Old Dec 21, 2011, 11:13 PM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Nov 2002
Here is my friend's (Karl S.) Fun Jet Ultra that was clocked at 163 mph, and we know it can do better than that, since this was only the first flight!
Karl's Fun Jet Ultra - 163 Mph (0 min 42 sec)
crazyj is offline Find More Posts by crazyj
Old Dec 22, 2011, 12:00 AM
xxxcellarator is offline
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
Yeah right! not if ur comparing it to a Ferrari Enzo! Price ratio is exactly the same as in our situation
xxxcellarator is offline Find More Posts by xxxcellarator
Old Dec 22, 2011, 02:06 AM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
in my 2 year experience with RC, this is the first time I've been up to 6cell. I burned my finger from touching the esc during my 2 minute run up test, to make sure everything is running smoothly. Everything is doing great, but there is a lot of heat. Im sure this is normal for 6S correct?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Dec 22, 2011, 02:30 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Heat is not directly related to the number of cells, but a function of the current. Heat losses = I² (current squared) x R (esistance).
If you are running high currents, your battery, ESC, motor etc. should be up to it.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 22, 2011, 02:38 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Airplanekid333,
2 minutes static test???
Normal static test should be about 3 seconds, maybe 4 seconds at most!!! (pending setup and relative AMPs).
Maybe even couple extra seconds longer if it is KV test.
______________
Part throttle heats up the ESC a LOT more compared to being full throttle.
If you did a 2 minute static test at varying throttle settings, it is possible to have damaged your ESC. Cross your fingers.
I did a rookie move (and posted about it) a few years ago. Most of my FET chips slid off the board and one of the main fat wires also became de-soldered and moved over and got itself soldered on elsewhere.
***Part throttle static test can spell disaster and destruction to ESC....mine was a new Castle Phoenix 80A ESC, and draw was in the 60-70A range (5S).
Told Castle Creations the truth and tried to pay for repair, But the Castle tech didn't let me pay.
________________
xxxcellarator,
I don't agree with you, but it does not matter. We don't have to be in agreement.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 22, 2011, 04:54 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
I would suggest you plug everything together, give a quick 2 second no load at home. If everythings fine, go to the field, NO more testing. Fly it with your 6 cell setup. If it held together for 2 minutes on the ground, it should fly (unless you already damaged something, which is why I suggested the 2 second no-load @ home). Is this the same ESC that got hot before ? http://www.rcgroups.com/forums/showp...postcount=4277
Which motor ? Turnigy 3648 ?
What ESC ? Hobby King 90-100 amp ESC ?
What battery ? 6s2200 (30/60) ?
What prop ?
moparmyway is offline Find More Posts by moparmyway
Old Dec 22, 2011, 10:26 AM
Joined Sep 2009
it is the 3648 with 90-100amp, on 2200 30c, turning APC 7X6. yes it is the same esc that got hot and its still living. Im charging right now to see how much Mah was used during the 2 minutes at half throttle with the prop on. Now i know not to do that again and only do it for 5 seconds now. Thank you
Joined Sep 2009
I will update my maiden flight on christmas day. Cheers
Old Dec 22, 2011, 07:41 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
http://www.youtube.com/watch?v=F2iqVsFA2Sw&hd=1
great speed, sounds like high kv and small propp ? what setup/propp ?
sebbe is offline Find More Posts by sebbe
Old Dec 22, 2011, 09:37 PM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
Cooked my motor at 178mph, these planes can go very fast.
markusvt is offline Find More Posts by markusvt
Old Dec 23, 2011, 05:28 AM
Joined Sep 2000
How do you interprete emoticons?
This subject came up during a conversation with Kevin Hines and it may indeed be something I have never given much thought about - people interpreting emoticons wrong.
Please vote here: http://www.rcgroups.com/forums/showthread.php?t=1560886
Jürgen
Old Dec 23, 2011, 11:12 AM
jeffsch is offline
Find More Posts by jeffsch
jeffsch's Avatar
Seattle, USA
Joined Oct 2009
FYI, this excellent airframe on sale at Hobby People today (only?) for $80.
http://www.hobbypeople.net/index.php...ultra-kit.html
jeffsch is offline Find More Posts by jeffsch
Old Dec 23, 2011, 11:24 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
If I didn't just buy 4 models I would pick up another FJ.
yellowcolorado is offline Find More Posts by yellowcolorado
Old Dec 23, 2011, 01:24 PM
kbuzz1 is offline
Find More Posts by kbuzz1
kbuzz1's Avatar
United States, PA, Greensburg
Joined Dec 2010
This is a sign from baby Jesus....I will be placing and order. Thanks for the link!
kbuzz1 is offline Find More Posts by kbuzz1
Old Dec 23, 2011, 01:31 PM
Toronto, Canada
Joined Nov 2009
LOL, it's more like hobby shops applying marketing strategies which clearly work
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 09:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 04:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 06:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 02:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 08:01 AM
