Old Jun 12, 2012, 10:24 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I get everything delivered to work or my rent house these days.
You gotta be crafty around the wifey.
I maidened my new Funjet yesterday. IT was nice.
Went with my [B]4S/HET 2W-30/APC 7x5 sport setup
I also got a chance to try out my new 65C TP pack. Came down cool. I will take it easy on it for the first few flights. But I should have plenty of head room now.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 12, 2012, 10:27 PM
matjon is offline
Find More Posts by matjon
matjon's Avatar
Sverige
Joined Oct 2007
Originally Posted by FLAME747 View Post
Matjon I recommend that you prop up, in small increments, going from 6.5X5.5 to 7X6 is to big of a jump, best to error on the side of caution.
Originally Posted by GryphonRCU View Post
matjon,
I saw your 2 flights at a quick glance (ICE File).
Did you recharge the same pack, or do you have 2 different packs?
I like the cell size that you are using....They are holding pretty good voltage under load (at least for now).
Also looks like you are only using 50-60% of pack capacity before landing. I'm sure your packs love you for it.
Consider adding throttle position to your logged data options.
Seeing higher voltage together with lower power and RPM from 570-575 second time period made me want to see if you were at full throttle or not...but it was not logged.
If you have 6.5X6.5 fly with it before 7X6 just so you can compare speeds and motor temps besides the data from ICE files.
Also consider posting your static data from 7X6 before flight (Read data from 1-2 second after initial meaningless peak AMP spike).
Start at with motor at room temp and do a 3 second test.
If you fly with 7X6 first, land after 2-3 passes and check motor temp to start getting an idea of what you can do.
At higher power levels compared to todays flight, use more throttle control and/or gliding around inbetween your full throttle single passes.
You better have heat sink and make sure motor's air passages are not blocked by motor mount.
Have fun,
Gryphon
Dont have any other prop on 6.5, do have a 7x5 and 7x6. But Ill be careful and using throttle control
Recharged the same pack. Yes it is a good pack, true 40C for the whole pack.
Will add throttle position data on the ICE for future flights, dont know why I dont have it.
Will do a static test first.
Heatsink is mounted and remember that Im in Sweden and Im flying in the evening. Yesterday we had like 16C (60F) in the air. I have the regular smallpartscnc mount but have ordered the Mega 16 mount for better airflow.
Thanks!
matjon is offline Find More Posts by matjon
Old Jun 13, 2012, 08:26 AM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
Johnny
What numbers are you getting with this setup? How's the torque roll? Crashed the freakin enigma on a bad launch......debating on whether to build it again.....maybe put it on variable throttle to launch...
-Dave
UOTE=johnnyrocco123;21882068]I get everything delivered to work or my rent house these days.
I also got a chance to try out my new 65C TP pack. Came down cool. I will take it easy on it for the first few flights. But I should have plenty of head room now.[/QUOTE]
hidaven is offline Find More Posts by hidaven
Old Jun 13, 2012, 11:43 AM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
feefo,
Sorry to read about your crash. Hope you get back up in the air soon and start having fun again.
Did you get to run any high load 3S props before the crash?
Any 7X7 sport passes?
Gryphon
I was sticking to the 6.5 x 6.5 APC. I maidened the rebuilt motor on a Gaupner of the same size, and then tried the APC after that. This time the APC seemed to perform better than the Graupner, maybe the old motor was struggling more than I/we realised when I said the Graup seemed as good for less amps. Flight before the crash with a fair amount of WOT and crusing had the motor at about 28c after landing. Thought I'd cooked it last week but turns out it was too much cruising and I took too much out of the pack and it was dropping into LVC under load.
Just in case I order another soon, I've taped the FJU up and hung it back in it's normal place. At least the wife won't notice it's missing.
