
SeaDog-Chief is offline Find More Posts by SeaDog-Chief
Old Mar 23, 2010, 12:41 PM
fr0g is offline
Find More Posts by fr0g
Joined Mar 2007
This happened to me as well. At first I just thought blades caught the ground. I noticed that a blade grip busted off from the control arm and thought that was it. Then I noticed a dent in the tail boom and realized what happened. Apparently this is common if you land too hard. Anyway, now I need to replace the tail boom. Is it possible to pull the wires through without de-soldering them from the tail motor? Can the plug be pulled through the tail from the other end? I'm a newb at soldering and don't want to screw it up.
fr0g is offline Find More Posts by fr0g
Old Mar 23, 2010, 01:01 PM
Danoman812's Avatar
Anniston, Al.
Joined May 2009
I'm takin' that last comment of mine back. It took a little modding but, they work great after I shaved some of the length off and sealed the ends of the rotors. They work really good in fact. Just got in from it's test flight. These blades are a little thinner in the Chord than the original CPP2 blades... just updating my comment from earlier. Ok, back out and gettin' back on topic... hehehe.
Discussion Boomtown, Vigilante, or Xtreme Tail Boom? (Pics if you have them) Zags Coaxial Helicopters 21 Sep 22, 2009 01:44 PM
Sold LMH Corona Parts M&T blades, tail boom, landing gear, mainshafts, z links jettvolks Aircraft - Electric - Helis (FS/W) 4 Aug 21, 2008 08:00 AM
Question Any Update on when Twister might hit US Shores? Bajora Hitec/Multiplex USA 3 Jul 10, 2007 01:03 PM
Sold Logo 10 OWNERS >>> 500mm Carbon main blades, 3D paddles, tail blades kookboy Aircraft - Electric - Helis (FS/W) 2 Feb 12, 2007 09:17 AM
Anyone have a hornet tail boom or any other spare parts? JStory Aircraft - Electric - Airplanes (FS/W) 3 Oct 31, 2001 12:20 AM
