Old Dec 18, 2012, 01:19 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Instructions say CA, I think most use CA although some use epoxy. CA and kicker 'melts' the parts together, don't think epoxy does that.
I've used the MPX Elapor glue, and some medium CA I got from work. Not sure if the CA from work is classed as foam safe (I'm betting it isn't or the boss would charge more....).
feefo is offline Find More Posts by feefo
Old Dec 18, 2012, 03:44 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
I use Gorilla Glue for all my foam planes and it works great.
setxws6 is offline Find More Posts by setxws6
Old Dec 18, 2012, 07:02 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Originally Posted by jasonafriedman View Post
About servos, mine didnt fit, so i just cut a tiny of foam out.
Is it ok that i used epoxy on everything so far though? Epoxy usually is really good for foam. Is foam safe CA ok on funjet ultra foam?
The instructions call for regular CA. It will have the strongest bond with this type of foam. Epoxy will probably work but may not bond as well with this type of foam. This is one of the few foams that does not require foam safe CA. They even recommend against it.
cjbucher is offline Find More Posts by cjbucher
Old Dec 18, 2012, 07:13 PM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
with regular CA do you have to use kicker ? All I have is foam safe kicker or should I not use kicker? which works better Med. Or thick
zeus3313 is offline Find More Posts by zeus3313
Old Dec 18, 2012, 08:17 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Medium and you can use foam safe kicker.
Old Dec 19, 2012, 08:22 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
I'd use clear Packing Tape along the areas that you epoxied...That will help Lock it together as well..I actually Tape the whole plane....Tape so that the laps are always on the downwind side...in other words ..so that wind can't peel it up at high speeds...on the wings start at the back and work your way forwards..the laps will be on the down side of the wind..
The Kicker on regular CA melts the foam..and actually welds it together
Or you can use Zagi Tape like I did for the colors..and I use Clear for the Bottom...It also keeps the plane from Scuffs and Grass stains..as well as small dings ...The two lil white spots on the wings are the servo rods...I run my Rods on top to help protect the servos from grass and other hits that occur under the wings if you run servos under the wings...
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Dec 19, 2012, 12:14 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
Has anyone tried using gyros on the fju? I recently fitted the newer HK 3-axis v2 stabilizer on mine and have yet to try it. I am going to use pitch and roll stabilization to keep my fju straight on high speed passes and on the initial hand toss.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Dec 19, 2012, 12:16 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
If you've discovered a way to compensate for the initial torque roll on the hand toss with this HK gyro, it would rock! Please let us know.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Dec 19, 2012, 03:26 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
For those few that are using the Mega 16/45/xx, what sort of AUW are you coming in at? How heavy are your battery packs?
Just wondering....
Old Dec 19, 2012, 04:49 PM
dmaaero is offline
Find More Posts by dmaaero
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
Ready to roll,
dmaaero is offline Find More Posts by dmaaero
Old Dec 19, 2012, 05:05 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by dmaaero View Post
Ready to roll,
Cool...
What's your setup again?
Old Dec 19, 2012, 05:06 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Wow, I somehow posted same thing twice...
Anyhow, I will post my gyro results hopefully with a video soon. I do notice the fju will also torque on a high speed pass as well and this makes it dangerous and unpredictable. On slow passes the fju would rock and wing stall. The change of speed also effects the amount of elevator trim needed for level flight. I am expecting all of these things will be corrected with the use of a gyro.
Old Dec 19, 2012, 05:48 PM
dmaaero is offline
dmaaero's Avatar
Joined Jan 2010
Originally Posted by feefo View Post
Cool...
T3648-1450 cc100 nano-tec 3300mah 65c 4s 7x10
Old Dec 19, 2012, 08:37 PM
Rogersville, Mo
Joined Jun 2008
Just wondering....
If I remember right..53 ounces...with a 6 cell in the 3000 mah area....
I haven't weighed my Batteries...got some 2650s in the 6 cell I'm goin to try this spring..2700 and a 3300 also ...Just been fishin since I got mine all ready to fly....I'll start back to flyin in a couple Months..
We're under a Tornado watch right now...Gotta go..
Billy
Old Dec 19, 2012, 08:39 PM
Rogersville, Mo
Joined Jun 2008
One of My regular Funjets I had that setup...just run a couple Mins..on each run and don't run WOT very long and that Motor will last lil bit...
Billy
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
