Old May 23, 2012, 01:46 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Originally Posted by MRGTX View Post
I have one of these 5x5 scimitar style props around...would this hold up to ~1000W?
http://www.valuehobby.com/accessorie...itar-prop.html
Both EMP and TRG (hobby city) make better 5x5 props. (the one in your link is an EMP prop)
Usually the rating is by RPM. You probably want to find the manufacturers rating on that prop and make sure it's within the limit of the RPM your setup generating.
cjbucher is offline Find More Posts by cjbucher
Old May 23, 2012, 02:08 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Originally Posted by cjbucher View Post
Part of the problem is that 5x5 prop (especially if it's an APC prop). APC makes great props but the 5x5 is one of their worst. It really was only made for fast pylon planes that have very low drag.
I'm not convinced it's that good on pylon planes either TBH. I've got a Simprop Turn Left (ok, only an F5D trainer) and the worst seemed to be the 5x5 when I used to run a Het 3W. I agree it takes a little to get going, but I'm not convinced it was any quicker than a 4.75x4.75. Launching was never a problem so I didn't try a 5.25x4.75, I figured it'd spin slightly slower so kept the square 4.75 on.
I'm not a fan of those EMP props either.
feefo is offline Find More Posts by feefo
Old May 23, 2012, 02:49 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
A few years ago I posted a thread in the Power Systems section about how terrible I thought this prop was. Many people agreed but a few of the high performance plane guys defended the prop saying it worked well in their application.
Also Dr Kiwi who does a lot of power system evaluations agreed that it was indeed a terrible prop.
Old May 23, 2012, 03:34 PM
feefo is offline
feefo's Avatar
Staffs, UK
Joined Apr 2009
I used to run the 5x5 on a TT Velocity (Projeti clone) with a 2700kv outrunner. At the time it seemed ok, and was visually faster than a 5.5x4.5. Maybe it does 'work' on certain motors and airframes, maybe a much higher RPM is needed to get the best from it?
I've also got the 4.75 (dia) x5.5 (pitch) pylon prop. Again it doesn't seem to work as well as some motor calc programs suggest it should. I think it might need the pilot to be more presise in turns to get the best from it, basically to keep the plane 'on song' the whole time or you lose the benefit of it?
Old May 23, 2012, 04:17 PM
cjbucher is offline
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
I did several tests with the 5x5 and the 5.5x4.5 and used doppler to compare. The 5.5x4.5 was consistently faster and had better acceleration. This was on a 2700 kv turnigy and a 40" flying wing.
Old May 23, 2012, 05:50 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Which prop is faster depends a lot on the airframe.
The higher the drag: advantage 5.5X4.5
The lower the drag: advantage 5X5
A certain tester used to test up to 30-35A on 3S-4S and "within" manufacturer "limits", I hope he has upped his game in last few years.
I think I saw some 50-60A tests while back.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old May 23, 2012, 06:54 PM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Gryphon
+1...On my Projeti it applies...its faster on 5x5........Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old May 23, 2012, 07:05 PM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
There is also graupner 5.2x5.2
rimripper is offline Find More Posts by rimripper
Old May 23, 2012, 09:52 PM
Rogersville, Mo
Joined Jun 2008
I'll look and see if i got one of those.....BTW....Benn workin on the Ultra....I went with Black on the ailerons as well as the fins....waiting on my Green Zagi tape to be shipped...I think you'll like the look Rim!!!!....Billy..
Last edited by FlyBillyFly; May 24, 2012 at 02:24 PM. Reason: Tape arrived today....
Old May 25, 2012, 11:37 AM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
I think my FunJet Ultra is too heavy, my motor weighs 369g!
Is there a point where the FJU is too heavy to launch, I hope to run 6s so how has every one coped so far?
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old May 25, 2012, 11:40 AM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
So did you just basically make a skin of tape over the airframe?
Runnikee is offline Find More Posts by Runnikee
Old May 25, 2012, 12:22 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
well it depens on how strong you are and how hard you can throw, maybee you need a bit of luck also... Mine did torque to death on a 155gram motor and 5s lipo, and I can throw hard and stright, didnt help..
Its like playing roulette ,, I wouldnt want a Ultra with a 369 gram motor on 6s and hand trow it.. but heck, try it, maybee you are lucky... I was lucky the first 3 times, then I couldnt throw it ,,, I tried 10 times before the airframe gave up..
My 4s funjet with a 120 gram motor is soooooo easy to throw..
sebbe is offline Find More Posts by sebbe
Old May 25, 2012, 01:08 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
If itís too heavy, and you are not comfortable hand launching, build a PVC launcher.
FCA
FLAME747 is offline Find More Posts by FLAME747
Old May 25, 2012, 01:45 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
What's your AUW?
369g inrunner is going to make you good power,I would just vertical launch it.
What size 6s are you packin?
Old May 25, 2012, 01:59 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
Mine is 3 lb 3 oz , thinking 1400-1500 grams, its a load but other then a little torque roll and hot landings its fine, never a bad launch.
snoshoe62 is offline Find More Posts by snoshoe62
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
