Old Jul 31, 2012, 10:55 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
Originally Posted by gchrisgo34 View Post
heres some pics jeff. as you can see, as always, ive spent a lot of time to make sure they're done right. the ultra is good for high speeds, ive also run hinge tape along the whole hinges, on both sides. id say its probably ready to do at least 150. theres your old original, got a few more scratches & dings since this picture. might have to glass it soon.
what kind of paint did you use on that fun jet and is it glass?
onefastxp is offline Find More Posts by onefastxp
Old Aug 01, 2012, 12:21 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
Originally Posted by GryphonRCU View Post
gchrisgo34,
Regarding Gary's mount on your Stryker:
http://www.customrcparts.com/index.p...products_id=58
Mopar helped develop that mount by working closely with Gary....and Mopar did all of the flight testing and gave various feedback to Gary for optimizing of that mount.
It is the VERY best Stryker mount EVER!!!!!!
Many of us have multiple Stryker mounts.
One of mine is bolted to a test stand.
Sometime after initial release Gary was able to drop the price by reducing his CNC machining costs. He then decided to refund that difference in price to every person who had previously bought the mount.
Gary is a standup guy.
Gryphon
sounds like he's a great guy. doing a lot of good things for the hobby! thanks to mopar as well. it definitly is a first class mount. quality is superb.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Aug 01, 2012, 12:24 AM
gchrisgo34's Avatar
Joined Nov 2010
TESTORS, plastic model paint. THE BEST paints to use with foam. doesnt eat foam, covers very well, & adds practicly no weight. took me awhile to find the perfect paint for foam, and its TESTORS. & no, none of these models have been glassed.
Old Aug 01, 2012, 12:30 AM
gchrisgo34's Avatar
Joined Nov 2010
heres some birds ive painted with TESTORS, as you can see, it doesnt eat foam at all. the green is rustoleum florecent green
Old Aug 01, 2012, 07:06 AM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
Got to 215.0mph today!
Yup, 194mph on the level, (with the wind), 215mph in a good dive, not a monster dive. More props coming for testing, will try for 200 in the level. Handles very, very nice, no issues. Not too many have I seen go this fast, (no matter how they got there). Just under 3.4 pounds, (54.3 ounces)
  • Motor: Turnigy 3659 1900kv SK3 Fandrive
  • Propellers: APC 6.5x6
  • Controller: SS Hobbyking Series 190-200A ESC
  • Servos: HS-5085MG, (overkill maybe, required a bit of cutting to fit well)
  • Rx: AR600, (one antenna forward into the fuse, the other in the fuse along the side and out under the wing).
  • Battery: Lipo Turnigy 6s Nanotech 2700mah 65/130C, (just fits)
  • Battery connections: HXT 4mm, (I have the castle 5.5mm, 6.5mm, did not use just yet)
  • Rx Battery: Hyperion LIPO 350mah, 2S, 25/50C
  • Rx Regulator: Voltron 6V 10A
Mod's
  • Epoxy, no CA
  • Carbon horns, taller, stronger. (Tied in with carbon rod, topped with carbon plate, all epoxied).
  • 2-56 control wires, (much bigger/stronger than stock.
  • Z-bend on one end, L-bend with retainer on the other end.
  • Metal motor mount, (I think plastic would be fine, but I had the metal one).
  • Cut small slots into the fuse sides to fit battery strap flush and not bow the fuse when battery is installed.
  • Replace stock Velcro and strap with OEM Velcro
  • Cooling added for ESC, (above ESC)
  • Gorilla Tape on bottom for landing
  • 3M Grip tape for launching.
  • Epoxy filled above the wing carbon tube, for strength and drag.
  • Taped both sides of hinge line with fiber tape.
  • 3 piece turtle deck, magnets to hold on center piece.
  • Cooling holes in front of motor, (Carbon tube cut at 45 on both ends, epoxied in)
  • 6 pieces of 1mm carbon rod x 4 inches pushed into rear foam before gluing plastic motor mount, (adds no weight and a LOT of strength).
  • Taper lower part of vertical fins into wing, (less drag in air and on grass).
  • Used glider servo covers, (no binding, needed for taller horns).
  • Hogged out foam to fit motor and improve cooling.
