Old Nov 06, 2012, 07:40 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Originally Posted by feefo View Post
I wrap the servo in masking tape and use a good blob of medium CA. If you need to remove the servo then the masking tape can be cut and the servo comes out (a bit) easier.
nice , i learned something new . going to start using this method on all my planes .
thanks for the tipbit of info
THESANDMAN is offline Find More Posts by THESANDMAN
Old Nov 06, 2012, 09:31 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
First launch of a friend's FJU on a ramp we recently built.
Though we can't figure out what that sound is
Multiplex Funjet Ultra Hits Vtec (300km/h) (4 min 25 sec)
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Nov 06, 2012, 09:53 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
un balanced prop? do you have a metal motor mount? when you run these high rpm motors, its imperative to have a very balanced prop. could also be bad bearings.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Nov 07, 2012, 08:56 AM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
So any servo recommendations for the Funjet Ultra?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Nov 07, 2012, 10:22 AM
gchrisgo34's Avatar
Joined Nov 2010
metal gear, high torque.
Old Nov 07, 2012, 10:29 AM
gchrisgo34's Avatar
Joined Nov 2010
im trying to figure out how to get 6v run to my servos. i have a turnigy bec, and theres a seperate 6v output on the bec, that ive never seen anyone use. ive hooked up bec's in the power lines, and run with a seperate 2cell batt. but theres a seperate 6v output on most bec's, that ive never seen anyone use. maybe instead of using the normal rx hookup, run a male to male servo extension from the 6v output on the bec, to the rx. and just leave the existing bec wire unhooked. any ideas?
Old Nov 07, 2012, 11:56 AM
Joined Jan 2012
Hitec MG65 or MG82? Or another?
Old Nov 07, 2012, 12:49 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
HS82's will need you to remove some foam, 65's should go straight in.
feefo is offline Find More Posts by feefo
Old Nov 07, 2012, 12:53 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Even on my molded slopers I wrap servo's in tape, but then use a epoxy + microballoon mix. Again if you need to remove them, cut the tape.
Old Nov 07, 2012, 12:55 PM
desertdog1 is offline
Find More Posts by desertdog1
windyhill
United States, OR, Ione
Joined Jan 2009
Wanted, fun jet battery hold down plate. If anyone hads a crashed f j please give me a e mail. Need it bad
Ron
desertdog1 is offline Find More Posts by desertdog1
Old Nov 07, 2012, 01:01 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
Ron
You can easily make one from a scrap piece of 1/8 plywood.
Grtz Rene
E-speed buff is offline Find More Posts by E-speed buff
Old Nov 07, 2012, 01:09 PM
windyhill
Joined Jan 2009
Grtz Rene
I know but i need one for my pulsar pro 3.2 e.
Old Nov 07, 2012, 01:23 PM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
http://www.youtube.com/watch?v=Myoe_H02ly8
I had a similar noise with mine which was the plastic motor mount.
I assume you have changed to a metal mount.
I've had the same noise on another fast model which was a not quite tight enough metal motor mount.
soundcheque is offline Find More Posts by soundcheque
Old Nov 07, 2012, 04:00 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Definitely sounds like an out of balance prop. You'll want to resolve that one quickly. If you were to watch the prop when it makes that noise you'd literally see it wobble as the forces of the imbalanced prop make your prop shaft flex. Your shaft could bend or break.
cjbucher is offline Find More Posts by cjbucher
Old Nov 07, 2012, 11:14 PM
Maccanaut is offline
Find More Posts by Maccanaut
Melbourne Australia
Joined Aug 2010
Going to start my Funjet Ultra build soon. Will start with a HiMax 3514 and then work my way up to an ARC.
What servos are you using on your Ultras? Will a Hitec 82MG fit into the pre-cut slots without any mods or are 65MGs a better bet?
HS 65MG's here.....on stock powertrain.
Maccanaut is offline Find More Posts by Maccanaut
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
