Old Oct 14, 2012, 08:35 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
HS85's will work, so will HS65's and the 5085's or the 5065's and even the HS5087's !!
moparmyway is offline Find More Posts by moparmyway
Old Oct 14, 2012, 08:38 AM
moparmyway's Avatar
New York
Joined Jan 2009
OK, so some prop testing has been done to the Turnigy 3659 (1900kv) SK3 and then compared to MEGA 22-40-1e.
Turnigy was doing pretty good @ 150 amps but the MEGA needs to be handicapped, like maybe 5 cells ..........
(6s2650 and APC 6.5x6.5 prop on each motor)
(Same ESC, batts, prop, adapter .............. only difference is each motor)
Old Oct 14, 2012, 09:13 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Just thought I'd say Hi to you fellas...Still haven't Maidened the Megas yet...Into my Fall Fishin now...have been readin day to day here..just settin on the sidelines..
Take Care Guys!!!....Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Oct 14, 2012, 09:38 AM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
Which servo fits and works best?
This is the setup I was going to use ..Not that fast I was told around 100-115 mph:
Himax 3514 2900KV APC 6x5.5E Pheonix ice 75
zeus3313 is offline Find More Posts by zeus3313
Old Oct 14, 2012, 10:05 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
The HS65's and HS5065's should fit straight in the servo wells, the bigger HS85's and 5085's will need you to remove some foam.
If that's the MPX recommended motor, I thought it was good for 125mph-ish?
Anyway, the MPX servo's (nano's?) are very similar to HS65's, so on a setup for 115mph the 65's should be fine. I use the 85's, I just prefer something a bit stronger than HS65's, but use them (65's) a lot in my moulded gliders. But it also helped I had 2x HS85's in the spare's box when I built the FJU.
feefo is offline Find More Posts by feefo
Old Oct 14, 2012, 01:49 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
I'm using the HS-65hb in my 140mph ultra with no problems yet (knock on wook)
setxws6 is offline Find More Posts by setxws6
Old Oct 14, 2012, 02:15 PM
piotralski is offline
Find More Posts by piotralski
piotralski's Avatar
Polska, Mazowieckie, Pruszków
Joined Oct 2009
Heat 1W-40 / 6x5 Areonaut / 4S 2200mAh / 273km/h
piotralski is offline Find More Posts by piotralski
Old Oct 14, 2012, 04:05 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Well after hitting the ground at full power, the impact was so strong that it ripped the motor mount right off
I figured the shaft on my MEGA 16/30/2.5RCE for sure was bent,
We the 5mm shaft took the hit, and asked for more
Still spins true, no wobbles.
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Oct 14, 2012, 06:02 PM
moparmyway's Avatar
New York
Joined Jan 2009
Flame,
Sorry for your loss ............. were you flying or was a friend piloting the failed launch ?
Old Oct 14, 2012, 08:23 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
I was out flying by myself, 1st hand launch went well, 2nd ended well see pic
she will see flight again, but as on ultra light
New FJ Should be ready this weekend
FCA
Old Oct 15, 2012, 08:25 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
moparmyway - would you say thats the best setup for the 1900kv SK3 - 6s2650 and 6.5X6.5 ?
Any idea what that motor would do with a 7X10 and 4s ?
War Machine is offline Find More Posts by War Machine
Old Oct 15, 2012, 12:42 PM
moparmyway's Avatar
New York
Joined Jan 2009
Take it easy ..............
That was just static test for data freaks like me.
Whats the best setup ???? ............. MEGA (of course)
OK, seriousely, the 6.5x6.5 prop on 6s2700 (65/130) batts would be at the top of my list to fly with if I were you, then possibly 7x8 on 5 cells.
7x10 on 4 cells should be an easy no limit throttle if the motor is any good longevity wise. I would oil the bearings and make sure to re-solder or remove the stock bullets
Old Oct 15, 2012, 06:01 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
moparmyway,
What's the white box in the upper left of your Eagle Tree screen shots?
Is that the results from the moment in time where mouse is located?
If it's not, then can you please zoom in further so I/we can read the averaged data over the narrow time line (maybe 0.1 second before and after where you normally place the mouse).
Right now, the averaged data includes motor off time periods and are not usable for comparison.
I have installed Eagle tree's latest software on the new computer, but did not finish it by connecting the data logger (required) for first use of software....Since it has been a bunch of weeks, I better get it done soon/tonight.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 15, 2012, 10:16 PM
nofreee is offline
Find More Posts by nofreee
nofreee's Avatar
United States, CO, Colorado Springs
Joined Jan 2012
Originally Posted by GryphonRCU View Post
nofreee,
I think that your setup has a fair chance of reaching your goals.....but I'm not sure about the required prop size.
Consider starting off with 75-80A static with a 1:1 prop size (diameter to pitch ratio).
If you have Graupner 5.2X5.2 post the static data before first flight and wait for feedback from the folks on this thread.
***Maybe the guys who are more familiar with that same motor on 4S can recommend a better prop.
If you have one of these APC 5X5 , 5.25X4.75 , or 5.5X4.5 then maybe that data can help the folks recommend a good prop for your first flight.
Run a heat sink and use throttle control till you get the hang of the motor temps.
Static testing:
Do only a single 3 second static test starting with the motor at room temp.
Report data from after the first second...read any 2 of these 3 values (A, V, W)
To do another test or re-test wait till the motor is pretty close to room temp.
Be safe.
Good luck,
Gryphon
Finally had a chance to get everything assembled and run some tests.
APC 5x5 - 60a 850w
APC 5.25x4.75 - 70a 950w
APC 5.5x4.5 - 75a 1000w
Graupner 5.5x5.5 - 80a 1085w
However, these tests were on done on 4s 1600mah 35c batts. I need to re-solder the connectors on my 4s 2650mah nanotechs and do it again tomorrow.
This was for the following setup.
HET 2w-23
Hobbywing 80a ESC
4s 2650 35-70c
nofreee is offline Find More Posts by nofreee
Old Oct 15, 2012, 11:55 PM
GryphonRCU's Avatar
Joined Mar 2008
nofreee,
Lets see how the data changes with your bigger pack.....AND it will change.
See my attachment. Actual data from one of my tests in order to show some other folks the effects of running various size packs.
on my graph:
See the effect of battery size change on weakest prop (RPM and Watts).....then look at the changes on the highest load prop.
Gryphon
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
