Old Mar 15, 2010, 02:08 PM
eJets is offline
Find More Posts by eJets
electric power,what else!
eJets's Avatar
Joined Dec 2005
Question
TF8000 Bench Test Data?
Hi,
I would like to integrate the TF8000 in my Fan Calculator (http://www.s4a.ch/eflight/fancalc_e.htm). for that I need your help:
Who is currently running a TF8000?
I am interested in your data regarding:
- Setup used (Motor, ESC, Battery)
- Datas evaluated on the bench or in the airplane?
- max. Current
- Voltage
- resulting (static) Thrust
- if available Efflux
- if evaluated in the airplane: Exhaust pipe diameter/area
- approx. elevation above sea level and temperature at evaluation
thanks for your help!
eJets
eJets is offline Find More Posts by eJets
Old Mar 15, 2010, 02:13 PM
dkaj is offline
Find More Posts by dkaj
Arvid Jensen
Joined Jun 2007
Get in touch with, J Rehm Germany
Arvid EDF DK
Member of www.electricjets.dk
dkaj is offline Find More Posts by dkaj
Old Mar 15, 2010, 02:43 PM
eJets is offline
eJets's Avatar
Joined Dec 2005
...I am already - but need more than one setup for integration
cheers eJet
Old Mar 16, 2010, 02:10 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Hi Markus,
have you already talked to Ueli Amacker or the Hotz brothers!?
They are using the NEU motor perhaps they have some datas for you.
reg Martin
MaHö is offline Find More Posts by MaHö
Old Mar 16, 2010, 09:26 AM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
http://www.rcgroups.com/forums/showthread.php?t=1162382
I did this modification. The problem is I never got to fully test it before it was returned to the customer.
It showed great promise.
Clay
racer1 is offline Find More Posts by racer1
Old Mar 17, 2010, 05:59 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
I'm subscibed and watching with interest. I have one of these fans and am also curious what direction to go with regards to the rest of the power train.
strictlyscale is offline Find More Posts by strictlyscale
Old Mar 17, 2010, 06:22 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Ejets your fan calculator is a godsend. I use it daily(seriously).
That being said, I've found the ds-30 model to underrate by a few amps and watts when using higher powered setups. In some cases as much as 15amps and 3-400watts. I can provide limited data on running the ds-30 to around 3000-3500 watts if you would like to increase accuracy.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Mar 22, 2010, 05:31 PM
eJets is offline
eJets's Avatar
Joined Dec 2005
...so got 2 mesurements from Amacker/Hotz - thanks MaHö ;-)
some more bench tests? we almost there....
Data Motor Data - test bench data for several hundred brushless motors. Dr Kiwi Power Systems 850 Feb 08, 2016 08:02 PM
Discussion Bench Test of APC E-props (11x5 to 15x6), Watts, Torque, Thrust Wise_Man Power Systems 46 Apr 14, 2014 06:46 AM
Discussion Scorpion 2208-34 bench test for Multiplex Merlin tdriedger Power Systems 11 Jan 30, 2010 11:11 PM
Discussion How to bench test correctly clintski Power Systems 1 Sep 27, 2009 05:48 AM
