Old Dec 14, 2012, 03:46 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I'm going bungee, not only is it safe, it's cool!
Ohmic is offline Find More Posts by Ohmic
Old Dec 14, 2012, 10:05 PM
jasonafriedman is offline
Find More Posts by jasonafriedman
F3K all day
Joined Dec 2011
I just got my FJU today. Im almost done with the build, but i need to wait for HK to ship my battery and ESC
jasonafriedman is offline Find More Posts by jasonafriedman
Old Dec 15, 2012, 04:06 AM
dmaaero is offline
Find More Posts by dmaaero
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
Bungee launchers are cool,
Super Squirrel (1 min 6 sec)
dmaaero is offline Find More Posts by dmaaero
Old Dec 15, 2012, 08:35 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by feefo View Post
Bit of a pain to take tho.
Not at all, ramp breaks down into 4 pieces in under 5mins
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Dec 15, 2012, 08:43 AM
F3K all day
Joined Dec 2011
Hey i have a problem. To get the motor at the correct angle, the adjustment screw has to stick out a certain amount. The problem is that for it to be in the center, the screw will hit my prop. Any solutions?
Old Dec 15, 2012, 09:17 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
You've done something wrong...Re check your Manual...and make sure your Motor and Mount is installed the correct way...
Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Dec 15, 2012, 09:41 AM
F3K all day
Joined Dec 2011
Haha ok.
Old Dec 15, 2012, 10:19 AM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
I had the same problem and it seemed the screws were so tight going into the plastic mount they end up stripping before you get them all the way in. I had thought they were threaded in all the way but no, I still had a ways to go. The soft metal slotted screws are the devil! Toss them out and use some hex screws from a Nitro Savage screw kit. They are the correct size and fit perfectly. I ended up using this motor mount
http://www.ebay.ca/itm/Multiplex-Fun...1#ht_891wt_922
It comes with the optional Socket head screws and they are not the soft metal.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Dec 15, 2012, 10:21 AM
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Description:
Spinner is on good and tight and there is still lots of clearance from those screw heads.
Old Dec 15, 2012, 01:02 PM
F3K all day
Joined Dec 2011
Yeah i had trouble screwing in the flathead screws. Maybe i should use different screws.
Old Dec 15, 2012, 06:46 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
This flatheads are a PIA!
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Dec 15, 2012, 07:05 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
looks like whoever made that flying squirrel video, is insufficient in a certain area of the anatomy. and has to pick on animals to feel like a man.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Dec 15, 2012, 07:24 PM
F3K all day
Joined Dec 2011
Hello, how do you guys recomend putting a gopro on the funjet. Is it a lot harder to fly?
Old Dec 16, 2012, 08:18 AM
Rogersville, Mo
Joined Jun 2008
If ya take some Vaseline and lightly coat the first two or three threads...they can be tightened real easy...I did that with all my Multiplex Motor Mounts..Makes it a breeze to change out power systems as well......Billy
Old Dec 16, 2012, 09:42 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Looking back, I think it might be a good idea to 'pre fit' the screws before you actually glue the mount to the plane. I found it took quite a bit of pressure on the screws to get them to screw forward, I'm sure that without enough pressure you simply cross thread the blind hole. Once you've 'tapped' the holes it'll be easier to screw the motor mount plate to the actual mount.
I've used the supplied screws, socket head and bolt head. Personally I prefer the bolt head and to use a small socket, less likely to slip or chew the head, which I have done with both the supplied screws and socket head screws. Pozi/Phillips head screws would be better, flat head always seem to slip and cause the chewing and small allen keys tend to wear very easily too.
feefo is offline Find More Posts by feefo
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
