Old Mar 15, 2010, 11:00 PM
Habanero is offline
Find More Posts by Habanero
Habanero's Avatar
United States, CA, Milpitas
Joined Jul 2008
Build Log
Dumas 19' Racing Runabout **Bash Job**
OK pics start here at FIG. 8 dont ask.
First problem was I could not get the chine to stick to frame 1. I let it cure an inordinate amount of time but the epoxy just would not set -maybe I mixed it wrong or it was too cool- but it would always pop out so I CA'd it in place.
Also I somehow missed step 1 & put the frame together without the steering column support but I later managed to place it ok. I think.
Habanero is offline Find More Posts by Habanero
Old Mar 16, 2010, 12:00 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Great to see you starting on another boat, Habanero!
Aerominded is offline Find More Posts by Aerominded
Old Mar 17, 2010, 07:24 PM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Actually started it 7 months ago with a pause that's why I dont have earlier pics lost the file somewhere.
Here with the bottom planks put on... I must not have sanded the front keel area enough because there is a gap in the middle hope it does not affect anything later.
I shaved the edges of the planks with an exacto as closely as I could to save sanding time with that step.
Third pic is the aforementioned steering support column I almost forgot.
Old Mar 17, 2010, 09:31 PM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Man I guess my first Midwest build spoiled me but I am having a really hard time following these diagrams- takes a long time for me to figure out what part of the boat I am looking at/from what angle.
Latest blog entry: Phoenix Mosquito
Old Mar 18, 2010, 11:57 AM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Rear side planks installed. Once again I have gaps between the plastic sheets- they were too stiff to fold around the bottom edge. I guess I will have to mix up some microbaloons and fill the gaps.
Old Mar 18, 2010, 12:03 PM
RussCA is offline
Find More Posts by RussCA
RussCA's Avatar
Petaluma, CA
Joined Jul 2008
Looking really good so far, my runabout is up to the stage of staining and glassing, you have a great part coming up, the mahogany planking, i really enjopyed the deck planking with the white styrene strips, look wonderful when it's done.
I too had a fair few gaps in the styrene subplanking, after filling it with auto bondo it looked just fine.
Keep up the good work
RussCA is offline Find More Posts by RussCA
Old Mar 18, 2010, 12:21 PM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Ah yes I forgot it will be glassed down there so epoxy would just be messy and more than necessary OK bondo it is- recommend any specific type/ brand?
Old Mar 18, 2010, 12:38 PM
RussCA is offline
RussCA's Avatar
Petaluma, CA
Joined Jul 2008
I think the instructions state not to glass the bottom, but many people have... As far as bondo goes i have just used "Evercoat Rage" in the past, only because i had some on the shelf, they also have lightweight bondo but have never used it.
Old Mar 18, 2010, 04:34 PM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Front side planks put on. Instructions say the gaps in the side wont matter since they will be planked over. The overlap was so severe I took my dremel out for the first time and -wow did it save me time- I was estatic until whoops gotta go back and repair THAT now.
I have seen someone use bondo to shape the bow instead of balsa blocks having never worked with bondo Im leaning towards following the instructions.
Maybe with bondo you get more chances to get it right
Old Mar 18, 2010, 04:46 PM
Joined Feb 2004
stick with the balsa blocks per the instruction... it would take a ton of bondo (which will crack) to make that bow piece.
Old Mar 18, 2010, 05:17 PM
Habanero is offline
Habanero's Avatar
Joined Jul 2008
Yes thanks I just found they call for both balsa block THEN bondo. hadnt read that far in the instructions. Off to the hardware store need more sandpaper anyway.
Old Mar 18, 2010, 07:16 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
I've been using Evercoat Polyester Glazing Putty on a styrene build and couldn't be happier.
woodybob is offline Find More Posts by woodybob
Old Mar 18, 2010, 10:30 PM
Joined Feb 2004
Originally Posted by woodybob View Post
...and couldn't be happier.
+1
That's the stuff I use!
Old Mar 19, 2010, 01:09 AM
mr_impervious is offline
Find More Posts by mr_impervious
mr_impervious's Avatar
Detroit Metro, MI, USA
Joined Dec 2007
Where do you get it? Thanks!
mr_impervious is offline Find More Posts by mr_impervious
Old Mar 19, 2010, 08:50 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Auto paint supply.
Dumas 19' Racing Runabout P. Tritle Scale Boats 54 Jan 26, 2016 02:25 PM
Sold 1952 19' Chris Craft racing runabout vett Boats (FS/W) 1 Jan 17, 2010 10:30 AM
For Sale Dumas Chris-Craft 1949 19' Racing Runabout Kit #1249 NIB Thread Closed... jbj620 Boats (FS/W) 1 Jun 11, 2009 10:31 PM
Build Log A beginners build of the Dumas 19' Racing Runabout -=Odie=- Scale Boats 32 Nov 20, 2006 04:36 PM
Dumas 19' Racing Runabout, bow section dmb Scale Boats 5 May 22, 2005 11:40 AM
