Old Aug 06, 2012, 03:33 AM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by feefo View Post
I'm pretty sure Bec voltage is 6.1v as you recommended Morpar.
Fleaflo,
Try and go down to 5.7 or 5.8 and see if it helps.
I have seen a few glitches at the LHS, mostly when voltage was set to default, that got cured when the voltage setpoint was changed, usually by going up.
moparmyway is offline Find More Posts by moparmyway
Old Aug 06, 2012, 04:20 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Yep, changing the voltage helped but it took 3 attempts , 3rd was putting it to factory setting of 5.1v. I've tried different voltages again and it doesn't glitch so it seems ok, sticking with factory setting for now. But I'm not sure if I trust it enough to fly.
feefo is offline Find More Posts by feefo
Old Aug 06, 2012, 06:39 AM
moparmyway's Avatar
New York
Joined Jan 2009
Me too.
BUT
Willing daredevils @ my LHS have said not 1 single glitch again, some have "hundreds of flights" and actually pull out their planes and throw them up in the air, right there in the back parking lot.
Old Aug 06, 2012, 07:41 AM
sebbe's Avatar
Sweden
Joined Feb 2006
http://www.youtube.com/watch?v=z0pD7lgPSAo
fastest ultra ? 228mph
sebbe is offline Find More Posts by sebbe
Old Aug 06, 2012, 09:12 AM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by G-Forse View Post
--On the topic of speed, here is an 1800 watt F-16 -- Ultra would smoke it with the same power
--:40 and 1:05 seem to be the fastest passes -- high 140's -- low 150's -- with aft cg, cooler day, fresh pack, and perfect run, may reach high 150's -- 160's at sea level
--elevation 5200 ft at 80 F --at altitude, speeds seem to be a little slower than sea level
--Notice no torque roll on launch -- courtesy of ducted fans -- it did torque on the go around because I punched the throttle at low speed and it has a an outrunner
What EDF are you running ?
Old Aug 06, 2012, 09:25 AM
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Originally Posted by GryphonRCU View Post
Billy,
I read about both of the motors in different posts, not sure which one you are starting out with(I lost track).
Does not make a difference to me....but you might not want to use a prop with enough pitch to make the plane very high speed capable "on a maiden flight".
So double check your static data by sending it Rim or other friends for review.
No need for aggressive prop during maiden....even if you intend to use lower throttle setting.
Gryphon
Howdy Gryph!!..Startin out with the 16/45/1.5...Rim has me set with the right prop......Dropped my wattage down from the prop I was gonna use..on Static test...our last day of heat was 107....now we're back in the low 90s...if the Maintenance crew is off the field gonna just get the feel with one good run then bring it in to see how the heat is...I like to baby my motors first and see how they take the heat rather than go all out...will do my usual 1 min. and 30 sec. flight...
Hope to receive my new FJU today....than I'll start work on the 16/30
Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Aug 06, 2012, 10:29 AM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by sebbe View Post
WOW !!!
I cant doppler that one ........... 228 is the fastest yet !!!
Old Aug 06, 2012, 12:37 PM
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by moparmyway View Post
WOW !!!
" ... faster then anything we flown,, I dont care whet that thing says "
1 min 40 sec into the video
well "that thing" (Velocity GPS) said 228mph
Old Aug 06, 2012, 01:07 PM
Raleigh, NC
Joined Sep 2004
Must not be from that video.
I saw some 140's from the doppler. Nothing anywhere near 228. Did you link in the wrong video?
Oh wait. Did you mean 228 kph? Because that would be 141 mph.
cjbucher is offline Find More Posts by cjbucher
Old Aug 06, 2012, 03:52 PM
sebbe's Avatar
Sweden
Joined Feb 2006
is says under the video:
This is a 228 mph speed run with my Funjet Ultra. I captured the speed with a Velocity RC GPS.
maybee he did write wrong ? but I think he meant 228 MPH, as it seems to be filmed in usa, they dont use km/h(kph)..
Old Aug 06, 2012, 03:58 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Did it really seem to be that fast?
Do not believe everything you read, Sebbe
www.youtube.com%2Fwatch%3Fv%3Dt3KkuCelG88&ei=XzAgU PueBuPk4QTwyID4DA&usg=AFQjCNH7NMiscGK1RbVQfwHMpi73 tl6Bsg
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Aug 06, 2012, 08:31 PM
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
Is there an original funjet thread or do most just hang out here? I remember yellow colorado had one but i can"t find it anymore.
dmaaero is offline Find More Posts by dmaaero
Old Aug 06, 2012, 10:43 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
HS-5065mg's
Does anyone here have any experience positive or negative with these servos?
I have read horrible reviews, right after I bought some. Never used them before, but hard to believe they could be crap.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Aug 07, 2012, 12:15 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
rimripper is offline Find More Posts by rimripper
Old Aug 07, 2012, 02:41 AM
sebbe's Avatar
Sweden
Joined Feb 2006
http://www.youtube.com%2Fwatch%3Fv%3...fwHMpi73tl6Bsg
I hope you say this as a joke ,, OF COURSE I dont believe it, was meant as way to show there ae many speed claims out there that are totally wrong
Discussion Funjet Ultra, more fast more fun.... tbmg1 Video Piloting (FPV/RPV) 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer Video Piloting (FPV/RPV) 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
