Old Dec 21, 2011, 12:45 AM
XtremeWingRC is offline
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
Ive learned my lesson too
casey
XtremeWingRC is offline Find More Posts by XtremeWingRC
Old Dec 21, 2011, 02:00 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Guys,
Cold days are here.
Anyone feels like doing a write up covering cold related issues?
Maybe someone else do a little writeup on safety....Good idea to talk safety occasionally (not too often though ... Haha)
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Dec 21, 2011, 05:41 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by GryphonRCU View Post
Guys,
Cold days are here.
Gryphon
I can start:
* Lipos need to be warm before flight
* Some H-wing/plush esc:s dont start when colder then +5-6 degrees celcius, be sure to fly quick to build up the heat.
* Some servos are acting weird/slow when cold, check !
* be careful if going from cold to warm(in car), water can be generated and after time destroying your electric stuff...
----- someone else can proceed
sebbe is offline Find More Posts by sebbe
Old Dec 21, 2011, 05:58 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
...warm HK outrunners shed their magnets when buried in snow
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Dec 21, 2011, 06:33 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by kbuzz1 View Post
I just called Multiplex and this is news to them. Perhaps now "mark it as a joke"?
I assume you called Multiplex USA, but those are not the producers of the kits. Do you really think, Multiplex would go through the trouble changing the decor sets for the FJ Ultra to match the white Elapor? The green camouflage decals for the DogFighter were also planned to be used on grey Elapor, but while the prototyes were grey, all production models are now plain white too.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 21, 2011, 08:48 AM
Joined Sep 2000
Originally Posted by dbgood View Post
Are the new Funjet Ultra's come in white also?
The color has been changed from grey to white. Many customers preferred a white version, because it also provides a better base for individual color schemes.
Jürgen
Old Dec 21, 2011, 12:14 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Jürgen
Interesting....it seems like MPX has a hard time managing Elapor production, justifying shipping, etc.
Oh well... grey was probably the worst possible color for a plane designed to go very fast... but I have to admit that it is a very pretty color scheme.
If I didn't have a grey one, I would be happy with a white one as well.
MRGTX is offline Find More Posts by MRGTX
Old Dec 21, 2011, 12:24 PM
MRGTX is offline
MRGTX's Avatar
United States, CT
Joined Aug 2005
Guys,
I am running an ARC 28-47-2...can anyone reccomend the best possible battery/prop combination for this motor in a FJU?
I have an 80A ESC...but if the motor can safely handle more amps, I'd upgrade that.
Thanks a million for any suggestions.
FWIW, I ran it on 4s/2200/30C with a 6x5.5 prop and it wasn't particularly quick.
Old Dec 21, 2011, 12:32 PM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
bought some battery heated glove liners. worked like junk. also bought some batter powered shoe insert soles and they work decent. Biggest issue is that your hands get cold holding that freezing metal radio fast. Cant wear gloves that are too thick as you cant operate the sticks : (
hidaven is offline Find More Posts by hidaven
Old Dec 21, 2011, 04:00 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by MRGTX View Post
Guys,
Depending on your battery, expect an APC E 6x5.5 to draw about 60 amps.
Expect an APC 6.5x5 to draw just over 60 amps
(these numbers are with about 3.9 volts per cell)
I wouldnt run any prop with more load than about 60 amps.
I reccomend checking motor temp after limited full throttle to be sure it will not overheat in a FJ/FJU
Fastest speed would probably come from a Graupner 5.5x5.5 with your motor and 4 cells
Best acceleration would be the 6.5x5 prop
moparmyway is offline Find More Posts by moparmyway
Old Dec 21, 2011, 04:02 PM
moparmyway's Avatar
New York
Joined Jan 2009
Now how would you know that ??
Old Dec 21, 2011, 04:13 PM
Arcteryxxx's Avatar
Joined Feb 2010
From experience
Motor was a Turnigy 2836 and the layer of white powder was thicker than expected and the plane too heavy to float... Poor thing! Guess the extreme cold caused the bell to contract faster than the more solid magnets and the tension was too high for the glue to cope with.
Old Dec 21, 2011, 04:18 PM
xxxcellarator is offline
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
You keep looking to make fun of the HK/Turnigy motors, but the funniest part is when a <$20 motor trumps ur $100 motor. (obv not all, and not in all aspects, but still)
xxxcellarator is offline Find More Posts by xxxcellarator
Old Dec 21, 2011, 04:36 PM
GryphonRCU's Avatar
Joined Mar 2008
No doubt that in some weird context that could be true.
You need all the luck and good Karma etc to run that motor....so don't start anything that will reduce your needed good Karma.
Good luck.....really, I mean it: "good luck"
Note: Arctery and Mopar are friends, so it is different if they want to have a little bit of fun with each other (given their great history) versus you poking someone you don't know well.
Gryphon
Old Dec 21, 2011, 04:41 PM
Toronto, Canada
Joined Nov 2009
Gryphon
I agree to some extent, but I think one KEY!! issue with those motors is the glue for the magnets. I too have experienced magnets coming loose (but only on 1, the 3648-850kv). Since then I've been adding extra glue to all the motors before running them. Not a single issue since. I'm running the 2836-2350 motor in my Flyjet (which has much better cooling than the Funjet) at 1500watts and 5S. It takes more than just luck to run that kind of power on that TINY motor successfully. Now I can't say up to what outside temperatures it'll keep handling that power, but as it is winter now and about 0 degrees C outside, motor comes down COOL every time (not even warm).
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
