Old Dec 17, 2011, 07:45 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by dbgood View Post
Hi Guys,
The Funjet ultra i have and alot of people on here have is grey!
Are the new Funjet Ultra's come in white also?
Just wondering,
DB
Multiplex has run out of blue and grey Elapor, i.e. all new models come in plain white color.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 18, 2011, 05:37 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
so i got my turnigy 3648 in the mail yesterday, and i programmed my esc and everything got hot! i got 4 out of 6 options programmed and it shut off because of the heat. i let it cool out for a little bit and got the timing and PWM programmed. so i gave it full throttle and it didnt sound good. was it because it was spinning too fast with out a propeller on?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Dec 18, 2011, 08:36 PM
xxxcellarator is online now
Find More Posts by xxxcellarator
xxxcellarator's Avatar
Toronto, Canada
Joined Nov 2009
Careful if your using the HK ESCs. They are well known to have issues programming on high voltage. Even though you are going to use 4s, or 5s, or w.e, do the programming either with 3s or using 8AA cells. I use one of those transmitter battery packs to do the programming on all my HK ESCs. Any higher voltage than that, and the ESCs get insanely hot during programming and they will fry REALLY quick.
As for the way it sounded, it really depends on what you mean by didn't sound good. Describe what it sounded like. Although, keep in mind you shouldn't be spinning to motor to full throttle without a prop on, it will start skipping as if the timing is off. So that might be the issue you are describing.
xxxcellarator is online now Find More Posts by xxxcellarator
Old Dec 18, 2011, 08:44 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
What ESC and cell count? I do not think you do a motor any good running it without a prop, but not sure just how bad it can be. How long did you run full throttle with no prop?
snoshoe62 is offline Find More Posts by snoshoe62
Old Dec 19, 2011, 08:15 AM
Joined Sep 2009
well i am very lucky that my esc did not fry during the programming, im using the hobbyking 90-100amp esc with a 6s 2200mah 30c pack. And i think your right it was skipping and losing its timing.
For the turnigy 3648 users out there, did you have to carve out foam for the motor to fit?
Old Dec 19, 2011, 08:46 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Usually this is only an issue with inferior ESC's or inferior motors. The better motors and ESC's have no problems running motors at full tilt for a few seconds, fully unloaded.
They should only be run for a few seconds to get no-load kv information. Unless they have cooling provided, some can overheat if done for longer than a few seconds
moparmyway is offline Find More Posts by moparmyway
Old Dec 19, 2011, 08:54 AM
kbuzz1 is offline
Find More Posts by kbuzz1
kbuzz1's Avatar
United States, PA, Greensburg
Joined Dec 2010
Jürgen
Seriously? Or is this just a cruel joke?
kbuzz1 is offline Find More Posts by kbuzz1
Old Dec 19, 2011, 10:04 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
I've had 3mm shafts explode at high rpm because of these HK adapters which is why I will only use the Hyperion adapters.
http://www.extremerc.com.au/estore/i...ex&cPath=86_89
Cheers
Matt
Psionic001 is offline Find More Posts by Psionic001
Old Dec 20, 2011, 07:24 AM
Joined Sep 2000
If it would be a joke, I would have marked it as a joke.
Jürgen
Old Dec 20, 2011, 08:34 AM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Jürgen
How are jokes marked?
Runnikee is offline Find More Posts by Runnikee
Old Dec 20, 2011, 10:58 AM
kbuzz1 is offline
kbuzz1's Avatar
Joined Dec 2010
Jürgen
I just called Multiplex and this is news to them. Perhaps now "mark it as a joke"?
Old Dec 20, 2011, 02:10 PM
moparmyway's Avatar
New York
Joined Jan 2009
I wonder how fast a FJU will go on a 6.5x6.5 prop ?
This thought has allways been on the back of my mind.
Do we really need a 7 inch prop for speeds closing in on 200 mph ??
Old Dec 20, 2011, 02:27 PM
Joined Sep 2000
Originally Posted by moparmyway View Post
Guys,
Lets not provoke any more "mis-information" from him, he is famous for it and just loves to see us respond, plus it inflates his post count. ...
I could not care less about my post count. By the way, the information I provided should not be completely new for guys following the old FJ thread:
http://www.rcgroups.com/forums/showp...ostcount=12012
Jürgen
Old Dec 20, 2011, 02:29 PM
Joined Sep 2000
I would have put a Twinker-Smiley () at the end of the sentence or added (j/k = just kidding).
Jürgen
Old Dec 20, 2011, 03:18 PM
kbuzz1 is offline
kbuzz1's Avatar
Joined Dec 2010
Lesson learned. Thanks Moparmyway.
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
