Old Oct 17, 2012, 05:51 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Originally Posted by zeus3313 View Post
Which would be better foam safe ca or epoxy... Or should I go and get gorilla glue (white) I'm going to start my build tonight
Personally I've never had good results with foam safe CA. It just never seemed to have good thick strong bonding IMO. Might work well with slow flying planes that don't have much stress on the wing and fuselage structure. Epoxy would work, but it seems too heavy for foam planes to me. The great thing about Gorilla glue is that a little goes a long way and it expands...so you get all those cracks and seems filled with glue.
You can find it at Lowes, Home Depot or any other hardware stores. I think it's at Walmart too...
setxws6 is offline Find More Posts by setxws6
Old Oct 17, 2012, 05:56 PM
PJRono is offline
Find More Posts by PJRono
PJRono's Avatar
Ham Lake, MN
Joined Jun 2003
I just used regular medium CA and accelerator like they tell you to. Mine's been good to 190+ mph.
PJRono is offline Find More Posts by PJRono
Old Oct 17, 2012, 06:50 PM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
The regular "brown" gorilla glue?.....Medium CA (not foam safe?) which a kicker foam safe or regular?
Sorry about all the questions if this were a stick build i wouldnt be asking many LOL .. I have almost every glue that we are talking about I just want to use the correct stuff
zeus3313 is offline Find More Posts by zeus3313
Old Oct 17, 2012, 07:11 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Reg brown Gorilla glue or the fast drying white kind both work fine. Just depends on how long you want to wait for it to cure. If you have CA and accelerator you can try it and see how it works for you.
Old Oct 17, 2012, 09:23 PM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
I use the 65's in my 140mph FJU, and 5085's in my 200 FJU, no issue with either.
Hs 85's ? Is the servos that are being used?
markusvt is offline Find More Posts by markusvt
Old Oct 17, 2012, 09:25 PM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
Med CA and kicker in my 140mph FJU, and 30 minute epoxy in my 200mph FJU. I think both are fine in each. The epoxy is stronger a bit.
What glue works best to assemble the FJU?
Old Oct 17, 2012, 09:26 PM
zeus3313 is offline
Joined Jan 2010
I picked up the 65 mg's ..I was going to build tonight but...maybe tomorrow night
Old Oct 17, 2012, 09:33 PM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
6.5x6.5 Graupner speed prop on 6S is perfect for that motor, runs it all day long. Need a good ESC and battery to run it to it's potential. Not really a good 4S motor, but 7x10 should be a good match if you wanted to try.
QUOTE=War Machine;23005390]moparmyway - would you say thats the best setup for the 1900kv SK3 - 6s2650 and 6.5X6.5 ?
Any idea what that motor would do with a 7X10 and 4s ?[/QUOTE]
Old Oct 17, 2012, 10:00 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Those will be fine. The FJ is going so fast that the faster you go the smaller and smaller the movement will be in the control surfaces for changing direction. So unless you plan on doing some 90 degree hard turns at 100+, there's really no need for expensive high torque servos.
Old Oct 17, 2012, 10:40 PM
zeus3313 is offline
Joined Jan 2010
My setup should be good for around 125mph but no high speed turns...I still have to figure out what battery to use??.. I also have a couple of these around I wonder if they will work
ES50 Nano™ Servo
Stock Number: GPMM1210
Speed @ 4.8V: 0.13 sec @ 60
Torque @ 4.8V: 16.7 oz-in (1.2 kg-cm)
Dimensions: 0.9 x 0.4 x 0.8 in (22 x 11 x 20 mm)
Weight: 0.32 oz (9 g)
Old Oct 17, 2012, 10:58 PM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
You claim to be using the Himax 3514 2900KV for your setup, and the specs on that motor recommend 2s to 3s lipos. I'm guessing a 2200-3300mah 3s would work.
Old Oct 17, 2012, 11:02 PM
zeus3313 is offline
Joined Jan 2010
Yes my LHS talked me into the combo from mpi...hope it's a good setup..I haven't picked it up yet..
Old Oct 18, 2012, 04:09 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
Do you think 6s2700 will be big enough ?
Ive already got 4s2700. Im hoping to use 2s+4s2700.
[/QUOTE]
War Machine is offline Find More Posts by War Machine
Old Oct 18, 2012, 12:00 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Bigger batts would serve you better as LVCO happens quickly @ 150+ amps
moparmyway is offline Find More Posts by moparmyway
Old Oct 18, 2012, 10:13 PM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
My Funjet likes to nose up under heavy throttle, cg is on the money with the tabs under the wings. Does it require up thrust or down thrust on the motor mount to remain more neutral?
nofreee is offline Find More Posts by nofreee
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
