Old Apr 04, 2011, 02:09 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Good to see a more progress on your malibu.
As for the Corvette boat, it seems like it falls a bit short.
If they could capture a bit more body style rather than a few
accessories on the exterior, it might start to look good...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Apr 04, 2011, 05:54 PM
xx29l9 is offline
Find More Posts by xx29l9
Mopar Musclecar fanatic
xx29l9's Avatar
Oregon
Joined Oct 2008
Nice work on the Photoshop Umi! I like your newer version better. Now you just need to make it affordable.
xx29l9 is offline Find More Posts by xx29l9
Old Apr 05, 2011, 01:04 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Lower stern piece glued on-
After some shaping, broke out the glue and stuck the lower stern section on. All went well. Still needs final shaping on outer edges to match up with pieces that will run from stern to bow.
Old Apr 05, 2011, 07:38 PM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
This thread added to WOODIES: Wooden Pleasure Craft Build Logs listing.
Path: RCGroups -> Boats -> Scale Boats ->"WOODIES..."
Looking real sweet...
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Apr 05, 2011, 10:28 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Holy Cow...now the pressure is on to keep this build actually moving forward! Thanks Craig!
Old Apr 06, 2011, 09:46 PM
Tollytime is online now
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
Less talk, more work, keep it moving please!
Tollytime is online now Find More Posts by Tollytime
Old Apr 06, 2011, 10:28 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Aye!
Old Apr 21, 2011, 12:24 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Looking ahead for power-
Looking ahead to what will power this thing...I have never used a brushless motor setup before and am thinking of trying it out here....anybody ever use this combo?
Traxxas Velineon Waterproof Brushless System
http://www3.towerhobbies.com/cgi-bin...&I=LXXWM5&P=ML
Comments- good/bad/indifferent?
Other combos you like better? I've had good luck with Novak products in the past and they seem to have quite a selection of brushless motor/esc combo's.
I'm not looking to set speed records with this boat. But I am a firm believer in having too much power is never a bad thing. Always easier/cheaper to slow something down than it is to speed it up. I will start with a Raboesch 4 blade prop with a 1.5:1 gear reduction. If the prop can't handle it, I will look more towards an Octura performance prop.
I'm thinking I will also end up going with LiPo's due to space constraints. Also something new for me. I would like to welcome me to 2011.
Bob
Old Apr 21, 2011, 09:17 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Caveat, I don't like car ESC's, and its a lot more than you need to spend IMHO.
The motor Kv is way too high for a direct drive 40 mm prop (saw the prop in your earlier post) on 2 cell Li-po something around the 2000 Kv and 3 cell no more than 1300 Kv, this will give about 14000 RPM, for a more conservative setup, aim for around 10-11000 RPM
Probably dont need reverse , so a air esc in the 60 amp range (especially for 2 cell) 3 cell a 40 would probably cover it, and a 28 or 36 mm out-runner or 540X or XL style in-runner
To make the ESC waterproof some non acidic cure silicone into each end of the heat shrink will seal it up.
2S
http://www.hobbyking.com/hobbyking/s...idProduct=6526
or
http://www.hobbyking.com/hobbyking/s...idProduct=3885
3S
http://www.hobbyking.com/hobbyking/s...idProduct=6525
or
http://www.hobbyking.com/hobbyking/s...idProduct=3887
Nice ESC I have used (until it went to Davy Jones locker)
http://www.hobbyking.com/hobbyking/s...idProduct=2166
Just as some examples for you
Cheers
Nick
nick_75au is online now Find More Posts by nick_75au
Old Apr 21, 2011, 10:54 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
2S
or
3S
or
Cheers
Nick
Hey Nick-
Thanks for the good info...but I do need reverse...the 1:1 boat has it, so the model will to. I plan on building 2 gear reductions, one will be 1.5:1 and the other 2:1. Depending on the motor and prop I end up with I can swap out the gear reduction units for better performance.
Enjoy the onslaught of winter it has been a long cold one here....
Bob
Old Apr 21, 2011, 11:05 PM
nick_75au's Avatar
Joined Mar 2007
Thats cool, , they do cheap car controllers as well with reverse, I have two 30 amp ones so far they have been really good. Only reason I thought reverse not required is the fact that my ski boat model swamps its a** if I use reverse I ended up disabling the reverse, the option is there to enable a percentage of reverse though.
The system you linked to will be fine with the ratios you state
Winters in my part of the world are great, usually clear skys, temps around 20-25 degs C but chilly nights, some years we might get a frost
Cheers
Nick
Old Apr 21, 2011, 11:17 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Cheers
Nick
Yup, biggest problem with the 1:1 boat is if you drop a boarder and slow down and turn straight into your wake too fast you will bury the bow and take the wave over the bow (chili dip). Not cool.
"Some years we might get a frost". Lucky, the calender says we are supposed to be well past freezing temps, but I just saw they are predicting a frost tonight. Ugh.
Old Jun 29, 2011, 11:08 PM
craig_c is offline
craig_c's Avatar
Joined Apr 2007
So Bob,
How is the WakeSetter project coming??
Old Jun 30, 2011, 10:48 AM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
So Bob,
Wellllll, slow would be over exaggerating. What little hobby time I've had lately has been put to finishing my late Christmas presents. What started out as me building 1 simple cartoonish model of my brother-in-laws charter boat to use as a Christmas ornament took on a whole new life. Right now it stands at 5 boats with a lot more detail than I thought I would put into them. That is so typical of my projects...I need to learn to say enough and be done instead of "well wouldn't it be cool to add just one more thing...". Oh well, they have turned out much better than I was hoping for.Besides the original yellow boat, my brother-in-law bought into an ownership on another boat, so of course I had to make that one too. The other owner is one of the old time skippers in the area and his health is not good, so I'm doing my best to finish this up as quick as I can. Anyway, these little guys are almost done, then it will be on to the Malibu...and the radio... and the charter boat refurb...etc...
Bob
Old Jun 30, 2011, 10:55 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
The detours is what makes the life worth living
Robert
Sharky1dk is offline Find More Posts by Sharky1dk
Cool scratch build learjet 55 DanielMadrigal Pusher Prop Jet Models 70 Mar 24, 2015 08:39 PM
Build Log Mosquito "Scratch" Build from Gus Morfis Plans Blue Falcon Fuel Warbirds 16 May 24, 2010 07:48 AM
Build Log Hack & Slash Scratch Build... Advice Welcome. Thepasty Slope 104 Apr 23, 2010 01:26 PM
Build Log Dornier DO-23 scratch build Pat Lynch Scale Kit/Scratch Built 95 Jan 12, 2007 05:41 PM
