Old Jun 08, 2012, 10:39 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by E-speed buff View Post
Torque roll at high power and speed is normal for a standard FJU around and above 150mph.
That is why I modified my FJU, to keep it flyable with a 2Kw+ drive system.
I found out that with a spot on C of G and the rim around the nose removed it was running at high speed without torque roll with 7in props.
I now fly with a carbon 7x11E prop ~175mph (0n 4S!) without torque roll.
Grtz rené
Are you running a 28mm motor with 7x11 on 4S?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 08, 2012, 10:56 AM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
No, a Turnigy T3648-1450 outrunner!
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old Jun 08, 2012, 10:59 AM
You down with EPP?
Houston, Tx
Joined May 2009
Grtz René
Ah, thanks.
I just got my 4S 3300mah 65C yesterday
Looking forward to some flights on my new Ultra. Haven't flow it since my mid-air.
Old Jun 08, 2012, 12:08 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
spcpicard...
I'm not sure if what I had was torque roll, but mine would roll to the left a little too. I figured I had built it slightly wonky , or maybe the left wing was slightly heavier as it would roll slightly when resting on the table (not sure if 'roll' describes it properly, more of a lean towards the left, sometimes it would roll off the flat belly, sometimes it wouldn't, depending on where abouts on the table it was put!!). I added a 7g weight (approx) on the rh wing, which has cured any probs when stationary, and in flight.
feefo is offline Find More Posts by feefo
Old Jun 08, 2012, 12:15 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by feefo View Post
spcpicard...
That reminds me, both of my orignal Funjets (white) used to torque roll at full throttle. It would take up to 40% right aileron to keep it level when running anything over 900watts or so.
I have never had that issue with the Ultra
Old Jun 08, 2012, 12:22 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
Just got off my ar*e and checked, closer to 2g on the wing TBH. Not sure why I thought it was 7g.
Old Jun 08, 2012, 01:30 PM
spcpicard is offline
Find More Posts by spcpicard
United States, LA, West Monroe
Joined May 2007
Its trimmed fine for half throttle or so, but at full throttle its like it needs to be trimmed more to the right, thats why i was thinking it was torque related. If i trim it for full throttle then when i slow down it pulls to the right. I also checked my horizontal thrust angle and it looks good also, maybe I should adjust it to counter the left roll.
spcpicard is offline Find More Posts by spcpicard
Old Jun 08, 2012, 03:00 PM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
I know on a small wing..and Big Prop....you git torque ...No gittin away from it...On Fast Trigger throttle...Mine will torque upon take off...but once I'm up to speed...Flies level...other than sometimes climbing..before I can Trim...I've got 3 FJs...all big motors...and all are the same symptoms.its a reflex of a Big propeller and Motor unloading on the Bird.....I have..and this will work..others say it doesn't...but works for me...trim right eleron up about 1/8" when ya launch...that compensates torque...then re trim after your going...The Nose Has Nothing to do with torque...Hold your plane steady in your hand and hit the throttle hard for just an instant..you'll see torque....thats what happens in the air...Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Jun 08, 2012, 03:02 PM
Rogersville, Mo
Joined Jun 2008
Grtz rené
You must be talking about Diving....I've heard the rim can cause the bird to dive...but torque....Not Hardly....torque is a reflex from the motor to the prop...Billy
Old Jun 08, 2012, 03:15 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
My Funjet goes 400 mph. No torque roll at all.
My setup?
A box with packing peanuts and a 2nd day air shipping label.
cjbucher is online now Find More Posts by cjbucher
Old Jun 08, 2012, 03:17 PM
Rogersville, Mo
Joined Jun 2008
My setup?
Now Your Talkin......Pass the Popcorn!!!...Billy
Old Jun 08, 2012, 03:40 PM
kayvannouri is offline
Find More Posts by kayvannouri
kayvannouri's Avatar
United States, MD, Columbia
Joined Aug 2011
Grtz René
are you running this on a 4s with 7x11 carbon prop ? how fast does it go and how many amp and watt are you pulling ?
kayvannouri is offline Find More Posts by kayvannouri
Old Jun 08, 2012, 04:04 PM
Joined May 2007
Im not refering to torque on take off, but full speed, my 1st fj with recommended motor would torque on launch, but it didn't roll at full speed.
Old Jun 08, 2012, 04:39 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Guys,
Regarding torque roll:
What about airframe strengthening mods for high speed.
Makes a difference regular FJ versus FJU.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 08, 2012, 05:12 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
....and this will work..others say it doesn't...but works for me...trim right eleron up about 1/8" when ya launch...that compensates torque...then re trim after your going......Billy
FlyBilly, it might work, the only problem I have with that is that you don't know for sure that you elevons are level once trimmed out after launch. It might fly level, but is 1 elevon slightly raised compared to the other? Personally I think it's better to launch with them level, trim for level flight, and then check where they sit after landing. You can work out what needs doing to keep the elevons level and give level flight after that. It's all personal preference tho, if it works for you then fair enough. But peer pressure says .....'set them level and go with the torque roll launch technique',.... go on.....you know you want to try....
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
