Old Jan 09, 2011, 02:48 AM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I'm excited to get this jet in the air. I just picked up the kit at the AMA show for $93 and change. Not bad at all.
T-CAT is offline Find More Posts by T-CAT
Old Jan 09, 2011, 02:52 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by SpoonEK View Post
I intend to give 6x4 a try with 2w20 on 4s. How do i know when the motor is running inefficiently?
Use 3s or you will fry your motor.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 09, 2011, 02:56 AM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Has anyone tried the MB-1 motor on 4S yet with the Funjet? I was going to test it on 4S with a 4.75X4.75 or 5.1X4.1 or something similar. The motor is 3200kv, but I have no idea what to expect with a prop on it considering the motor is normally used for EDF's.
Old Jan 09, 2011, 08:23 AM
rapz0r is offline
Find More Posts by rapz0r
Bipe addict.
rapz0r's Avatar
Ljubljana, Slovenia
Joined May 2007
Originally Posted by rapz0r View Post
Thanks for the advice, I'll measure the "jet nozzle"(lol) position to the wing, and recheck the mount. I am pretty sure that motor sits perfect, since I payed attention to that aluminum plate being straight and I loctited the bolts.
However I am not so sure about how plate sits on the black thingy.
I'll try to get it straight, however I'm affraid it is going to take a while to test fly it, since the grass runway where I fly is in bad condition, frozen, and last time I landed my FJ it got some nasty scars on the belly.
And broke one servo arm off. (My fault, I didn't put servo covers on - I have now.)
I checked the mount, it obviously wasnt sitting straight. I fixed it, now it is 0/0 degree angle.
I emptied four packs today, torque roll is reduced significantly, however it is still present. I will adjust the motor to add a bit of downthrust and try it, I hope I can get rid of torque roll completely.
rapz0r is offline Find More Posts by rapz0r
Old Jan 09, 2011, 09:00 AM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
Glad you fixed it
dogshome is offline Find More Posts by dogshome
Old Jan 09, 2011, 09:07 AM
dogshome is offline
dogshome's Avatar
Joined Dec 2006
Jürgen
He's right.
3300KV will need a 4.5" prop max. You're doing 40,000+ RPM on 4S.
Inefficiency will mean a large drop in RPM compared to no load RPM, heat, more heat and then smoke
Old Jan 10, 2011, 11:10 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
As Mid January nears....... Will Tower Hobbies move back the date for the 10th time???? Stay tuned.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 10, 2011, 01:11 PM
fabianvzwol is offline
Find More Posts by fabianvzwol
Nederland, Zuid-Holland, Spijkenisse
Joined Apr 2007
hello guys,
I'm planning to buy an FJ Ultra aswell, and would like to fly it with 4S 2650 35-70C Turnigy Nano-Techs. Wich motor (preferably a turnigy or something comparable)
I'd like to use a 60A ESC, but I also can use a 80A if needed. I would like to have a velocity about 200 km/h
greetings,
Fabian
fabianvzwol is offline Find More Posts by fabianvzwol
Old Jan 10, 2011, 01:54 PM
Shepski is offline
Find More Posts by Shepski
Joined Jan 2010
Fabian
HET 2W-25 on a 6 X 5.5 prop and running 4S , its a really quick set up.
Shepski is offline Find More Posts by Shepski
Old Jan 10, 2011, 02:02 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I am thinking of ditching my 4S set-up with the 3200kv Sapac MB-1. It may work =, but I am doubting myself. I have received great advice from board members and I think I may still try it out with a 5X5 APC or 4.75X4.75. However, this HET 2W-25 on 4S with 6X5.5 prop seems to be highly recommended by lots of members.
Now, I have the aluminum motor mount from multiplex. Would the aluminum mount fit the bolt pattern of the HET 2W-25 motor?
Also, can the 2W-25 setup mentioned take the Ultra 140+mph?
Old Jan 10, 2011, 04:17 PM
Joined Apr 2007
@shepski
which ESC should i use with the 2W-25 on 4S?
Old Jan 10, 2011, 08:13 PM
wise guy is offline
Find More Posts by wise guy
"Where are the shovels?"
wise guy's Avatar
Joined Apr 2010
Anyone have them in stock yet?
wise guy is offline Find More Posts by wise guy
Old Jan 10, 2011, 08:35 PM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
I'd advise you stay away from the APC 5x5 prop. It doesn't seem to have very good performance. From the ritewing thread, we've had lots of success with the "magical" APC 6x4 Sport prop (as opposed to the 6x4 electric). But as with anything, stick the setup through a wattmeter before you go out flying.
hawkz is offline Find More Posts by hawkz
Old Jan 10, 2011, 09:25 PM
zzw26n is offline
Find More Posts by zzw26n
Utica, Michigan
Joined Feb 2007
http://cgi.ebay.com/Multiplex-M21424...item5ade7870ba
zzw26n is offline Find More Posts by zzw26n
Old Jan 10, 2011, 09:55 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Thanks Hawkz. I'm assuming you are recommending to stay away from the 5X5 prop on either set-up I may use. Thank you for the heads up. I have never used one, so that's good to know. I'll do some research on it. I am worried a 6X4 using 4S with a 3200kv motor will fry that motor into pieces, lol. That's why I am thinking of moving to the HET 2W-25 on 4S .
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 09:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 04:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 06:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 02:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 08:01 AM
