All,
thanks for your inputs! I have also ordered a 2200KV 2836mm outrunner, that will run off 4S if need be. Going to higher voltage means that the current will drop for the same power. Also ordered a 3000KV 2836 outrunner, since I have far more 3S LiPos than 4S LiPos. Since I have been advised not to stir up the efficiency debate, I'll just conclude, that at least outrunners are better cooled than inrunners ![]() Basically, my style FPV doesn't require anything special, I just a plane better suited for the prevailing, strong winds in my part of the world. I believe a even a slow flying FJ will do the job
I ordered 2 of these SK3 1900 kv motors today. Expect to see one after I have taken a resistance reading and no load kv test. I wont prop test the motor coming your way, so you will have a BRAND NEW one to hit with 6 cells and a 6.5x6.5 prop. I would rather you fly it due to my 90-95 deg F temps, as I believe it will burn or be close to burning with a healthier battery and warmer temps, so your 50-55 deg temps beat mine .................. so long as you dont mind getting in some extra flights and a few minutes putting on bullets and swapping over to this 4 pole beast !! |
You might very well like your 2200kv motor with a 3 cell and an APC 7x5E prop. Shouldnt be too fast and should have plenty of thrust !! Should be between 80-90 mph straight and level @ full tilt if your motor has decent efficiency |
With a 4 pole spinning over 30k ...(not just the SK3)........ there might be even more of a speed difference between diving and straight and level. |
Looking forward to it!!!!! |
Yeah it was used by 'a few' on the original FJ, but so was the 3200kv (3s @5.5x4.5 prop). I liked the 2350kv because it was quiet, the 3200 was a screamer. 2350kv on 4s was similar to the 3200 on 3s IIRC. Never tried different props myself, but I think you could go a bit bigger with a sport prop, maybe 6.5x6.
Look at the pictures with additional cooling, I think is helps the motor and ESC quite a bit. The only worry on 5S for me was the bigger prop to get the watts, and the negative effect on torque roll, and would I get the RPM's needed for fast speeds? I did not try it though, so it may work out just fine. Mine balances perfect, but not a lot of leeway with motor weight and battery weight, for now they match perfectly.
I have been meaning to ask you ............. kept forgetting ![]() Your cooling holes, are they straight in @ 90 deg angles, or did you set them on different angles to try to draw air in or out ? Any way to post them up again, maybe some more so we can see the details easily ? The hole you show does look angled ??? |
YOU STATED IN THE BEGINING OF THIS REPLY (I know for sure, numbers in level flight is data we can use and make some comparising) WHO IS WE WHO CARES WHAT THIS WE PERSON OR PERSONS WANT AND WHAT THOSE WE WANT TO COMPARE IT WITH . HMMMM AND THEN CONSTANTY ASKING AGAIN AND AGAIN AND AGAIN . AND AGAIN AND AGAIN . OOOH WE JUST WANT A LEVEL FLIGHT , THAT IS ALL THAT IS COMING OUT OF YOUAND THESE "WE".PERSON OR PERSONS . IT MAY NOT BE BULLYING TO YOU BUT TO ME IF SOMEONE KEEPS ASKING ME TO DO SOMETHING I DONT WANT ITS CALLED HARRASSMENT ( SORT OF LIKE BULLYING) |
Latest blog entry: Rainbow f3a
Denver, CO
Joined Nov 2007
Well...on a lighter note
![]() I mounted my eagletree speedo and it said I went over 3000miles an hour this morning on my first flight. So either that is incorrect, or I have the fastest FJ in the world and I'm competing with the SR71. I'm not sure why it was reading stupid but oh well, got a couple more flights in. I'll update on how much flight time I'm getting as I go, but so far I'm limiting it to 4mins and it seems I'm putting back in around 2000mah in my 3300mah pack. But I'm going to test somemore before I start extending flight times.
| Thread Tools | |
| Discussion Funjet Ultra, more fast more fun.... | tbmg1 | Video Piloting (FPV/RPV) | 34 | Jul 28, 2010 08:36 AM |
| Discussion Muliplex EasyStar | WBFlyer | Video Piloting (FPV/RPV) | 9 | Mar 10, 2010 03:09 PM |
| Sold muliplex ASW 27 NIB | bushpilotx1 | Aircraft - Sailplanes (FS/W) | 7 | Aug 31, 2009 05:41 PM |
| Question Muliplex Alpha Junior Radio Instalation | Allan Glover | Sailplane Talk | 3 | Apr 09, 2004 01:37 AM |
| Muliplex MultiCharger 4010DC - is mine faulty ? | borgs | Batteries and Chargers | 0 | Jul 12, 2003 07:01 AM |
