Old Oct 06, 2012, 03:42 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by stanordave View Post
Sebbe,
Good point!
Meanwhile, I'm still trying to relax after this mornings maiden!
A new FJU with fiberglassed body, A spec Nanotech 6s, Tgy SK3 with a 6.5˛ prop.
Still gets my attention 1st flight w/the A spec for me - hope it holds up. Sure worked well in flight.
ciao,
Stan ......... or .............. Dave,
I hope you broke those LiPo's in and didnt run a brand new LiPo that wasnt broken in ??
moparmyway is offline Find More Posts by moparmyway
Old Oct 06, 2012, 04:00 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by sebbe View Post
I dont know, I would say, fly it stock, dont think anything will fall apart, I think if we all put a cam to look at our planes in action during flight, we would probably reinforce many things, maybee to much..
Sebbe
I've seen vids of moulded gliders with rear facing cams and they can suffer with the vert stab flexing too. Possibly the horizontal stab helps by giving more leverage to it, but it's still visible.
feefo is offline Find More Posts by feefo
Old Oct 06, 2012, 05:27 AM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
I coated my FJU's with varnish for wooden floors (water based) after the initial plastic primer and color coat.
Be sure to coat both sides in one go, because of shrinkage. Otherwise she will warp.
The airframe is notably stiffer and not to heavy after the varnish coat.
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old Oct 06, 2012, 12:16 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I don't break my batteries in..and they don't last long..
Might there be a connection? Perhaps I should start!
stanordave is offline Find More Posts by stanordave
Old Oct 06, 2012, 08:58 PM
zeus3313 is offline
Find More Posts by zeus3313
United States, FL, Port St Lucie
Joined Jan 2010
What speeds am I looking with this combo?
Himax 3514 2900KV APC 6x5.5E Pheonix ice 75
What battery should I be using?
Thanks!
I belive the MPi website states with 3s 700 watts 54 oz thrust does that help?
zeus3313 is offline Find More Posts by zeus3313
Old Oct 06, 2012, 09:57 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Thanks!
about 115 mph in a dive .
THESANDMAN is offline Find More Posts by THESANDMAN
Old Oct 08, 2012, 01:42 AM
War Machine is offline
Find More Posts by War Machine
Joined Oct 2008
Mike, Are you using the 1900kv SK3?
How many Amps does it draw with a 6S and 6.5X6.5 ?
Sebbe,
Good point!
ciao,
War Machine is offline Find More Posts by War Machine
Old Oct 08, 2012, 10:33 AM
stanordave's Avatar
Joined Jan 2006
yes its the 1900kv
amps? don't know. haven't bother to measure. everything comes back warm but not too hot, and others are flying with the same setup so haven't worried about it.
Old Oct 08, 2012, 05:41 PM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Grtz René
So do you spread it on very thin? Any notice in extra speed or aerodynamic advantages? Is your landing speed increased?
setxws6 is offline Find More Posts by setxws6
Old Oct 08, 2012, 06:22 PM
186mph Funjet Ultra
Joined Feb 2010
setxws6
I spray it on very lightly, it has no aerodynamic advantage, with the uncoated airframe you will get a 50Hz buzz at around 186mph, we discovered that it where the vertical fins vibrating.
And it is more responsive on the controls when the airframe is stiffer.
It adds the same weight as the original stickers, but they give no extra stiffness.
I don't sand the airframe because it will soak up paint and add to much weight.
Grtz René
Old Oct 10, 2012, 03:42 AM
moparmyway's Avatar
New York
Joined Jan 2009
Got 2 Turnigy 3659 Super EDF motors yesterday (1900kv advertised)
- measurements between phases and each motor differ
-#1 has resistances of 0.0116 / 0.0126 / 0.0134 (2 poles) (averaged to 0.0125)
-#2 has resistances of 0.0128 / 0.0138 / 0.0132 (2 poles) (averaged to 0.0133)
#1 weighs in at 8.875oz
#2 weighs in at 8.835oz
-motor is a 2.5 "D" winding
-motors are super easy to spin over .......... are there magnets in there ?
-4 pole inrunner
-36x60mm
- stated resistance of 0.011
- shafts are slotted
-3.5mm bullets already installed (although I am sure nobody has been flying on 6 cells without swapping for bigger bullets)
Rim,
Yours (#2) will be on its way in a few days, so have at it ................ and please fwd me the .csv files
Also gunna test some props later this week, maybe even try getting in a few flights (fat chance on that)
Old Oct 10, 2012, 01:17 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Ought to be some interesting test results.
cjbucher is online now Find More Posts by cjbucher
Old Oct 10, 2012, 02:04 PM
THESANDMAN's Avatar
Joined Oct 2010
im waiting on the ups guy now .for my sk3 as i type . it must have been shipped on the same boat . although mine isnt going to get installed for a while , got too many thing going on right now . and im still waiting on my mega motor.
either i missed something or it hasnt been done , but i havent seen anything on the sk3 with a 5 cell battery "only 4cell and 6cell" .
what do you guys think the performance on the sk3 ,would be on a 5 cell ?
Old Oct 10, 2012, 06:20 PM
zeus3313 is offline
Joined Jan 2010
found it..
Old Oct 10, 2012, 07:14 PM
moparmyway's Avatar
New York
Joined Jan 2009
Things just didnt seem right, so I took off the heatshrink and bullets, then re-measured the resistances ............... results speak volumes for HC soldering QC ........... I humbly suggest everyone who gets a Turnigy motor re-heat their bullets and make sure of good soldered joints
No bullets:
#1 motor ......... 8.755oz ..... 2085kv actual ..... 0.0122 milli-ohms resistance (2 poles)
#2 motor ......... 8.720oz ..... 2100kv actual ..... 0.0121 milli-ohms resistance (2 poles)
No load kv was done on ICE and Eagletree at the same time, if anyone wants the file.
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
