Old May 16, 2012, 11:48 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by capt soap View Post
Had a e-flite v-15 motor in my ultra. It's toast! Guy's give me some replacement idea's, maybe around $50-100.00 . 4s and around 1000-1500 watts. Lee
HET 2w-30
An unbelievable motor for the money and 4S is it's sweet spot on a Funjet
Max Prop (APC 7x6 Sport)
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old May 16, 2012, 12:08 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Gryphon originally recommended the HET 2w30 to me when I was looking back then. I ended up stepping back to the HET 2w25 to keep it lighter and to stay in 3s (which for me has been great since I'm not comfortable with speeds above 120 yet).
But either motor is great. But go with the HET 2w30 if you are wanting more than 130's mph.
cjbucher is online now Find More Posts by cjbucher
Old May 17, 2012, 11:03 AM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
HET 2w25 -- heatsink -- 6x5.5 apc -- 4s 3000--3300 -- 80 amps -- solid 130 mph
Het 2w30 -- heatsink -- 6x5.5 -- 5s 3300 -- I think should get 145mph-ish
Ordered Turnigy 3648-1450 -- hoping to see 150mph+ on 4s - 5s 3300 with 7x5 or 7x6 props
G-Forse is offline Find More Posts by G-Forse
Old May 17, 2012, 11:08 AM
You down with EPP?
Houston, Tx
Joined May 2009
We hot 147mph with the HET 2W-30 on 4S, APC 7x6sport. I haven't tried 5S, but I figured with propping down, I wouldn't get any more speed.
Old May 17, 2012, 01:45 PM
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Can't remember who it was but I remember someone posting that the HET 2w25 could do 133 mph with a 6x4 sport prop and 4s.
Old May 18, 2012, 05:42 AM
LOONY BOY is offline
Find More Posts by LOONY BOY
Canberra
Joined Nov 2003
Het 2w30 --heatsink front and back -- 6x5.5-- 6S-- 2600 Fast!!!
Had good results with APC 6.3x4 combat prop het2w20 and 3s 2200 Fun!!
LOONY BOY is offline Find More Posts by LOONY BOY
Old May 18, 2012, 08:30 AM
You down with EPP?
Houston, Tx
Joined May 2009
Just got a 2W-20 for my Microjet.
TP 4S 1800mah 65C with an APC 4.75xc4.75.
Nearly 1000w in a Microjet
Old May 20, 2012, 11:07 AM
Wilit run? 353 is offline
Find More Posts by Wilit run? 353
No such thing as overpowered
Wilit run? 353's Avatar
Suffolk, England
Joined Sep 2008
What prop is best to use in the Ultra. I have an APC 6x5.5 but not sure this is best, what will give the best top speed?
Also,
How should I mount the pusher prop-
1) Just like a normal prop but spin the motor backwards?
2) Put the prop on back-to-front so it "pulls" through the air despite being a pusher
3) Do i have to buy a specific pusher prop?
Will
Wilit run? 353 is offline Find More Posts by Wilit run? 353
Old May 20, 2012, 12:15 PM
feefo is offline
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Also,
Will
Prop size will depend on what motor are you going to use and the size of lipo (no. of cells).
Props should be mounted as if you would on a 'normal' plane, numbers on the prop facing forward.
You can use pusher props but you would need to reverse the wires on the motor. If you wanted to swap with tractor props (normal props), you would need to swap the wires over again. Best to not use pusher props TBH, they're designed for IC engines (which you can't reverse the motors rotation with).
feefo is offline Find More Posts by feefo
Old May 20, 2012, 12:23 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
I changed my nanotech 4S 2650 45/90C for a nanotech 4S 3300 65/130C, top speed went from 255km/h to 273km/h on the APC 7x10 sport
Now I have 6S speed on only 4S with the 3648-1450, and the motor is not so hot anymore after the flight!
On 6S APC 7x6 sport was borderline on 5-6 sec bursts and speed was ~275km/h
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old May 20, 2012, 12:32 PM
bosco49 is offline
Find More Posts by bosco49
bosco49's Avatar
USA, CA, Shasta Lake
Joined Mar 2005
Whats the ESC your used?
bosco49 is offline Find More Posts by bosco49
Old May 20, 2012, 12:45 PM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Grtz René
I'm messing around with those Motors along with a Scorpion HK 3226 1400 and a 1900...You must be diving right?...I fly about 30 to 40' above ground and level...I don't see how you get that speed on a 4 cell...unless its Gravity induced...correct...Just asking...
I use a 6 cell with 80x60 Master Air Screw prop...and i don't think i'm goin over 160...don't know for sure....Billy
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old May 20, 2012, 01:33 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
If thats an 8x6 prop, drop down to a 7x7 and you will see more speed on the long straight-aways, and your batts will thank you !!
moparmyway is offline Find More Posts by moparmyway
Old May 20, 2012, 02:07 PM
186mph Funjet Ultra
Joined Feb 2010
Hi Billy
It was dopplered in level flight, the 7x10 does the trick, it is more efficient than any other prop on the FJU.
Try the 7x10 on the HK3226-1400 on 4S and see for your self.
Grtz René
Old May 20, 2012, 08:01 PM
Rogersville, Mo
Joined Jun 2008
I just been tinkerin till my Megas show up...I tried some 7s...and they just made a lotta noise....and just churnin air..I remember one was a 7x6....I found a box of APC props...I'll try some more this week...started to work on my Ultra got the wings in place...and ESC is in...I just make 3 runs....and then these down..they Never very warm...Thanks Fellas...I'll try a couple more combos...
Just curious.....anyone know how Max Amps Batteries are..was lookin at the 150C series....?????...Billy
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
