Old Dec 23, 2011, 12:42 PM
kbuzz1 is offline
Find More Posts by kbuzz1
kbuzz1's Avatar
United States, PA, Greensburg
Joined Dec 2010
Marketing strategies that get me an $80 airframe are ok by me.
kbuzz1 is offline Find More Posts by kbuzz1
Old Dec 23, 2011, 12:43 PM
xxxcellarator is offline
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
true true true
xxxcellarator is offline Find More Posts by xxxcellarator
Old Dec 23, 2011, 03:44 PM
Sterby is offline
Find More Posts by Sterby
Hungary, Borsod-Aba˙j-ZemplÚn, Miskolc
Joined Mar 2011
Hi! I recently bought a Funjet and threw together a setup. Flightmax 3s 2200mAh 25C, PowerHD 40A esc, HxT 2836 2700KV inrunner and Graupner 5x5 speed prop. Flies beautyfully. The setup wasn't expensive and it's a blast in the air.
To those who automatically bash anything cheap and non top of the line, this is a FUNjet. It was designed to be fun. The super quality cutting edge parts aren't necessary outside of competition use. Those who can afford it can use them anywhere, but it's not necessary to buy expensive parts to have fun on the field.
Just to blow your wigs off, I use a Turnigy 9X
Sterby is offline Find More Posts by Sterby
Old Dec 23, 2011, 05:20 PM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Went to maiden my FunJet tonight and found something out. On a 4S setup, a 6x3 prop does not, I repeat DOES NOT have enough ass behind it to keep this in the air. Launched vertically and it would go up, do the torque roll, then would come back down. Thankfully it's been a really mild we winter here and the ground is saturated. Buried the nose about 4 inches in the mud. Threw it up again, same result. Only damage was a muddy airframe and a broken control horn. I'll give it another shot tomorrow with a bigger prop.
Runnikee is offline Find More Posts by Runnikee
Old Dec 23, 2011, 07:37 PM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
All depends on the KV of the motor, will fly very fine on 4S with a 6x3.
markusvt is offline Find More Posts by markusvt
Old Dec 23, 2011, 07:42 PM
Runnikee is offline
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Guess mine didn't have the kv. Not really sure what the problem was. I'll prop up and go at it again tomorrow.
Old Dec 23, 2011, 08:41 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Your setup isnt pushing 1500 watts through it eithor.
Yours should give you plenty of trouble free enjoyment.
The bashing starts when there are reports of unrealistic expectations, or when there are reported power levels that arent backed up with reliable flights, and possibly data, or video from those flights.
How do you like the programming on the 9x ??
moparmyway is offline Find More Posts by moparmyway
Old Dec 23, 2011, 08:58 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Yes please....has it give you any trouble? (Sterby....1st post, hope he swings back through)
Dad_Roman is offline Find More Posts by Dad_Roman
Old Dec 23, 2011, 10:22 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Originally Posted by sebbe View Post
great speed, sounds like high kv and small propp ? what setup/propp ?
The motor is a NEU 1515 1.5D (2700kv) on 5s. I forget what prop (Graupner 6x6?)
crazyj is offline Find More Posts by crazyj
Old Dec 23, 2011, 11:10 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
A break in prop for first discharges of a pack is by definition weak (I mean power and thrust).
That is definitely not the time to launch vertically.
Did you use 6X3 Sport, or 6.5X2.9 Pylon?
Still given that Amp draw, you would have had even less thrust with 5.4X4.5 E
Launch vertically after a few more flights.....not yet....not with a break in prop.
I don't recal having seen this reason for a crash yet. I think we need to add this to list of "Do Not"
Sorry your FJ became banged up.
Actually similar thing banged up my Stryker, but it was not due to cycling a pack.
8" prop, low KV, 3S, semi heavy build, and extra steep climbing after launch ended with same results as yours....minimal damage to nose.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 24, 2011, 12:34 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
That's a large lump of metal.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Dec 24, 2011, 02:07 AM
Toronto, Canada
Joined Nov 2009
Originally Posted by restlessswind View Post
I used to have that motor. It worked very well, up to 400 watts. Anything over that is extremely inefficient, wasted electricity (pure heat--cooled off by cold air passing over it). I believe peak efficiency is at 300 watts. Have fun, maybe some video to show your "stuff"?
Hey restlesswind, here's the video you asked for: Flyjet X83 w/ 2836-2350 @ 1500+ watts
Efficient or not, really doesn't matter to me. I LOVE this thing and still can't believe how nice it runs at this power level. I ran it the other day (few days after that video was shot), it was about 5-10C outside, and motor was still coming down relatively cool. Just slightly warm. And even managed to pull off a 140mph pass. This was with almost no wind (maybe 5-10kph wind gusts on occasion).
... or when there are reported power levels that arent backed up with reliable flights, and possibly data, or video from those flights.
Look at the above video for backup (I'm sure you were referring to my setup, right?).
Old Dec 24, 2011, 02:09 AM
Toronto, Canada
Joined Nov 2009
P.S. That was my very first flight ever with that setup and only my 5th on the Flyjet. Still managed to hit 130mph though.
Old Dec 24, 2011, 02:16 AM
Sterby is offline
Joined Mar 2011
I like the 9X so far, but I'll reprogram it in the near future. I replaced the factory module to FrSky telemetry and the ATMega has a serial port so I'll be able to use the transmitter screen for the telemetry data. Also ER9X has way more options than the factory firmware.
Old Dec 24, 2011, 04:10 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi! I recently bought a Funjet and threw together a setup. Flightmax 3s 2200mAh 25C, PowerHD 40A esc, HxT 2836 2700KV inrunner and Graupner 5x5 speed prop. Flies beautyfully. The setup wasn't expensive and it's a blast in the air. ...
Replace the Graupner Speed 5x5" by a Graupner Cam Speed 5.5x4.3" and I bet you'll love your FJ even more. Luckily, the amount of fun is not linear to the price of our equipment. Quite often, it is even the other way around.
JŘrgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
