Old Nov 14, 2012, 06:37 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
MPX aren't the cheapest RX's either....
feefo is offline Find More Posts by feefo
Old Nov 14, 2012, 11:35 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
I am a big fan of Horizon products.
Their customer service has been Very good to me over the years.
I too agree that way too often Receivers get blamed when the issue is else where.
At the same time, I know that not in a million years will they (Spektrum/Horizon) ever admit that something was not perfect.
What's that Heli site?.....runryder or similar....A guy did a excellent write up and showed pics of the printed circuit board of AR6200. He pointed out areas that are too thin and prone to damage.
Wish you all the very best and hope none of you ever crash. It sure sucks!!!!
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Nov 15, 2012, 05:05 AM
Maccanaut is offline
Find More Posts by Maccanaut
Melbourne Australia
Joined Aug 2010
Ok ive pulled this from my little tub of tricks. I'll rebuild my FJU (now known as FrankenJet Ultra) and trial the same set up but with the ubec. If its fine, I'll buy ANOTHER (goddammit!) funjet and start again. Thanks EVERYONE for the help.
Maccanaut is offline Find More Posts by Maccanaut
Old Nov 15, 2012, 05:20 AM
Melbourne Australia
Joined Aug 2010
Trying to attach photos here using ipad
Old Nov 15, 2012, 05:53 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
Ive used that one - works well. I suggest again use a separate Rx pack. 2s370 is only 40g. That way you bypass your main lipo and esc. Added peice of mind.
War Machine is offline Find More Posts by War Machine
Old Nov 15, 2012, 07:01 AM
Melbourne Australia
Joined Aug 2010
Ok uve convinced me.....but can u steer me to an online guide to setting that up? Ive not used that set up before.
TIA
Old Nov 15, 2012, 07:40 AM
Joined Oct 2008
Get a 2s370mah (or 400mah)
Solder a minideans / your favourite plug to the battery lead and a plug to the black and red wire of your UBEC.
Plug battery into UBEC
Plug UBEC into Rx
Easy !
Or you can use a 2S LIFE battery. They're 6.6V so you can plug them straight into your Rx with no UBEC.
Old Nov 15, 2012, 07:41 AM
Joined Oct 2008
Rx pack
Old Nov 15, 2012, 09:04 AM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
I'm going to start building my MultiPlex TwinJet soon with two HiMax inrunners. And I plan on using one of these Hobby People LiFe Receiver Packs to power the servos. It'll also help balance the plane by adding a little more weight up front. I picked one up when it was on sale for $19.99.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Nov 15, 2012, 02:37 PM
Melbourne Australia
Joined Aug 2010
Heres a theory. First off, i once had a servo on a heli that when installing was very tight and took some working in. When testing the heli, that particular servo would have spasms. I thought it was a dodgy servo so removed it, but it was fine when tested outside of the heli. i wondered if it was due to the servo bay being too tight. It was fixed just by filing the servo bay a touch.
These HS 65MG's were very tight in the servo bays on the FJU, and I'm wondering if maybe theyre drawing more current as a result, possibly causing the problems I'm having. Any thoughts on this?
I'm just disappointed that I spent $167 aud on the MPX set up and having issues, when I could have gone a cheaper route that would have given more power and speed at half the price.
Old Nov 15, 2012, 04:08 PM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
Originally Posted by nofreee View Post
The 5.5x4.5 runs are coming down in the low 90's on the can. Batteries and ESC are well within acceptable temps. I will be stepping up to the 5.5x5.5 this weekend, but like you stated I think this motor can take it.
Finally got my 5.5x5.5 runs in on a 4s HET 2w-23.
I think it is too much prop and I am losing too much RPM. It was constantly in 125-130 range when I was getting those speeds with a 5.5x4.5.
I've got the 5.2x5.2 that I'll try this weekend, I think that might be the sweet spot for prop sizes on this motor on 4s at least.
nofreee is offline Find More Posts by nofreee
Old Nov 16, 2012, 12:22 PM
nofreee is offline
nofreee's Avatar
Joined Jan 2012
I put my HS65's in with only minor trimming where the horn screws in. No problems with mine on a 3amp integrated BEC.
Old Nov 18, 2012, 08:32 AM
Joined Jan 2012
If you're looking for a recommended Himax HC3514-2900 for your FunJet Ultra, I'm selling mine.
Old Nov 23, 2012, 07:21 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
Well this is it... I got all my parts together and I assembled my Funjet. We will see now if this recommended setp wlll in fact crush the opposition!
I started the assembly by sanding all the mold bumps and filling the dimples.
Attachment 5323944
I coated all the parts with Minwax to ensure a good surface for paint. After a fine sanding this also helped smooth out the panels. I picked up a light kit just for that extra touch that will set mine apart from the others. I used 5 min epoxy on the spar and with the wings but I used silicone adhesive for the turtle decks and the motor hub. I might have to get back in here at some point someday.
Attachment 5323951
This is the desired paint scheme which will tie in well with my decal set.
Attachment 5323982
I didn't like the "50's space ship" retro look of the original canopy so I sanded in new canopy lines and used rattle can chrome on it.
Attachment 5323983
My opponents got some free stickers so they plastered "Rockstar energy drinks" all over their funjets. Out of spite, I am using a "Monster energy drinks" scheme with the choice of paint colours and decal set I picked up. Notice the spoon hood scoop over the esc and onto the back of the motor. This should provide optimal cooling.
Attachment 5323992
Attachment 5323993
For my setup I am using a BL15 3600kv inrunner with the E-flite Stryker 6x4 prop (older version) powered with a CC Ice lite 100A. I have balanced the plane for use with either 3s or 4s 3500mAh 30C lipo packs. I also balanced the prop to ensure smooth quiet operation. Well... as quiet as Funjet can get, lol. I will be posting the maiden soon.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Nov 23, 2012, 07:32 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Oops the pics didnt load properly...
Description:
Description:
Description:
Description:
Description:
Description:
Hopefully these will work.
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
