Espritmodel.com Heli Air
Old Jul 27, 2012, 01:31 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Originally Posted by stanordave View Post
I've had a "few"Funjet Ultras ( 5! ). On the last few, the controls horns seem to be breaking real easily. Had one break this AM when doing an engine run. My flying buddy had his break on the maiden when landing. Different design or just bad luck? Whatever, I'm cutting them out and putting in something else tonight...
It always helps to rough up the bottom of the plastic horn before bonding it in place with a good quality medium viscosity cyano, NOT foam safe!
Ben D Wing is offline Find More Posts by Ben D Wing
Old Jul 27, 2012, 02:34 AM
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by Piledriver View Post
Had my own tragedy today. Third flight on my Funjet Ultra and the unreinforced elevon tore loose causing a wild spinning crash. Airframe is totally ruined but luckily all my electronics survived. Hit the ground at a low enough angle that the right wing took the brunt of it and the canopy popped off and battery, esc and receiver followed it across the soccer field.
I'm bummed. I assume this was a fluke or do the elevons need a reinforcement on the hinge line?
I've had several Funjets and never experienced anything like this.
yes, reinforce the hingeline, best is with crossweave fibertape, clean with alcohol beforem then put it on over and under, will never tear apart again..
Also the original plastic horns, I dont know why you are flying with these when over 4s lipo and 1000 watts, i always make my own horns. other then they can loose up in air, the bad parts are: the geometry and that thin linkage wire, not for high speed at all, it will flex...
put a stronger horn, thicker wire(and some good clevis), reinforce the hingelines, then it will be ok.
sebbe is offline Find More Posts by sebbe
Old Jul 27, 2012, 03:40 AM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
I like to rough up the elevon and horn with some sand paper,then glue in place,mine are hiding up good with large amounts of power going through my FJU.
Long grass can tend to be the culprit on the horns when landing also.
rimripper is offline Find More Posts by rimripper
Old Jul 27, 2012, 07:30 AM
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Howdy Gryphon... Rim was lettin me know bout the readings on the graph....thats what I did, was move the mouse down a bit as the spike lowered...Thanks!!!!...ordered some more props for static testing...
If I was you fellas having problems with the linkage tearin away from the elerons...I'd switch over to the top side...I have, and it stopped those Tragedies...Grass and ground strikes can weakin the systems when landing....on original installations...I think its just an accident waiting to happen with undersides control linkage when belly landing...and I also lock my elerons on with Tape..after several years of flying foamies of different Makes...I've Never had a Flap tear away...Never...Hope this info might might help..Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Jul 27, 2012, 07:48 AM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
I am very sorry your FJU got destroyed. If there werent any individual(s) disputing the unreliability of the stock hinge line, we wouldnt go through this. Read the following links and the posts that follow for details.
http://www.rcgroups.com/forums/showp...postcount=1995
http://www.rcgroups.com/forums/showp...&postcount=645
http://www.rcgroups.com/forums/showp...postcount=2006
http://www.rcgroups.com/forums/showp...postcount=2011
I could go on and on and on ...........................
moparmyway is offline Find More Posts by moparmyway
Old Jul 27, 2012, 07:56 AM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by Jurgen Heilig View Post
The turbine powered Funjets exceed those speeds at every flight. Enough said.
Jürgen
Jurgen,
Its NOT enough said !!!!
I will say it again and again untill the moderators suspend me, the stock FJU hinge line needs help !!
I suppose you still think that each individual who has had this problem was at fault themselves, eh ?
So far, this is like the 36th FJU that has suffered a torn off elevon with a stock - un-re-enforced hinge line that I know of. Maybe you ought to reconsider your adamant stand Jurgen, you are keenly aware that this is happening more and more, arent you ?
Old Jul 27, 2012, 09:47 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
78 flights on two Funjet Ultras - blenderm used on hinge line for peace of mind - No issues. Max speeds 146mph
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jul 27, 2012, 11:24 AM
almost slackin
Joined Dec 2005
I never had a failure with a Multiplex product on the hinge line before my Funjet Ultra the other day, they usually stood up to lots of abuse before requiring reinforcement. I've been out of the sport for awhile and didn't realize the Ultra was occasionally failing there, well I'll still buy a new kit and start over with some reliability improvements.
Mine was/ will be powered by an HET 2w-25, 4 cell 3300, 6x4 sport.
This definitely wasn't exceeding the envelope for this airframe so I'm still disappointed, but , if some slight reinforcement is all thats needed then I'm good with it.
My 3 flights were very good until......
Piledriver is offline Find More Posts by Piledriver
Old Jul 27, 2012, 11:30 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
I find it hard to believe they still include those thin pushrods as standard.
feefo is offline Find More Posts by feefo
Old Jul 27, 2012, 11:51 AM
moparmyway's Avatar
New York
Joined Jan 2009
Mine went down on my maiden flight.
All thats really needed is some help for that hinge.
Most Dudes are running 3m x-treme tape or 3m mailing and storage tape for the extra support that hinge line needs.
Installing aftermarket hinges like Robart or DuBro is allways a great idea, but most times, the tape is all thats necessary if you arent exceeding 160-170 mph.
Old Jul 27, 2012, 12:15 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Agreed Feefo,ditch them for some 2-56...
Old Jul 27, 2012, 01:27 PM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Well we got stuffed with the metric system so 2mm is what I use normally as it's the easiest to get.
Old Jul 28, 2012, 02:04 AM
kayvannouri's Avatar
United States, TX, Dallas
Joined Aug 2011
question,
I am thinking about cutting the vertical stabilizers of my funjet and replace it with 3mm carbon fiber sheet, then if I feel a little difference in performance, I can also shave the front (about 1 inch) from tip of the wings and reinforce it with a long sheet of 3mm carbon fiber, its gotta be about 2"x10"x3mm, perhaps this will reduce the drag and make it go a little faster,
any thoughts on that ?
kayvannouri is offline Find More Posts by kayvannouri
Old Jul 28, 2012, 02:37 AM
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Originally Posted by kayvannouri View Post
question,
For a $100 frame I think it is already fine the way it is.
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Jul 28, 2012, 04:03 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Maybe servos aren't 100% secure, or there is backlash in the gear trains, or there's slop in the pushrod 'Z' bend where it enters the servo arm. Any of these could cause flutter and thus fail an otherwise perfectly adequate hinge. Mishandling the airframe in transportation or unsympathetic storage could also stress the hinge line. These are all valid reasons for possible elevon failure.
Discussion Funjet Ultra, more fast more fun.... tbmg1 Video Piloting (FPV/RPV) 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer Video Piloting (FPV/RPV) 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