  • Hogged out some foam under canopy to fit battery.
  • 3mm x .7mm carbon on back of all horizontal surfaces, (CA'ed, then CA filled, then sanded).
  • 2 coats Rustoleum paint, 2 coats spray shellac.
215mph Funjet Ultra Very Fast (3 min 39 sec)
markusvt is offline Find More Posts by markusvt
Old Aug 01, 2012, 07:14 AM
dmaaero is offline
Find More Posts by dmaaero
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
I"d like to run something by you. I run a 2700kv six series 6x4 sport on 4s. I have a 2650kv outrunner edf motor that runs on 4s but the guys have been having great success with it on 5s with there edf"s. My question is can i put a prop on it an go to 5s an have more power than my six series i run now? kv x volts shows allmost 20,000 more rpm but i don"t know if the outrunner makes the power the inrunner does. I don"t know much about motors, i just like to go fast.
dmaaero is offline Find More Posts by dmaaero
Old Aug 01, 2012, 07:34 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Why not just put on a 6x5.5 prop on your 4 cell 2700 setup ?
You can run 5 cells with your outrunner, but your prop size probably wont be ideal, and you will make alot of power, you just wont have the thrust to take advantage of all of your power.
Your 2700 could also run on 3 cells with a 6.5x6.5 prop.
You sure about that 20,000 more RPM ?
moparmyway is offline Find More Posts by moparmyway
Old Aug 01, 2012, 07:36 AM
moparmyway's Avatar
New York
Joined Jan 2009
Markus,
Congrats on your flight !
Thank you for clearly stating with the wind, and when you dove. Thats a FAST FJU !!!!
Were the sirens and the comment "here they come" meant like ................ here come the coppers, .............. run !!!! ??
Old Aug 01, 2012, 07:45 AM
markusvt is offline
215.0 MPH
markusvt's Avatar
Joined Jul 2007
The RPM's really picked up on the 215mph run! I have 1 more prop, then that's it for this bird. Everything temp wise is still good, but not sure how much more I should push a foam plane with no glassing and foam hinges.......
Old Aug 01, 2012, 07:46 AM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Originally Posted by Waverunner View Post
They make a 2,000 and 3,000, very good motors. They can take the abuse. I tried the 3,000 but was not very user friendly on a 3 cell 2200 bat. even with a 6 x 5 battery
Waverunner
I've had a half a dozen Six series motors on Pylons....they can't take abuse...they will burn...at least mine did...that was several years ago...both 2200 and 2700KV..Stay to Specs....or they will heat up......
Unless they've changed ....don't go over specs.....Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Aug 01, 2012, 07:56 AM
dmaaero is offline
dmaaero's Avatar
Joined Jan 2010
Mopar you know me i"m not sure about anything, here"s how i figured it.
six motor 2700x11.1=29,700
edf motor 2650x18.5=49,025
Oh i see what i did now, i compaired a 3s to a 5s
2700x14.8=39,960 thats only 9,065 increse in rpm not 20,000
thanks for keeping me straight,
I could try the 6x5.5 on 4s an the 6.5x6.5 on 3s or i could just ask you which would be faster? thanks for your time an help. david
Old Aug 01, 2012, 08:46 AM
moparmyway's Avatar
New York
Joined Jan 2009
I think they would be about the same on a straight and level run.
The 3 cell 6.5x6.5 would probably appear faster to you due to the superior acceleration of the 6.5" prop ................... and both setups are right at the point where you should use throttle controll and check motor temps to be sure your ambient air temps dont cook anything.
Pitch speeds are just about the same, so its really a choice of preference for you. Please just remember to make sure of the motor temps, the FJU has less cooling than the plane I tested my six series motors on.
Old Aug 01, 2012, 08:47 AM
moparmyway's Avatar
New York
Joined Jan 2009
Billy,
Do you remeber cell count and prop size related to each motor when they burned ?
Old Aug 01, 2012, 10:08 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Can anyone confirm Runnikee's motor's kv?
-MEGA 16/25/2 CE
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Aug 01, 2012, 10:44 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
I get a no load of 2356kv on my 16/25/2CE F5D.
feefo is offline Find More Posts by feefo
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
