Old Nov 27, 2012, 05:27 PM
jasonafriedman is offline
Find More Posts by jasonafriedman
F3K all day
Joined Dec 2011
What speed do you think i could get with this?
http://www.hobbyking.com/hobbyking/s...idProduct=9083
and
http://www.hobbyking.com/hobbyking/s...ontroller.html
And
Sky lipo 3300mah 3s 40c lipo?
I do not know what prop i should get. Do you have a recomendation for a pretty cheap setup capable of 120?
jasonafriedman is offline Find More Posts by jasonafriedman
Old Nov 27, 2012, 06:01 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Those links don't work....not for me anyway.
feefo is offline Find More Posts by feefo
Old Nov 27, 2012, 06:55 PM
F3K all day
Joined Dec 2011
Oops sorry. Let me try again.
Old Nov 27, 2012, 07:57 PM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
Ok I really am ready to buy a motor:
Here are some of the equipment I have:
CC Ice 100 ESC
60 amp Turnigy ESC
Batts
4s 2200
3s 3350
4s 3300
3s 2200
I am wanting to getting speeds over 120 without mods. What motor should I get and use any of the above equipment? Should I get a whole new setup what should I get
zeus3313 is offline Find More Posts by zeus3313
Old Nov 27, 2012, 08:33 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Hey guys I am totally new to whole FJU realm and I am currently having a problem with the spinner. Under load it seems the rotor pulls into the motor and the prop will strike the mount plate screws. The instructions are useless so I am asking if there is a correct way to install the motor, spinner and plate? I'd imagine I would need to find the right amount of clearance for setting the spinner but I don't think it should be hanging on the edge of the motor shaft. Any thoughts guys?
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Nov 27, 2012, 09:00 PM
nofreee is online now
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
CC Ice 100 ESC
60 amp Turnigy ESC
Batts
4s 2200
3s 3350
4s 3300
3s 2200
You can definitely do it with those parts. I ran a HET 2w-23 with a 5.2x5.2 on 4s and got around 130mph flat and level, 140+ in a dive. Pulls about 85 amps static if I recall correctly.
nofreee is online now Find More Posts by nofreee
Old Nov 27, 2012, 11:27 PM
F3K all day
Joined Dec 2011
How much does a funjet weigh? Whats a good weight to thrust ratio with one of these planes? Thanks
Old Nov 28, 2012, 12:19 AM
doonunder is offline
Find More Posts by doonunder
New Zealand, Auckland, Waiau Pa
Joined Dec 2006
Where's the best place to buy a Funjet these days? Are they discontinued? Love my X-83 and that is discontinued and would love to replace it with a funjet when she dies.
doonunder is offline Find More Posts by doonunder
Old Nov 28, 2012, 12:25 AM
F3K all day
Joined Dec 2011
http://www.rctoys.com/email/BlackFriday.html
Old Nov 28, 2012, 12:43 AM
Joined Dec 2006
Originally Posted by jasonafriedman View Post
Geez thanks but that is 3x cost a x-83, damn it should have bought a few of the x-83 a while back .
Old Nov 28, 2012, 01:04 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
I was getting about 105A static on 4S and a 7.4X8. Considering you'' get about a 10% drop in flight this prop will be fine on 5S. Maybe even a 7X10 if you're carefull.
With 4S and 7.4X8 the motor was barely warm - plenty potential left.
BTW - I got 194mph on that set up (down wind with a dive). If didn't ever do a level flight test but I reckon its about 175mph.
Originally Posted by nofreee View Post
I'm going with a 5s setup and plan on starting with a APC electric 7x6 and going from there, maybe a 6x5.5 depending how many amps it pulls.
I put the 4s batts in to see what it would take to get the CG right. The 5s 3000mah are about 150g heavier than the 4s, so it should help with the balance.
War Machine is offline Find More Posts by War Machine
Old Nov 28, 2012, 09:09 AM
nofreee's Avatar
Joined Jan 2012
Good to know. I've got a CC 100a that's going in there. I'm only shooting for around 160mph or so initially, then I'll prop up from there.
Old Nov 28, 2012, 12:55 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
KV of that motor is a bit high, might be ok on 3s and the quoted 5.5x4.5 prop but as it's been said bigger props are better. Pretty sure it'll work, just don't think it's 'ideal'.
Always found Turnigy esc's to be ok (good value for money)
Old Nov 28, 2012, 01:03 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
CC Ice 100 ESC
60 amp Turnigy ESC
Batts
4s 2200
3s 3350
4s 3300
3s 2200
What C rating are those lipo's, if they're 20c then you're going to squeeze the life out of them
Get a Mega 16/25/2CE, which is 3, 4 and 5s capable (I've not run 5s myself tho). It's the cheapest Mega that's suitable for 130mph+ at around 74 euro's + postage. HET motor's work ok but I got through 2 HET's (3W) to 1 Mega (16/15/3) on a pylon racer.
If you want my (soap box) opinion on the 16/25/2CE pm me, or search this thread for some of my posts.
Old Nov 28, 2012, 01:11 PM
F3K all day
Joined Dec 2011
What would you recomend that is as cheap as that or cheaper?
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
