Old Jan 30, 2013, 08:07 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by Jurgen Heilig View Post
Rene was talking about ESCs - not receivers.
Jürgen
When you run Castle ESC's it isnt a problem. You can even adjust their internal BEC circuit to put out up to 7 volts ....................
and if my memory aint too far gone, Patrick said the Castle ICE can stand well more than 8.4 volts if driven from an external source. I remember my main concern was the receiver max voltage
moparmyway is offline Find More Posts by moparmyway
Old Jan 30, 2013, 01:45 PM
skyhawk newbie is offline
Find More Posts by skyhawk newbie
Not a newbie anymore..
skyhawk newbie's Avatar
Ireland, Cork
Joined Oct 2010
Originally Posted by moparmyway View Post
Thats how I do my bungee launches ................... it aint a FJU, but its faster !!
http://www.youtube.com/watch?v=BkTVQ3caa1k
I've just used the RCSpeedo app
while watching your vid and got a top speed reading of 179.8mph
Sean
skyhawk newbie is offline Find More Posts by skyhawk newbie
Old Jan 31, 2013, 08:11 AM
moparmyway's Avatar
New York
Joined Jan 2009
Thanks ..........................
thats straight and level, without diving.
Old Feb 03, 2013, 01:44 AM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--what are any thoughts about using this motor
http://www.highendrc.com/index_eprod...roducts_id=322
-should be able to run a couple prop sizes more pitch than a 2w30 for same amperage since its a 36mm motor?
-maybe 7x8 on 4s under 90 amps?
-biggest thing for me is 5mm shaft and solid 150mph plus
-2w30 is 2200kv - 28mm x 52mm - run 7x6 on 4s
--this motor is about same kv and size as sk3 fandrive
http://www.highendrc.com/index_eprod...roducts_id=321
-maybe go with this one on 4s and run 7x 8 or more pitch or ramp it up to 5s when needed?
-maybe more battery and prop options with this motor?
--list of motors considering
http://www.ejf.com/index.php?main_pa...85_186_244_245
G-Forse is offline Find More Posts by G-Forse
Old Feb 03, 2013, 09:02 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
If your gonna spend over 100.00..kick in just a lil extra and have a Mega..
But...HET are good...
Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Feb 05, 2013, 10:17 AM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Till the itsy bitsy shaft bends......
rimripper is offline Find More Posts by rimripper
Old Feb 05, 2013, 10:36 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Or the caps come unglued 'cos you ran it too hot for too long
feefo is offline Find More Posts by feefo
Old Feb 05, 2013, 10:38 AM
G-Forse is offline
Denver, CO
Joined Nov 2007
5mm shafts
Old Feb 05, 2013, 10:40 AM
G-Forse is offline
Denver, CO
Joined Nov 2007
--Not sure I could run 150mph plus for to long -- maybe 5 seconds
--never had one open up and I've run my 2w25 with 6x5.5 pretty hot before as you can hold WOT alot longer
only going 130mph plus
Old Feb 05, 2013, 11:06 AM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Had 2 HET 3w's which the front cap came loose on. Motors were run within recommended cell count and prop sizes. Good to hear yours are fine.
Old Feb 05, 2013, 12:38 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
If you got it with 5mm,good,mine was 3.2mm sneeze wrong and it looked bent...
Old Feb 05, 2013, 01:12 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Hi Rim,
I believe you are referring to 28mm motors, he is after the 36mm.
Even though 36mm MEGA is "relatively" cheaper than 28mm MEGA for high power, he looks set on HET motors.
It should run ok.
Consider EDF foamy for flying on snow covered grounds. Remember the video of that EDF Stryker taking off from ground?
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 06, 2013, 09:59 AM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Or it explodes just by looking at it...
(sheesh! HET's aren't that bad... )
cjbucher is online now Find More Posts by cjbucher
Old Feb 06, 2013, 01:33 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Tempted to get one of these Neu motors:
http://www.neumotors.com/store/page1/page1.html
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Feb 06, 2013, 06:00 PM
G-Forse is offline
Denver, CO
Joined Nov 2007
--One of the main reasons I like HET motors is because they are relatively available as well as price. I've ordered HET edf fans and motors for various aircraft
--I also would prefer a larger shaft diameter on their 28mm motors, however, I only had one bend after a severe stall recovery in windy conditions that pancaked my FJ down hard on the asphalt runway.
--What is the best website in English to review and order Mega motors of different sizes and KV?
--Gryphon
--LOL-- the Turnigy 36mm SK3 Fandrive runs "OK" -- A 36mm HET should do very well -- along with Neu, Mega, Arc --LOL
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
