Old Jun 24, 2010, 11:54 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Infante View Post
only got the info of the wattmeter:
1098W
72Amps
16,50v
I can tel you that it flyes very fast an also light setup.
is faster than the funjet ultra with the multiplex propulsion kit.
Well, considering you run 1100W rather than 700W (recommended FJ ULTRA setup) you should be faster, otherwise 400W waisted in heat losses would melt your model.
The question is: How efficient is your setup compared to the recommended setup? Do you have noticeably better performance, or is there only a marginal difference and the added power is just mostly waisted in heat losses in battery, ESC and motor?
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 25, 2010, 06:08 AM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
Like anything you want to make go faster its a law of ever diminishing returns. IE it takes more and more input to get smaller and smaller increments of improvement. See drag racing, F1, WRC and funjets...
Jürgen
flyingrally is offline Find More Posts by flyingrally
Old Jun 25, 2010, 01:32 PM
Infante is offline
Find More Posts by Infante
Infante's Avatar
Portugal, Lisboa, Sintra
Joined Feb 2010
Jürgen
i can tell you that mysetup copared with the multiplex, is faster and consumes less amps. we made the experience with the watmeter and the multiplex setup only with 3s the reading was 75amps and 703Watts with the same prop.My reading was 950w and 64 amps with 3s.
Wen i fly with a friend, is very easy to notice the diference of speed in full trothle passes with the same batterys.
Infante is offline Find More Posts by Infante
Old Jun 25, 2010, 02:36 PM
Joined Sep 2000
In order to achieve 950W with just 64A requires a voltage of 14.844V under load. That's impossible with a 3s Lipo.
Jürgen
Old Jun 27, 2010, 10:23 AM
codys is offline
Find More Posts by codys
codys's Avatar
United States, TX, Sugar Land
Joined Sep 2008
I think he meant a 4s Lipo!!!!!!!
codys is offline Find More Posts by codys
Old Jun 27, 2010, 11:47 AM
Joined Sep 2000
With 4s he claimed 1100W, so something's a miss here.
Jürgen
Old Jun 28, 2010, 12:43 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
How much faster can this actually go compared to the last?
rcjim11 is offline Find More Posts by rcjim11
Old Jun 28, 2010, 02:54 PM
petranf is offline
Find More Posts by petranf
petranf's Avatar
Greece
Joined Jun 2007
Hello guys
5cell setup is by far the best setup i have ever had on a funjet. I had the opinion that this plane must be as leightweight as possible but i reconsidered. . Not good video quality but you can see for yourshelf .
1100 grams, 80amps max. Heatsink on battery and motor. 210 km/h
FanJet & petranf.avi (2 min 55 sec)
petranf is offline Find More Posts by petranf
Old Jun 29, 2010, 04:26 PM
Joined Sep 2000
My FJ ULTRA plus drive set has arrived
Here are some pictures of the ESC and the Hitec High-Speed outrunner:
Old Jul 01, 2010, 08:08 AM
Joined Sep 2000
Foam part weights ...
Center part/ fuselage 149.6g
Turtle deck 15.7g
Canopy 26.7g
Wing panels (L/R) 47.4g / 45.0g
Vertical fins (L/R) 8.8g / 9.3g
That's 302.5g total.
Jürgen
Old Jul 08, 2010, 02:12 PM
Joined Sep 2000
Sanded and painted (Honda Pewter Grey metallic):
9.4g / 9.9g - i.e. 0.6g added to each vertical fin.
Jürgen
Old Jul 08, 2010, 03:30 PM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
Jürgen
Nice Jurgen, that color will go well. Can't wait to see the finished product!
casey
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Jul 09, 2010, 03:32 PM
Joined Sep 2000
More pictures ...
Well, it is really hot over here, so i am taking it slow.
Carbon fibre spar sanded and glued into the center fuselage with Slo-Zap. Outer wing panels glued onto the fuse and spar using Slow-Zap. To improve torque transfer from wing to spar I used two lines of Beli-Zell on both sides of the spar (I used white one for better visibilty ).
Jürgen
Last edited by Jurgen Heilig; Sep 01, 2010 at 12:18 AM. Reason: "to" changed to "two"
Old Jul 10, 2010, 12:12 AM
Joined Oct 2007
WOW Jurgen looks to me like it will be stiff and rigid as hell. Love the silver look. Looks like a NASA prototype gone mach 15. Beautiful!! Yeah good call on the sanding of the spar, and the epoxy glue or whatever u used. I cannot stress to people that when your going top SPEEDS, reinforcement is really important. Thats why in a dive people wonder if there servos are failing or if the wing is just really flexing making you think one is failing. Nice job as always Jurgen!
casey
Old Jul 10, 2010, 12:34 AM
Joined Sep 2000
Beli-Zell is not epoxy, but PU-glue. Epoxy should not be used on Elapor.
Jürgen
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