Carbon rod could be an option, although I have another 'plan' for the next one.....
feefo is offline Find More Posts by feefo
Old Jun 13, 2012, 02:39 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Feefo, the carbon rod is a proven method of reducing the nose from breaking off, I've crashed and built more FunJet Ultras than anyone else on this thread, so I know what works. Just my 2 cents
FCA
Glassing, using carbon fiber cloth, or "the heat treatment" will not prevent the nose from breaking off
Use at least a 5mm thick wall cf rod
FLAME747 is offline Find More Posts by FLAME747
Old Jun 13, 2012, 03:39 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Ok, cheers for the heads on that Flame. I'll put the effort in and add it when I get the next 1.
Old Jun 14, 2012, 07:55 AM
hidaven is offline
Joined Apr 2009
I have a 2w25 on 4s2200 40 to 90c. A CC 100 esc and getting about 138 level pass. I'm spinning an aeronaut 6x5. Can my setup take a 6x6 or 6.5x6.5 ????? I want 140-145. : )
Old Jun 14, 2012, 12:13 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
6x6 possibly,
6.5x6.5 ............... I doubt it
moparmyway is offline Find More Posts by moparmyway
Old Jun 14, 2012, 02:13 PM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
Motor rated for 1100W and 70A max.
With a good battery, you are likely close to 1100W now.
New Required Power = Old Power (New Speed/Old Speed)**3
145/138 = 1.051
1.051 cubed is 1.161
1.161*1100W = 1277W.
Doable, in bursts, with good cooling, (fins and cooling holes).
Calculator says
6x5 = 1090.
6x5.5 = 1152.
6.5x6.5 = 1480.
6.5x6.5 will have to be quick 1-2 second bursts. Go high, let her scream WOT for 5 seconds and watch for the white smoke.
markusvt is offline Find More Posts by markusvt
Old Jun 14, 2012, 02:42 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
APC do a 6.5 x 6, could be another option.
http://www.apcprop.com/ProductDetail...ctCode=LP06560
Old Jun 14, 2012, 04:29 PM
You down with EPP?
Houston, Tx
Joined May 2009
Hey bud, I have the 2W-25, but it has sat on the shelf ever since I picked up the 2W-30.
If you are going for 4S or 5S, I would definitely look into the 2W-30.
I flew mine today, and remembered that I am using a P125, so I don't have data logger. I can pull some static numbers for you if you are interested.
I am still spinning a 7x5 sport, but I am feeling pretty good about trying a 7x6 even in the heat.
Old Jun 14, 2012, 10:29 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--Run a 4s 3000 minimum
--Your at the limit of what the 2w25 will put out. Upgrade the motor and battery
G-Forse is offline Find More Posts by G-Forse
Old Jun 14, 2012, 10:45 PM
kayvannouri is offline
Find More Posts by kayvannouri
kayvannouri's Avatar
United States, MD, Columbia
Joined Aug 2011
I am defiantly interested to see the data from 2w30 on 4s and 5s, very interested in that motor
kayvannouri is offline Find More Posts by kayvannouri
Old Jun 14, 2012, 11:13 PM
You down with EPP?
Houston, Tx
Joined May 2009
I will do some static tests tomorrow and post with APC 7x5, 7x6 sport.
Torque roll is the usual, nothing to worry about, just make sure your cg is close.
Today I got 2 flights in. I threw out my arm playing softball, so my throws are junk right about now. It doesn't take a big toss
In fact, I will take some vid this weekend of the 2W-30 in action. I will make sure and get the launch on vid too.
Old Jun 15, 2012, 02:51 AM
matjon is offline
matjon's Avatar
Sverige
Joined Oct 2007
Static 16/40/1.5S on APC Sport 7x6
Finally balanced my 7x6 prop and did two static tests. Same battery with no recharge between.
Ive attached the file for anyone hows interested.
The amps peaked at 113A and then dropped down to 100A before I shut off.
The voltage dropped all the way to 17.4, but it should rise a little when the prop unload in the air.
I dont think this will be any problem for the motor. If I look at my last flight the amps should drop to about 90A.
Will hopefully fly it tomorrow and maybe shoot a doppler video to see what speed I have with this prop.
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
