Old Mar 15, 2010, 11:18 PM
Rctestflight is offline
Find More Posts by Rctestflight
Rctestflight's Avatar
United States, UT, Park City
Joined Sep 2009
Smallest 4 stroke gas engine
Does anyone know what the smallest 4 stroke gas engine is called?
Thanks, Dan
Rctestflight is offline Find More Posts by Rctestflight
Old Mar 16, 2010, 02:08 AM
b7gwap is offline
Find More Posts by b7gwap
It's Prime Time for Slime Time
b7gwap's Avatar
Joined May 2004
You talking petrol, gasoline, benzine, ignition-fired engines? There aren't many four strokers in that category. Fuji imvac makes a few, but they aren't cheap and they aren't small. Saito makes the FG 14, which is their FA82B but set up for gas and ignition with a pumper carb.
b7gwap is offline Find More Posts by b7gwap
Old Mar 16, 2010, 05:52 AM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
The smallest gasoline powered commercial four-stroke is the Saito FG-14, .82cu.i size.
Patxipt is offline Find More Posts by Patxipt
Old Mar 16, 2010, 07:10 AM
Gluehand is offline
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Now this is a small engine....how about a 1cc 4-stroke...?...and a diesel at that.....
Diesel Model Engine 1ccm Four Stroke (1 min 20 sec)
Gluehand is offline Find More Posts by Gluehand
Old Mar 16, 2010, 07:29 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The HP VT21glow engine is a pretty small 4 cycle engine. .21 cubic inch displacement.
MECOA still sells them. http://www.mecoa.com/hp/vt/21.htm
Saito's first 4 cycle engine was around a .20 cubic inch displacement too, but Saito hasn't made it for many years now.
The current crop of mass produced small 4 cycle engines displace around .36 cubic inches and are made by Magnum, OS and Saito as well as the batches that Mecoa turns out in the Hp VT 21 and VT 25 engine sizes.
earlwb is offline Find More Posts by earlwb
Old Mar 16, 2010, 08:37 AM
Joined Sep 2009
How about a 2 stroke? The reason I want a gas engine is because I live 80 miles from the closest hobby shop so its hard to get nitro fuel.
Old Mar 16, 2010, 09:06 AM
Patxipt is offline
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
RCGF 15cc is the smallest gas 2 stroke
http://www.modelrcplanes.com/product..._rcgf-15cc.php
There's also the SV-17 at 17cc, but it's heavy, over 1Kg with cdi and silencer.
Old Mar 16, 2010, 01:51 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You could convert any number of weedeater, leaf blower or chainsaw engines over to RC use. if you have a lathe and or drill press you can make your own conversion parts too.
http://wackerengines.com/
But usually the weedeaters and blowers are around 24cc, 25cc or 26cc or 32cc in displacement though. But I simply go around the neighborhood and find them laying about on garbage day, so i get them free. The engines almost always work, it is the pole or something else as to why the owner is discarding them.
now one other possibility, is to convert a glow engine to spark ignition and gasoline. You have to run a higher oil content in the gasoline oil mixture as the connecting rod on the glow engines doesn't have needle bearings in it. You also have a power loss after the conversion, but other than compensating for that with a larger engine, it isn't a big deal. The early model airplanes engines were all gasoline spark igniton engines before there were glow plugs.
Here is one source for 1/4x32 spark plugs, and ignition models. http://www.prcmodel.com/modeng/name/...ore/category/7
There are many more out there.
The smallest mass produced 4 cycle gasoline spark igniton engine is the SAITO FG14, which is a 14cc displacement engine, which is similar to running a glow Saito Fa72 engine, so it should work OK for the larger 40-50 size model planes: http://www.horizonhobby.com/Products...rodID=SAIEG14B
Old Mar 16, 2010, 02:06 PM
Jim Kraft is offline
Find More Posts by Jim Kraft
Jim Kraft's Avatar
The middle of Kansas
Joined Jan 2005
About any engine can be converted to gas and spark ignition. I have seen cox .049's converted to gas. Back in the 40,s before the glow plug came out, everything was gas.
Jim Kraft is offline Find More Posts by Jim Kraft
Old Mar 16, 2010, 09:29 PM
rodneygt is offline
Find More Posts by rodneygt
Registered User Wannabe
rodneygt's Avatar
Southwest Mississippi, USA
I can't find the price on that site. . . probably staring me in the face.
Has anyone ever seen one in use.
rodneygt is offline Find More Posts by rodneygt
Old Mar 16, 2010, 09:50 PM
lfishel is offline
Find More Posts by lfishel
Joined Mar 2010
If you're flying planes, I assume you will be going to the hobby shop occasionally right? You're allowed to buy more than one gallon of fuel at a time...
lfishel is offline Find More Posts by lfishel
Old Mar 16, 2010, 10:02 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Look for the price list and availability page. MECOA puts a link to it on each engine page.
Old Mar 17, 2010, 06:53 PM
Fylingdales Flyer is offline
Find More Posts by Fylingdales Flyer
Fylingdales Flyer's Avatar
Yorkshire Coast. United kingdom
Joined Apr 2008
Yes, I re-engined my KK Junior 60 (60"wingspan vintage) with an HP21VT. It flies beautifully.
The HP 21VT was the smallest production 4 stroke, it is of slightly smaller capacity than the OS20 FS.
Mine is the Austrian made version, but I believe it is virtually identical to the Mecoa version. It is very quiet, almost like an electric model in flight.
Many people believe they are lacking in power, but mine flies my Junior 60 as well as the SC30 (same as ASP or Magnum) commonly used in the same aeroplane by my cubmates.
Search my other posts for photographs of them model with the HP21VT installed.
Graham
Fylingdales Flyer is offline Find More Posts by Fylingdales Flyer
Old Mar 18, 2010, 01:27 PM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
No one has to go to the hobbyshop any longer. At least not anyone living in the United States. Any and everything can be purchased online or via mail order.
I stopped going to hobbyshops years ago, after I discovered that my inventory was usually better than theirs and that quite often I knew much more about the hobby than some little Hitler behind the counter.
I'm an old geezer and my latter years hobbyshop experiences were negative, as you can tell.
However, when I was just a young teenager, I used to spend weekends with a family that owned a hobbyshop. Their only son was one of my best friends in those days. Then there was his slightly older blonde and buxom sister - Carolyn. Ah, Carolyn - those beautiful blue eyes, the golden curly locks of hair, the super fine as- whoops! Can't go there from here.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Old Mar 18, 2010, 07:32 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
The problem with buying fuel online is that if you buy gallons, you pay $20 per case (4 gallons) HazMat fee on top of the price of the fuel and the shipping.
Or you can buy LOTS of quarts.
Pinecone is offline Find More Posts by Pinecone
Sold New Magnum 4 Stroke XL70 RFS Engine $110 cbcalhoun Aircraft - Fuel - Engines and Accessories (FS/W) 17 Mar 25, 2010 12:54 PM
Off Site Saito 100 4 Stroke Aircraft Engine FA-100 moxjett Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 03, 2010 08:44 PM
Off Site Saito 82 4 Stroke Aircraft Engine FA-82a moxjett Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 03, 2010 08:43 PM
Discussion warbird engine 2 stroke gas vs 4 stroke glow YEEOOWZAA Engines 8 Sep 29, 2008 11:59 AM
Discussion Advice on engine 4/2 stroke or Gas ?` avf Engines 12 Dec 05, 2006 11:21 PM
