Old Mar 13, 2012, 06:31 AM
LOONY BOY is offline
Find More Posts by LOONY BOY
Canberra
Joined Nov 2003
Thanks, will try warming up batteries.
Ridge is now just a shadow, was thinking about it on the weekend and made the assumption that it played no major effect on control.
One strange thing I did notice on my most recent flights is that the funjet felt spongy when in a turn, kinda like the servos struggled to move surfaces.
Servos are hs65mg.
Will change the ubec output to 6v and see if it helps.
I put the 1450kv turnigy into my f27Q stryker once and ran 6s with 7x6 prop.
Wow talk about wing flex and servo strain.
Just wouldn't pull out of a dive without shutting the motor down.
Never liked that POS anyway.
Bring on the weekend!!
LOONY BOY is offline Find More Posts by LOONY BOY
Old Mar 13, 2012, 07:28 AM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
I use the same servos, but I reduced my max throw mechanicly to ~10mm, and I use dual rate to reduce them to ~6mm with 50% expo.
With a neutral to slightly rearward C of G it is still fine at 190mph.
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old Mar 13, 2012, 07:57 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by LOONY BOY View Post
Sebbe Wow what a loud test in the workshop!
Results are:
6.5x7 prop
6s 2650 45c
150.68A
19.46v
3223w!!
3120rpm
Will get new batteries cjbucher.
Just not sure what to get anymore?
man thats crazy power, pooooor lipo
Are you running the HK 190/200A esc also ?
is that 31200 rpm ?
MAN, are you running hs65 in that potential 200mph ultra, haha, lucky you, dont dive to much, else it wont pull upp and continue 1 meter down the ground
I am going for Hyperion 13 series servos, 8.2 kg holding power
sebbe is offline Find More Posts by sebbe
Old Mar 13, 2012, 08:35 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
One thing more, the lipos are sagging now, so the pitchspeed static is the same with the cutdown 6.5x7 as with the Garupner 6.5x6.5, so I dont think you will add that much more speed.. Maybee the 6.5x7 prop unloads a bit more, dont know..
With stronger lipos you would get more out of the 6.5x7 prop.
Old Mar 13, 2012, 10:30 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
is that 31200 rpm ?
GENS ACE!!!!!
They are the best I have used, hands down. The only true C rating out there. They are also cheap
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 13, 2012, 10:54 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by johnnyrocco123 View Post
GENS ACE!!!!!
Ive heard they are damn god..
BUT, I have tried to find some 2600-2700mah 6s lipo fron Gens ace, with no luck... Any tip ?
And of course, they have to be in stock..
Old Mar 13, 2012, 03:59 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
I got 2 gens ace 5300 6s 30c and 2 nano tech 5000 6s 45 c packs last week, tested under identical circumstances....the 30c gens packs had less then half the internal resistance as the nano packs. I new this but thought i would compare while they were all new. My opinion....a 30c gens ace is better then a 45c nano. Just my opinion based on my charging and discharging experience with them
snoshoe62 is offline Find More Posts by snoshoe62
Old Mar 13, 2012, 04:27 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yepp, but where to buy a 2600-2700mah 6s gens ace ?
Old Mar 13, 2012, 08:24 PM
snoshoe62's Avatar
Joined Jun 2006
Hobbypartz is the only place I can think of that sells Gens Ace, or maybe Nitroplanes, or Xheli. I think they are all related. Problem is finding one that size...I dont have time to check now, but Gens Ace packs are lighter then Your nano/Zippy/Flightmax so depends what you had in there, check the weight, you may be able to find a larger capacity pack with the same weight. If you were running a zippy 2650, I am pretty sure you could get a 3000 Gens at a very close weight, if in fact they make a 3000....again, there variety could use some expanding
Old Mar 13, 2012, 08:30 PM
snoshoe62's Avatar
Joined Jun 2006
option...Series a couple of these http://www.hobbypartz.com/98p-55c-2600-3s1p.html
Old Mar 13, 2012, 08:33 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
www.hobbypartz.com
6s 2600 25c but it's a true 25c which makes it close to a 40c Turnigy nano.
cjbucher is online now Find More Posts by cjbucher
Old Mar 13, 2012, 08:37 PM
FlyBillyFly is offline
Find More Posts by FlyBillyFly
FlyBillyFly's Avatar
Rogersville, Mo
Joined Jun 2008
Without a doubt...I'm a big fan of series....works nicely..I like Gens also...
FlyBillyFly is offline Find More Posts by FlyBillyFly
Old Mar 14, 2012, 03:59 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Thanks, will check it out...
Old Mar 14, 2012, 05:54 AM
Canberra
Joined Nov 2003
RPM was 31200rpm
Running the 190A hk ESC
Run dual rates and a little expo as well.
Prop/motor combo really unloads in the air. Awesome sound.
Checked for gens lipo in Australia mostly sold out.
Will possibly get zippy 6s 4000ma 45c this time.
Running a 3s setup as well just for laughs, all my stryker f27q gear and an old smashed up ultra with lots of glue. Slow
I.d like to know what all you guys are running/ Your latest setup?
Motor,ESC,servos,ect.
Old Mar 14, 2012, 11:08 AM
You down with EPP?
Houston, Tx
Joined May 2009
New Motor
I bought a Neu 1115/2.5D for an F5D project, but I think it needs to make a few Funjet appearances first. I am interested to see how it compares to my....
Mega 16/40/1.5rc
HET 2W-30
Interested.... anyone try the 1115/2.5D on a Funjet or similar airframe?
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
