Old Sep 23, 2012, 09:41 AM
ILLSMOQ
KURTIST's Avatar
United States, CA, San Jose
Joined Dec 2004
Originally Posted by johnnyrocco123 View Post
Any suggestion on what prop to to try on a 5s setup with a Mega 1640/1.5RC ???
I have finally had enough of 4S
I ran a graupmer 6.5x6.5 on mine. I did burn the motor on this set up on 5 cells but I was making back to back runs with out cool down passes
KURTIST is offline Find More Posts by KURTIST
Old Sep 23, 2012, 09:42 AM
ILLSMOQ
KURTIST's Avatar
Joined Dec 2004
Speaking of burnt motors...what should I do with a burnt mega?
Old Sep 23, 2012, 09:56 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Hey thanks for the info. Sorry about your motor. I guess I will try a 6x6 graupner.
You need to ship that motor back to Mega. I'm not sure of the details, but someone will chime in and tell you the correct shipping info and procedure.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 23, 2012, 01:01 PM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
What MEGA burned ?
What do you want, a replacement, a different one, sell it as is .................... ?
moparmyway is offline Find More Posts by moparmyway
Old Sep 23, 2012, 01:26 PM
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
If rebuilding it, consider other windings if you can change cell count.
You will increase power and robustness.
My 16/40/1.5RCE just got rebuilt into 16/40/2 F5D CE 100K
I look forward to 6S, and 7S testing in next couple of months....maybe 12-20+ props on each cell count. I need low priced quality cells to put in series.
Even though I went for 100K bearing upgrade, Mopar went for Boca Ceramic Hybrid option from Mega (oiled).
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Sep 23, 2012, 01:36 PM
ILLSMOQ
KURTIST's Avatar
Joined Dec 2004
I'm looking at building some kind of hot liner so maybe have it built into something for that? Or maybe get one of the Mach fans and put it into a habu 2 or something...? Im onto the 36+ mm stuff for the strykers and funjets. Who do I contact to send it in?
Thanks!
Old Sep 23, 2012, 01:37 PM
ILLSMOQ
KURTIST's Avatar
Joined Dec 2004
Originally Posted by moparmyway View Post
What MEGA burned ?
16/40/1.5rc
Old Sep 23, 2012, 03:05 PM
PJRono's Avatar
Ham Lake, MN
Joined Jun 2003
I've thought about some new 65C batts in the 2600 mah range might do it. I don't want to go bigger with the prop as I can hear the motor/battery is at it's max rpm when full battery and then tapers as it gets used up.
PJRono is offline Find More Posts by PJRono
Old Sep 24, 2012, 03:55 PM
Joined Feb 2009
Well take a look at post 5865 for some pics of how the heat treatment / paint can turn out... I'm still impressed.
yellowcolorado is offline Find More Posts by yellowcolorado
Old Sep 24, 2012, 04:12 PM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Is this an 'oops wrong thread' post?
Maybe for the DF?
feefo is offline Find More Posts by feefo
Old Sep 24, 2012, 05:37 PM
Joined Feb 2009
LOL yeah my bad.
Old Sep 25, 2012, 02:48 AM
Joined Oct 2008
Can someone please suggest how to place the aurora 9 channel Rx antenna in the FJ ?
I was going to install the Rx in the nose and run the antenna down the length of the fuse but the manual states to keep away from batteries.
War Machine is offline Find More Posts by War Machine
Old Sep 25, 2012, 04:51 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Any chance you can put the rx in the nose but run the antenna externally? I know the Hitec rx's have a slightly wierd antenna so it might cause probs.
IF you're struggling to come up with a solution, stick it where you were going to but do a few range tests. MPX advise their antennas are at 90 degrees to each other, which is virtually impossible in all of my planes, but I haven't had a prob when I don't do it like they advise.
Old Sep 25, 2012, 08:17 AM
Joined Oct 2008
I could possibly do that. It may be the only option. Hopefully someone else here uses the 9ch Hitec Rx in their FJ.
Old Sep 26, 2012, 07:21 AM
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
Might not help with your 9 channel question, but i never had a problem with my 7 channel antennas being right beside the batteries, in several planes including my f/j
dmaaero is offline Find More Posts by dmaaero
Discussion Funjet Ultra, more fast more fun.... tbmg1 Video Piloting (FPV/RPV) 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer Video Piloting (FPV/RPV) 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
