Old Nov 26, 2012, 12:24 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Perhaps you'll want to duct the air "down" from the vents to the motor.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Nov 26, 2012, 01:00 PM
xx29l9 is offline
Find More Posts by xx29l9
Mopar Musclecar fanatic
xx29l9's Avatar
Oregon
Joined Oct 2008
Well...I haven't picked out the amp yet for the stereo, but I'm sure a little fresh air for that can never hurt.
xx29l9 is offline Find More Posts by xx29l9
Old Dec 10, 2012, 11:55 AM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Progress is progress, right?
Some progress made, even it it is only a little. Started to form what will be the bracing for the back of the seats in the bow area. Also looking at possible carpet material since I will need to glue some up the inside walls of the hull. Found some cheap grey velvet looking material at the fabric store. Looks pretty good in the model.
Bob
Old Dec 10, 2012, 01:22 PM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
This build is getting more complex than an F-22 Raptor. But I love it!!
Tollytime is offline Find More Posts by Tollytime
Old Dec 10, 2012, 06:35 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Hi Tollytime....agreed. I may have a problem, I can't stop the insanity. Just wait till I start building the tower for this thing. It's going to be epic. I hope.
Bob
Old Jan 02, 2013, 06:04 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Doing battle with the chicken vs. egg thing-
Seems you always reach a point (or several) during a build where you really need to glue something down in order to move on, but it would make some things down the road so much easier if you didn't glue it. Hmmm. I would really like to glue the pieces on in the bow to finish that up so I can continue with epoxy covering and eventually paint. But wiring for the lights and stereo would be soooo much easier if those pieces weren't glued in. I will make an executive decision and glue the pieces in next and just have to work the wires around later.
Bought myself a late birthday present. After much discussion with nick_75au about brushless motors, I bought an E-flite Power 10 motor. 1100kv, 375 watts. Will run it on 3s lipos. Thanks for the input Nick!
Also to help finish up the bow area before gluing those side pieces on, I drilled the bow for the front navigation light. I can tell already that this will be a pain in the rear to build, the 1:1 boat has a flip up nav light, think of rotating headlights on a corvette. Oh well, worry about that when I get there. Also drilled holes in bow sides for the speakers that will go up there. And found better material for the carpet, much better color match and texture is closer to the 1:1 boat.
Old Jan 02, 2013, 09:32 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
With all those speakers, where are you mounting the mp3 player?
Old Jan 03, 2013, 06:27 AM
pops52 is offline
Find More Posts by pops52
pops52's Avatar
United States, OH, Richfield
Joined Aug 2007
Might I ask where you obtained the speakers?
pops52 is offline Find More Posts by pops52
Old Jan 03, 2013, 07:32 AM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
WHY NOT PUT A CONDUIT IN? PULL YOUR WIRES ANYTIME.
http://www.rcgroups.com/forums/showt...643045&page=51
ALSO THINK ABOUT MAINT./CHANGE LATER
oldbilgewater is offline Find More Posts by oldbilgewater
Old Jan 03, 2013, 12:24 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
Speakers will all be mounted in the same spots as the 1:1 boat. Amp will go in storage area under left side of front window, just like the 1:1's 3 amps. Funny how those things work out. I have one of the older 4GB ipods that is really small that will also go in the amp area. Haven't settled on an amp yet, but here are two possibilities-
http://www.kemo-electronic.de/en/Lig...-universal.php
And a stereo version-
http://www.parts-express.com/pe/show...number=320-556
The speakers- After much (probably too much) miniature speaker research I settled on speakers made by CUI Inc, which just happens to be up the road in Tualitan from me. You can see all their specs here-
http://www.cui.com/Catalog/Components/Speakers
Only issue is they want to sell you several thousand units. So I found that Digikey carried the ones I was looking for-
http://www.digikey.com/product-searc...peakers/720966
OBW- I thought about running some tubes for the wires...but the speakers are going to require a fairly complex combination of parallel/series wiring and I haven't figured all the layout yet. Add in lights and stuff, going to get complex and not sure where I will have to cut into the tubes to tie things together....we'll see.
bob
Old Jan 03, 2013, 03:13 PM
pops52 is offline
pops52's Avatar
Joined Aug 2007
Thanks for the info xx2919. I (and likely others) would like to learn what your feelings are with the amplification and sounds from the speakers when you have them up and running.
Old Jan 03, 2013, 03:49 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
I'm curious about how it will sound too. Sound reproduction is always really limited by the small size of these speakers, so while I may not get glorious 8-Track quadrophonic sound, I am mainly doing this for the uniqueness of the project. If you can tell what song is actually playing through all 10 speakers and the giant 1" subwoofer I will call that a major success. Back to my build philosophy, "if it's on the 1:1 boat, it needs to be on the model".
Bob
Old Jan 04, 2013, 09:36 AM
Guard-Officer is offline
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Nice, a pumpin stereo to go with it! Looks great so far!
Guard-Officer is offline Find More Posts by Guard-Officer
Old Jan 04, 2013, 12:02 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
It'll thump as much as it can using about 3.5 watts.
Old Jan 08, 2013, 01:39 PM
xx29l9 is offline
xx29l9's Avatar
Oregon
Joined Oct 2008
More work on bow seating area-
After executive decision was made to go ahead and continue bow details, I went ahead and glued carpet on the inside of the hull, glued the sides on and rear for cushion mounting area. I then took some 1/64" thick wood and shaped a piece I could bend sharply into the corners. Seemed to work out well. I then added a piece to the front of the area to finish off all the major sides in the bow. Still need a little more sanding and smoothing, but I think it is a good start. Luckily the holes I drilled in the bow allow me to still snake some wires throughout the area.
When I was looking over the almost completed area above....The skinny section that runs between the front windows appears to be too long. Looked at some pictures and broke out the measuring tape on the 1:1 boat. Sure enough, I will need to cut and shape that area about 3/4" shorter than it is now. I thought about leaving at is for a moment...but it would end up bugging me too much. Easier to fix it now than later.
Bob
Cool scratch build learjet 55 DanielMadrigal Pusher Prop Jet Models 70 Mar 24, 2015 08:39 PM
Build Log Mosquito "Scratch" Build from Gus Morfis Plans Blue Falcon Fuel Warbirds 16 May 24, 2010 07:48 AM
Build Log Hack & Slash Scratch Build... Advice Welcome. Thepasty Slope 104 Apr 23, 2010 01:26 PM
Build Log Dornier DO-23 scratch build Pat Lynch Scale Kit/Scratch Built 95 Jan 12, 2007 05:41 PM
