Old Nov 29, 2010, 05:06 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Originally Posted by Ben D Wing View Post
As per the funjet instructions works extremely well, quote:
''The first flight ...
Do not attempt to hand-glide this model!
The FunJet is designed for hand-launching only - always launch
directly into wind.
If you are a beginner to model flying we strongly recommend
that you ask an experienced model pilot to help you for the
first few flights. The model should be launched at ½ to ¾-
throttle, with the wings level and the nose angled up at an angle of 20 - 30°.
Don’t launch the model “down-hill”, like a glider!''
If you do launch it at an angle below the horizon then that is the point where you are most likely to injure yourself.
Thanks Ben. I appreciate your input. To be honest, a pusher makes me nervous. I have launched EDF's hundreds of times so technique shouldn't be an issue. This should hopefully minimize the risk. However, this won't eliminate the risk associated with pushers. I have everything I need for this ultra, except for the jet. Now I just need to determine whether or not I'm comfortable launching it. I could always put the power system and electronics in something else. Everything has it's risks, but now I just need to weigh them.
T-CAT is offline Find More Posts by T-CAT
Old Nov 29, 2010, 05:23 PM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
Once youve been flying a pusher for a while, like a few hundred flights and 2 years later your gonna laugh at this, because it becomes like breathing when you throw it. I could launch it with my eyes closed.
Also too fellas, you dont have to have the power on when throwing, just throw it then hit the throttle. I know it will torque roll a lil when doing that, but if your really that afraid then try that.
casey
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Nov 29, 2010, 05:26 PM
wise guy is offline
Find More Posts by wise guy
"Where are the shovels?"
wise guy's Avatar
Joined Apr 2010
The problem with the no throttle trick is weight... the 1500 watt + planes are so heavy!
wise guy is offline Find More Posts by wise guy
Old Nov 29, 2010, 05:36 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
casey
complacency can be deadly
cmala is offline Find More Posts by cmala
Old Nov 29, 2010, 07:05 PM
rrp is offline
rrp
Find More Posts by rrp
rrp
rrp's Avatar
Hampton Roads, VA Home of the 1st Fighter Wing, USAF
Joined Jan 2006
Originally Posted by Jurgen Heilig View Post
You really don't need a rubber band:
Another advantage of a turbine over an electric prop drive.
Jürgen
Well, I really didn't mean the bungee ... rubber band ... as in powered. It was supposed to be a joke, Jurgen. Yeah, I won't quit my day job.
rrp is offline Find More Posts by rrp
Old Nov 30, 2010, 02:28 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by wise guy View Post
Like it or not, your finger comes within millimeters of being cut off forever everytime you launch a funjet. This is a problem.
There are many ways to launch a FunJet and your fingers don't need to come close the prop. Here is an older compilation of FJ hand launches:
How to Hand launch A FunJet (1 min 39 sec)
Contrary to some launches in the video, it is safer to continue the circular motion of your throwing arm.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 30, 2010, 11:02 AM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
found that hand-lauching my Himax FJ full throttle at +/- 45° angle (yes, against the wind) gives:
- predictable results
- time to get rid of the moisture/dirt from your right hand (mode 2) on your trousers, then go to the right stick
- time for flight path adjustments if needed
Guess the method will work as well on the FJU when I'm finished (working on those CF fins right now )
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Nov 30, 2010, 11:37 AM
MoRaLeSD is offline
Find More Posts by MoRaLeSD
^(_Mš®ăĻēŜĐ_)^ ЯuĽeˇ U
Greece, Attica, Elefsina
Joined Sep 2010
Originally Posted by dicker View Post
Ok, the hinges of the FJ ultra are robust and perform up to 300kph (180mph) without any problem.
Can you suggest us a setup to achieve this speed?? Thanks mate!!
Dmitris, Greece.
MoRaLeSD is offline Find More Posts by MoRaLeSD
Old Nov 30, 2010, 12:29 PM
dicker is offline
Find More Posts by dicker
foamforce pilot
dicker's Avatar
Deutschland, Schleswig-Holstein, Braak
Joined Jan 2004
Dmitris, Greece.
http://www.rcgroups.com/forums/showthread.php?t=1340571
Motor was a Dymond HQ3651 from modellhobby.de
Julian
dicker is offline Find More Posts by dicker
Old Nov 30, 2010, 02:42 PM
MoRaLeSD is offline
Joined Sep 2010
Hm let me see!
Old Dec 01, 2010, 04:36 AM
dicker is offline
foamforce pilot
dicker's Avatar
Joined Jan 2004
Hm let me see!
what? Logs and data is in the linked thread?
Julian
Old Dec 03, 2010, 12:38 PM
griffin 27 is offline
Find More Posts by griffin 27
Trusted Verified User
griffin 27's Avatar
United States, CA, San Diego
Joined May 2009
I received and installed one of these and I'm using a HET motor. The problem I have with it is the hole around the motor shaft is to small to fit the prop adapter close to the motor.
Does anyone else have this problem, I guess I could always dremel out the hole and make it bigger.
Originally Posted by ongl View Post
Gryphon,
Yup my het motor mount looks exactly like that. Anyway I have included some photos for your reference. Hope this helps!
ongl
griffin 27 is offline Find More Posts by griffin 27
Old Dec 03, 2010, 12:53 PM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
I haven't received mine yet, but there doesn't look to be a lot of meat to trim off that mount. Maybe you could try a different adaptor as some have deeper immersions than others.
Ben D Wing is offline Find More Posts by Ben D Wing
Old Dec 03, 2010, 07:02 PM
rrp is offline
rrp
rrp
rrp's Avatar
Joined Jan 2006
I'm assuming this is the red aluminum mount, griffen? I too, ordered one of those. What is the center hole diameter? The base of my adapter is abouts 10 mm. Looks like a very tight fit?
It appears Tower had the yellow/gold one back in stock early this week and I was able to nab the last one from their stock. I expect to get it next week. My airframe has shipped from Malaysia. Making progress, slowly.
Old Dec 05, 2010, 04:16 PM
dogshome is offline
Find More Posts by dogshome
dogshome's Avatar
Joined Dec 2006
Originally Posted by schim View Post
The other problem was: totally wrong setup CoG!!!!
I just saw the vid
Very funny and I know the feeling:- "Should I try and land? or just stay up here??"
dogshome is offline Find More Posts by dogshome
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
